Remus92
Everything posted by Remus92
  1. Yeah. I'd go for the disconnect battery method much easier. You can also disconnect both battery cables and run a small jumper wire between them. You won't need to leave it sit for multiple hours waiting for capacitors to discharge. Just a couple minutes. You can make a small wire with alligator clips and 16 guage wire. This should also reset the air to fuel mixture tables to the defaults.
  2. Might drive it for a few days to see if it comes back. Are you getting any other signs of a bad sensor other than the code? Running rough/rich or hesitation? My scan tool is cheaper so i don't see that much feed backwhile scanning. It may need to be driven longer before a code pops again... I don't see anyway that you could have incorrectly reset the code
  3. You would just have to replace the bad sensor. That specific one is a pain to change. But generally a bad sensor is the cause of that code. I recently had to swap out that sensor after one I put in went bad. I went with ntk... The NGK brand in hopes I don't have it prematurely fail again like the cheap one i bought prior to this. I got mine from Rock auto for $45. They have a lot of choices ranging from 25 to 100 or so.
  4. FYI. Tapatalk has an issue. The error it gives when posting is false. Just reload and you should see the post.
  5. Unfortunately this is a post 1996 vehicle. In 96 due to federal regulations obd ports are now required. You need to use a scan tool. I ended up buying a cheap scan tool off of amazon for less than 20 bucks. You may be able to go to some parts stores and ask them to read it. The port is under the drivers side dash. Right where your knees sit.
  6. http://www.nissanpathfinders.net/forum/topic/11439-17-flashes-of-od-off-light/ Tried this. Nothing came up. Also have no codes. If a solenoid is bad, would I have a coffee come up on the scan tool?
  7. Yes it did. Actually shifted in smoother than forward. Still worked after that work too until Monday. No bad noises. Rpms do not change at all going from park to reverse to neutral. I suppose checking connections would be a good idea. Where is the solenoid located top of trans somewhere? Are solenoids known to randomly fail?
  8. I should add. The transmission acted just fine during that period. No odd shifts or delays. Also fluid doesn't really smell or look different from when I did a drain and fill 2 months ago. I think it smells funky to begin with. But really can't tell much difference between what's in the vehicle and the now empty jug.
  9. So... Is my auto trans toast? 96 pathfinder. I took it to a shop to get an issue fixed. Didn't have the tools up here to do it myself. In the process they removed the radiator. Also undoing the trans cooler lines. Long story short it was misdiagnosed and my starter died right before they did service and they still did it anyway. So they put it back together and I sat pissed off in their parking lot while waiting on a tow truck. Got parts ordered, installed myself, and back on the road. Drive it Friday to the store, Saturday to work, and Sunday to work. Which is 10 to 15 miles each way. Monday it would not go into reverse. Since then, I finally got it full with 3.5 quarts of atf. Still no reverse. Got it pushed out of the drive and took it on a short 1 to 2 mile drive since drive still engaged. All forward gears work and shift nicely. Still no reverse. Any advice? Are there air bubbles that may be trapped? Is it dead? I've called the shop once. I got the whole are you checking it correctly? Are you using the right type of atf? We only drained half a quart! Definitely going to call back and try to get the owner on the line. Any advice guys? I may be out of the pathfinder game again.... And right as I got all the issues fixed after I bought this damn thing.
  10. Open it up and take a picture of the connections to the speaker. A lot of us have the non Bose system but have replaced speakers with adapters. And if nothing else it is very simple to solder the wires onto a new speaker. The best part about the adapters is that you don't have to chop up original wiring. I have a 96 without Bose so it will have some differences in the process but I was able to change all 4 speakers and headunit (including wiring it up) while using adapters in about 2 hours. Just replacing speakers should be fairly simple even if you can't use adapters.
  11. Nice! I love this thread. Keep up the good work man!
  12. That jap crap wasn't made for that... Quit showing how ignorant we are. Want to see my latest jeep bolt on?
  13. Ehh close enough. The typo becomes true once the keys turn off.
  14. Hmmm. For my 96 they had the correct info. I fit 6 3/4" kicker speakers in. But a lot of options in 6.5 and the 6 3/4 all said installs with no issue. On mine I would have been better with 6.5 in the front as the ones I got were slightly big but the 6 3/4 went in the back perfectly.
  15. Try another shop. It may end up being more expensive. But that may be worth it if they have more experienced technicians.
  16. Alright making headway. So the AN 6 threaded on. But I don't have enough threads on the bit sticking out of the radiator to tighten it down. I cannot find any AN or SAE or JIC fittings that will fit without the swivel. Now npt fittings have female to hose barb fittings that are solid. Google assisted me in piecing together that AN 6 threads are the equivalent of npt 3/8x18 and the standard pitch on the 3/8 npt is 18... So I ordered a 3/8 fitting with npt threads... This should work as long as the damn part is actually solid like it appears to be and not a swivel!! Fingers crossed! This may be solved!
  17. If you find wiring that has been damaged or worn, it's usually easy to fix. But finding it isn't always easy. Electrical problems suck!
  18. 1. My guess is this fuse is blowing because it is shorting out on something else. Check the wiring and look for any exposed wires (eg. Something rubbing on a metal support) also double check that you have the right amp fuse. Somebody in the past may have replaced it with one they had laying around 2. Don't know which fuse and I have the prefacelift r50 3. Replace it all. Usually they are just old and worn out. I recently replaced the factory head unit and all four factory door speakers. Made a world of difference. If you already have after market speakers I bet you do still have the factory amp and that is the issue. Someone else may have better advice but that might be a place to start
  19. ..... So frustrated right now. Got the parts in. Yes they screwed on. But not enough threads to tighten down. Emailed the place to ask if they had a non swivel version. They said no and asked for a picture. Then told me it's sae and to go look at propane plumbing items at home depot. Back to square one. I may try Napa and the hardware store in town again. And try to avoid talking to people attempting to help as all they did last time was tell me they had nothing that would work as soon as I started describing where the piece was and what the dimensions were... If I loosen the nut on there antifreeze starts leaking immediately... I don't think I probably have any wiggle room to get more threads.
  20. Yes number 6 female to 3/8 barb. Thanks guys, I was slightly annoyed yesterday from the time wasted at local stores to come up with less than nothing! I'm alright with ordering parts instead of driving to another store. From my area I'm assuming the closest store that would carry these would be 45 miles or more away. I'm not needing to drive out right now... So I can wait another few days! Nothing weird on the transmission end. He didn't get any further back than those hoses. Thankfully... With that level of jerry rigging
  21. And 2 ordered. From an online source. Screw trying to find a specialty store that has what I want in Iowa...
  22. It's not. Those guys looked at me like Nissan's are made on the moon. To be driven by the martian tourists.
