31
Everything posted by bushnut
Eugene
mathalicious! a GREAT customer brought in Saskatoon berry tarts for us today! I still feel fat (only had 2)
whats your fuel millage like? have you replaced spark plugs, wire, rotor, cap recently? does it idle ok? when an engine is not running right but still runs the first things to check are spark and fuel. to little spark or to much fuel can cause the engine to choke.
I had IronMan Lift springs in my 2000 R50 Pathfinder....the sagged to lower than stock in less than 2 years. Stay away....go with OME
- 1 reply
- 1
so happened to me again this weekend...traveling along at 100 kph hit the cruise...all good for about 60seconds....then hiccup ...start to loose speed, cruise control light in dash flashing, press accelerator... nothing. turn off Cruise at switch on dash board.nothing. Pull over to the side of the road and turned off the truck and re-start. all good. didn't try to use cruise for the rest of the weekend. did a 400km+ drive and no other issues was running like a champ. until I realized that on steep hills the transmission does not step down to a lower gear from OD unless I use the button on the gear selector. Is this relay or vacuum controled? throwing no codes but were should I start looking?
Bad or dirty gas can cause all kinds of misery. Bad (old) or gas from the bottom of the tank (at the gas station) is a mechanics nightmare. some times it has water in it or has started to break down chemically. just as a test try filling up with premium from a busy station in a well to do neighbourhood...(Canadian spelling). the reason being is that "nice" 'hoods have nicer cars that require premium fuel. meaning that it gets replaced more often, equals "fresher" gas. As a side note my truck runs noticeably better on premium gas, and has better fuel economy especially in the cold. I figure that it is because the engine (vg33) was not designed to run on ethanol. Ethanol can cause all kinds of problems in older cars as it breaks down and eats rubber hoses and absorbs water from the atmosphere. Though your VQ engine should be immune. as it is a newer platform, I'd still try a test.
So I went to the local JY today found a couple of R50s grabbed 2 injectors from 2 different vehicles. different cylinders....just to up my odds of not pulling more bad ones. total cost...$10.00. they look like OEM one. picked one cleaned it up with carb cleaner and installed....truck runs perfect. has more power. sounds great. I think this problem was developing for a while but took some time to throw a code. just a steady decline in performance that sneaks up on you until things are bad. my advice is to buy an Ultra Gage/ Scan Gage/ Smart Phone AP that lets you see your engines performance in real time. it really helps with diagnostics.
not my first day at the rodeo. I am a bicycle mechanic by trade. fixing is what I do. when searching the internet for a solution to a problem, nothing drives me crazier than incomplete forum posts. almost as bad as blue balls.
GOOD NEWS...there is light at the end of the tunnel. so after checking for vacuum leaks with a can of carb clean (finding none) I started checking the injectors. the should have a resistance of 11- 14 ohms. #5 (miss firing cylinder) was reading at 18 ohms. removed it and it looked Ok. cleaned it and re-installed. truck ran great, code was clear, for about 2 minutes. Then started shuddering again and code P0305 came back. swapped injector #5 with ingector #1.....Lo and behold code switched to P0301...bad injector. heading to the JY tomorrow to find a few injectors...a new one up hear is $192.00.... I know right...free trade may asss. Judging from the lack of tool marks on the hold down screws these puppies are 17 years old and I think I'll have to replace more of them in the future.
I hear your pain. just spent the last week or so chasing a cylinder 5 miss fire code. through careful diagnosis and process of elimination I figured it out to be a bad injector. Have you checked for any Vacuum leaks? a can of carb clean works well for this. I'd even run a bottle of injector cleaner (I know it's snake oil but what do you have to loose?) through the system. are you running premium gas? it does make a difference as older cars were not designed to run ethanol. hope this helps read this....repairpal.com/obd-ii-code-p0171
just remember to use your torque wrench. oh! and DO NOT HAMMER on the splined end of the axle where it goes through the hub. don't ask me how I know. It helps if you disconnect the ball joint and the strut to do the cv shafts.
So the truck started shaking and stuttering the other day CEL was Flashing. Code P0305. Cylinder #5 misfire. Started with the usual suspects. Plugs&Wires #6 is a PITA #4 was almost stuck! Next Distributor cap and rotor, as well as air filter. Oil was changed in December, Cleared Codes with my scan tool. drove around the block and no change still running bad. most definitively not running on all 6 cylinders. Though it starts just fine. first time every try. At Idle you can tell it is not quite right but no bad clanking or other "wrong noises" just a stutter in the idle. today's air temp was -7C. CEL still showing P0305. Just filled up with premium Gas and a bottle of injector cleaner "snake oil". any ideas? tomorrow I'll be checking for vacuum leaks with a can of brake clean. The Question is will there be any harm to the engine driving around like this?
Clicking Sound from the Front Left?
bushnut replied to mjotrainbrain's topic in 96-2004 R50 Pathfinders
after replacing everything else I still had a clicking sound....they were the last and cheapest parts. next time I'm starting there and moving to the more expensive stuff. If you think about what a sway bar does you realize that it is under constant twisting/ bending forces. small rubber bushings really won't last all that long. they are easy to change and are what enginnerds call a consumable. I think I paid like 5 bucks from rock auto. there wasn't any noticeable "slop" but when I compared the old vs. the new it was very apparent that they were worn out. -
check the sway bar bushings that are on the front of the sway bar parallel to the steering rack. they are known to deteriorate and are very quick and cheep to replace. -
Axle interchangeability between different R50 trims?
bushnut replied to whodatpopcorn's topic in 96-2004 R50 Pathfinders
btw all R50s have a whinny rear end. -
I get a low whine from my T-case as well. I have the older manual version.
33x10.5 on Lego wheels - will they fit?
bushnut replied to guycar778's topic in 96-2004 R50 Pathfinders
I'm running 31x10.5 guard dogs on Legos no issues. though I do run wheel spacers. 33 might be a little tight in the wheel well without trimming. -
Threading compression tester into number 6 cylinder
bushnut replied to Citron's topic in 90-95 WD21 Pathfinders
i feel that every engineer involved with the development of the vg33 engine should be forced to be on FREE 24h call to replace the #6 spark plug. thereby forever solving the problem of..."well F$*&K them I'll never have to work on it!" -
I can measure speed, RPM, HP, Torque, % of engine output, Temperature, battery output etc... It also tells me if the engine is in open or closed loop. it is also a code reader (no codes indicated). the loop indicator seems to go to closed as the temperature reaches around 60C normal operating temp is 84C. were is that temperature sensor located?
the ticking noise seems to have gone away. just the usual lifter noise on start up for about 2-3 seconds. cold engine performance is still awful but as it warms up things get better. todays -30C temperatures don't help at all. next week things should warm up a little and I'll be able to investigate more. I'm thinking that there might be an issue with the AIC or throttle sensor.
Ok, so I just got back from running around town. before I left I opened the Air box ( I tied the air filter to the intake so at least the engine would be breathing through a filter) and just left it open a crack. As it is -20C right now I wasn't to worried about the sucking up to much hot air from the engine compartment. The engine purred very smooth at idle 750 rpm. however according to my Ultra gauge while accelerating from 0-70km/h at 1/4 throttle the engine was running at 1800-2000 RPM and running at 100% of capacity. delivering 200ft of torques but only 98hp. I was keeping up with traffic but then engine sounded like it was working way harder than it should. I'm wondering if my torque converter is slipping? how would i tell? is there maybe something else I might look at? thanks 'yall.
