Everything posted by edicer2
idk if u want to go this rout or if they would require a tune or not but here are some people use on their z31 vg30e and vg30et motors toward the bottom http://www.thezstore.com/page/TZS/CTGY/PEM01
most wd21s by now that have them are probably worn out unless they were replaced. So you might not be able to tell a difference anymore.
Anyone have experience with cross drilled or slotted rotors?
edicer2 replied to nmpath's topic in 96-2004 R50 Pathfinders
i wonder if z32 brakes will fit? I put the z32 brakes on my z31 with the turbo hubs off a 88t z31 and floating rotors and damn did that make a difference. I was told get sloted rotors for daily driving dont get drill or sloted and drilled because the drilled ones cool to fast and warp much quicker. -
could it be a vacum leak? does your new one light up at all?
I dont know much about r50s but im going to guess SE it could be any of them though I think since you have the tire rack na spoiler possibly a SE and since you dont have leather seats not a LE but i could be very wrong about that.
I have the same problem it lights up on my dash but when i push the set button it does nothing. it used to work but it quit im not sure what caused it though.
check the MAF and the connector to the MAF mine did that everytime i put the clutch in and let the rpms drop. It ended up bring the wireing was getting hit by the hood and causing it to put a short in it if i touch the cord while the car was on it would rev or die
looks great so far!
ecu might be on the frits just a thought....have you run the codes off the ecu??
mine never goes more than 1/3 of the way....i was going 80 on the highway for almost 3 hours with ac on in 95 degree weather also. intown it never goes above a 1/4
i have stock manifolds and down pipes, magnaflow high flow cat, then flowmaster 40 series muffler, and a 4" truck tip
i have a alarm moduel if thats the case but idk if it works my led would blink in my old pathy but i couldnt arm it
well the pathy from 93 down are cable drive speedos, the temp might now work because of a bad thermostat i know nothing about the auto trans besides they over heat and need tranny coolers
nice cage! Wishi had one but they cost so damn much. Another project im working on is i just bought my first house so im in the process of redoing it. I also just got my htpc to finally work great on my tv that was a bitch.....had to buy a better vid card
I like working on computers and also I have been getting parts to make my 300zx na2t or just plain t witha holset hx35 turbo. since eplaced the shift boot with a nice new black leather one power coated z32 4pot brakes thee things are huge stock rims dont fit anymore test fit the rare turbo tail light and smoked lenses
What did he say it was charging at for volts? mines formaly around 14 something. The reason i mentioned the belts is becasue mine got bad one time and the alternator one was slipping and i replaced the belt not the altenrator like the mechanic wanted to and itfixed the problem. You could check your grounds for the alternator and battery and make sure they are good.
sounds like what the above 2 said.....could try making sure your belts are in good shape and are tight
you should try doing a compression test. also maybe different oil, injector cleaner, seafoam. Idk stuff to try that are cheap
i have no idea what the factory size is...sorry
wow that came out really well!
i noticed a difference with mine plus i like the cool sucking air sound it makes! My exhuast at high rpms drowns it out but low rpms people turn and look lol
I have a 2.25" magnaflow high flow cat and a 2.25" flowmaster 40 series muffler with a 4" truck tip and it sounds great. Now i am starting to have problems with my manifold warping though so i need to fix that. its sounded mean before my manifold warped. I also have a cold air intake so u can hear the sucking noise and the nice exhuast sound.
i dont think there are relocate kits i think its only option is a snorkle but i dont offroad really so u would haveto ask someone else then
depends theres a cold air intake and there are snorkls depends on street driving vs mudding
they have them on ebay for like 50 bucks i have one on my pathfinder pretty much bolt on. might just need a few extra small hose clamps and also maybe something to help support the air intake i had a small metal piece i bolted on. metal bracket i made. hoes get close to the belts
