Everything posted by 3rdtimesacharm
The bolts that secure the calipers to the steering knuckle are up for replacement. Does anyone know the original Nissan spec? Looking at what's come off on mine, they're hex heads stamped 6 and appear to be 1/2" 20 unf (?) . I would have thought they should be metric M12 1.25 thread. A M12 x 1.25 above 8.8 grade (with a hex head) is a rare thing around here.. To add to this, the old bolts wont thread into new/ refurb calipers. Which again makes me doubt the old set up.
Maybe its for carrying timber/pipe.
Are we talking fast zombies or slow zombies?
You could wait for a decent truck to come up for sale on the forum. They're usually pretty well documented so you'd know what you were getting. I'd also narrow the list of alternative trucks by getting rid of anything without a frame, ie no unibodies. The more metal under you the better.
I reckon I'll be finding room for a cheap driver + a few decent (Koken?) bits in the near future. Not used any Koken before, could be a good test for them. I'm one of them daft people that like to have the right tool for the job. Thanks again
Has any had much use of these? I can think of a few times when having one would of saved alot of ball ache (if they do work). But, I'm having a hard time finding any decent reviews/ info about them. Here's a pic for reference.. Cheers gents.
If the rear of a 1992 WD21 has discs/rotors, does this increase the chances of it also having a LSD?
In the UK and i guess other civilisations under mass surveillance (?) you get 'car cloning' where you get the reg of a similar vehicle and put it on your own. So your car might be uninsured with no road tax or MOT (yearly inspection) but you can pretend to have all those things. If you were doing that sort of thing, you'd probably search the car ads for candidates.. And if you saw one that is blurred out, you would just move onto the next. In conclusion, it takes miminal effort that could save alot of future agro. As you say in point 4, you could just go view it and get the details..
That GTR looks like its straight out of a Power Rangers movie.
How about breaking it down into stages and re-evalulate at each one. Say, make it solid, then run electric motor via generator then progress onto batteries. Actually dont do anything, you'll be expected to sort the purple paving with the bug out the way. Turn it into a BugBQ.
how many pounds for AC recharge?
3rdtimesacharm replied to ONCEBITN's topic in 96-2004 R50 Pathfinders
我转向日本 我想我转向日本 我真的这么认为.. http://www.nicoclub.com/FSM/Pathfinder/1997_Pathfinder/ha.pdf Page 33? -
I dont know anyone that does. I went as far as using Shell Helix which has a built in detergent in for the first few changes and then moved onto whatever oil takes my fancy. If you were really concerned you could get your used oil tested.
VG30E to TD27T Transmissions swap/rebuild
3rdtimesacharm replied to GlowPlug's topic in 90-95 WD21 Pathfinders
Ah that sounds pretty idyiic. I wont tell you about the flood damage around Seaton and Looe.. Whitsand bay is as beautiful as ever I have found http://www.offroadexpress.co.nz/ to be very informative for WD21s. It's a New Zealand offroading forum but every other member seems to have Pathfinder/ Terrano and know their stuff. Might be worth a rummage. If there are no clues in there i'd go as far as to say its going to be a rebuild of self discovery. -
The R20 diesel was turbo from day one (1993) and the autobox was available in that 93-96 period. They jiggled it about in 1996 with some significant changes like the intercooler and fueling. I dont know if the autobox specs changed at that point but the manual box was definitely altered. If you could find the FSM for that 93-96 period that would be your best bet. Redruth! I don't even like going over the Tamar these days I dont know how you made it to Canadia. I drove through there the other day getting to Stithians reservoir. I can assure you it's still there and not changed since you left. I'm from the Seaton/ Downderry area and know naff all about autos and the witchcraft inside goodluck! -
The R20 used the TD27T, TD27T i and came with an auto. Have you checked out that FSM? it appears pretty thorough regards overhaul. -
Could you lift it with some farm equipment and brace it with some badass bits of wood + straps. Or lift up the back end with tractor and move it 500ft that way. Or pick up the whole damn thing sideways on? Or make some sort of ski for the back and drag it.
There's a site you can go on that lists vehicles in films... http://www.imcdb.org/movie.php?id=1071875 << that's the list for Ghost rider 2 (lots of screenshots).
3rdtimesacharm replied to RedRider3141's topic in The Garage
http://www.ebay.co.uk/itm/Weatherstrip-Window-Glass-Rubber-Seal-Set-Nissan-D21-Hardbody-Pickup-Frontier-/271444009094?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f3352e086 This will be the front ^, all the way from Thailand. I ordered some and they definitely turned up. Yet to open the box got a nice elephant on the label. Genuine nissan cost a small fortune. -
93 TD27 Engine Stalls Until Warm
3rdtimesacharm replied to Drifter2090's topic in 90-95 WD21 Pathfinders
If it still has the EGR fitted you either want to remove/ blank it or clean out the 21 years worth of crap within. Check all the pipes from the injectors back, i'd guess air is getting in the fuel somewhere it shouldnt. Anything interesting coming out of the exhaust? -
Worth a read - http://www.stoptech.com/technical-support/technical-white-papers/-warped-brake-disc-and-other-myths "..even if the brakes are properly broken, if, when they are very hot or following a single long stop from high speed, the brakes are kept applied after the vehicle comes to a complete stop it is possible to leave a telltale deposit.." Essentially, it's more likely to be pad transfer than warped discs.
mebe they are enkrypt3d?
Bait the car (oregano, linkin park CD, frilly underwear? maybe all three) Film them in the act. Now you know who for sure. You'll probably know who they are. Now you've got alot more options, be it state funded or private tuition.
I've found out they're called Palnut Locknuts or self locking counter nuts. They thread ontop as Kingman said and just act as a locknut. http://www.jetpress.com/Products.aspx/lxukkben15/Locknuts-Palnut-DIN7967/ Live n learn. Cheers for help
If you were fitting a front shock, where would you put this extravagant creature? Its pretty snug on the thread already, let alone when it gets compressed. I dont much like the idea of removing it in the future..
