Everything posted by edicer2
one thing i would expect is plan on buying new hose clamps and vacume lines...those always seem to break if they are the orginal ones.
ha sounds good...power steering pump going bad?
hey man i have the same problem in my 92 and had the same in my 93....its most like not the cluster it has been the end of the cable that goes into the cluster. it is a little white part that snaps onto the end ofthe speedo cable and looks like a square needle the goes int the back of the cluster. well it seems the plastic cracks on it and the cable spins inside that part that clips on to the cable so then its not spining the gears in the cluster. i have tried replacing that tip on both trucks and it has worked for a few months then cracked again. I am thinking my cable is wearing out and hard to turn so i think the best best is to replace the cable. you can certianly try the tip but its hard to find one thats not cracked already. Only part that sucked about the cable changing is idk how to remove it with out taking the into plenum off its a very tight space atleast at for my big hands. Hope that helps. edit....the tip will look like its spinning but to be sure try driving slowly down the road and put a little pressure on int if it quits spining then theres ur problem.
very nice!
x2 thats what has happened to both of my pathfinders
i have after market ones from ebay i dont think they have any moister escape but mine have never fogged up at all i could always look but i think they are pretty much sealed up http://cgi.ebay.com/ebaymotors/87-95-PATHFINDER-88-89-HARDBODY-CRYSTAL-HEADLIGHTS-LAMP-/390268773988?pt=Motors_Car_Truck_Parts_Accessories&hash=item5addd4e664
yeah good luck man i hope u can fix it! this happened to me in my 93 but my frame was rotted out so i junked it i bet your frame is good motors are cheap so its free to take that apart and see the damage if its not bad the nfix it if its bad swap a vg33!
i have them in my 92 and i have never had a problem with them i got mine on ebay for 30 bucks though. Mine dont have the highbeam but i never need it anyways. I plan on retro fiting some projectors into my 92 aftermarket lights because it scatters the light to much. I dont think u will burn them out if they get wet if anything dont have them on when your driving in water. i took my headlight unit out and calked all the seems and made sure i was gettign good suction where the bulb is seated.
i have found out if the sensor for the rear glass isnt good or isnt being contacted good enough the wiper doesnt work. just a thought
aww yes i went and looked at my old speakers(from my 93) they were 5x7 my bad they were all the same size though...sorry
mine were 6x9 all around in my 93 se i think.
http://www.certifit.com/images/catalogs/MN.pdf go to page 237.....parts a new and cheap!
Ridiculously cool idea to help me think about!
edicer2 replied to kefferjoe's topic in 96-2004 R50 Pathfinders
you would defaintly not have any power issues whatever if he did a turbo vg33 -
HA yeah its a blast thats what its making right now on this piss poor tune with e85 I need to being it and get it tuned again after installing my bovand intercool. This hauls though can still light up the tires around 70+ if i drop it down -
the vg has been around alot longer and has much more after market due to that so u can get forged parts and cams and its a iron block. my vg33 z31 has a gt3582r on 15psi making 470 hp right now and its a stock motor and has been like this for over a year so far. -
u might be able to get a z31 aftermarket clutch fit -
most people (like me) upgrade their vg30 to vg33 in their z31 and swap the turbo crap onto it and its a major improvement! so u can use ur motor just get a the couple of turbo parts u need and swap parts not whole motors -
my freinds pathfinder would do this....when u pressed on the gas the whole shifter would lurch forward like a inch then when u let off it would lurch back and it would pop out of gear...were were pretty sure he has a bad mount and also a bad syncro
yeah most parts stores sell the high temp brake lube stuff in the little packets for like 50 cents each when ur at the register.
sounds like ur getting ripped off on all of that parts.... go to a different repair shop....a cluch cost me 400 bucks to get done a tranny is maybe 500 and those prices are with the parts inclused in the labor brakes do not cost 500 bucks
personally i would put ur bearing races on and new bushings and see how it is. if it doesnt wobble or look like its going to wreck the bushings i would leave it alone. worse case is u cut a few ofthe spot welds for the bearing races and have to retack them on once u make the hole smaller.
i would go to a u pull or a junk yard and get new calipers or buy re built ones I wont bother with leaking ones at all. If it was just the slide pin i would fight with it somemore and all of them when it was out (i do this evertime anyways and grease the @!*% out of them whenever i change the brakes pads) but since you cant get it i would just buy new ones. Your best bet is a parts store for the same day fix or if not a big rush then online but it will cost you more from a store.
i think the hole is too big. Im not sure what size mine was but i think the holes need to be a little smaller looks like that will move around alot.
i think if i were to build a new motor i would of picked a vg33 damn near the same thing but it makes a major difference. I bought a z with a swapped vg33 in it and holy smokes is there way pepper than my vg30
i dont think it will fit it barely fits in a z31 which has a larger engine bay
