Slartibartfast
  1. I've heard you can clear 33s even without a lift, but that's on the alloy ("lego") rims. I know the steel rims are narrower, no idea on backspacing etc. If it needs an alignment, getting that done could help. Also,
  2. ^+1, the trans gets confused and locks into third, which isn't much use when you're stuck in a snowdrift. Shut it down, start it back up, and see if it goes then. If the E-AT light's flashing, the trans computer thinks something's wrong; normally it'll illuminate at startup, then go off. (I think it stays on if you've got it in 'power mode.') Failure with these is usually more gradual. Unless your torque converter gave up, my money's on the computer being confused.
  3. I'll bet the condensation is from the A/C condenser.
  4. I've heard that you can just slide it forward... I pull mine out so I can see what I'm doing. It's four bolts (and a plug if you've got heated seats), not too difficult. Mine had the same issue a while back. It would work just fine until it warmed up, at which point the computer would start referencing sensors, clearly something was faulty, because it started twitching out (dipping and surging, stalling at stop signs, the works). Never did figure out what was wrong... but my dad and I messed with the TPS and MAF plugs, packed them with dielectric grease, and bumped the intake around a bit, and it hasn't acted up since. I suspect the TPS plug or wiring was the issue, though when I took it apart it was totally clean inside. I never checked for codes, but it never triggered the CEL.
  5. Are you a wizard? More to the point, can you do a write-up on that? Mine took a couple hours each time. Imagine if that seam above your hand was 1" lower. Right where your knuckles are. The manifold to plug distance is the same, and you probably don't even notice the 1" difference in height, except that the firewall's in the way.
  6. The easiest way to tell is to look at the back of the rear axle. It should have a radioactive-orange sticker that says 'LSD OIL ONLY.' If it's got that, it's LSD. The other way is to do a burnout on gravel. Two tire marks? LSD. One tire mark? Open. I think there's a 'Do I have LSD?' thread pinned somewhere.
  7. Is it jacked up while you're doing this? Maybe turning the wheel a bit would improve the spline alignment or something?
  8. Probably. Normal water has minerals in it which can react with the coolant. I don't know about the drinking water in Taiwan, but here, it's so 'hard' that it makes crusty build-up on sink taps. Not something you want in your engine or your rad! A full flush and new coolant/distilled water probably wouldn't save the radiator, but would be much better for the engine internals.
  9. ... so you put it on a jack stand, only one wheel spun easily, and the other one had a really hot brake drum? It may not be your only problem, but I think you've got a sticking brake.
  10. Rebuilt/junkyard picked is probably a whole lot cheaper than new. But, yeah, what's wrong with them? If you can pin down what's wrong, you can buy just the bits you need, install them yourself, and save a whole lot of money. If they're ticking like a sewing machine, that's the lifters... if they're leaking, replace the gaskets... etc.
  11. I doubt you'll find an adapter... not a lot of people make bits for these. If you could mate the engine and trans... rework the frame etc for the axles/shafts... it could work. But it sounds like a lot more work than swapping in a Nissan 5-speed and hacking up a Yota axle. I suppose you could also just put a Toyota engine in it. Then you'd only have the mounts to figure out. At that point, though, you might as well save yourself a whole lot of work and just pick up a Yota!
  12. Looks like the pics aren't working. Dechroming shouldn't be too hard. I've found that Simple Green works pretty well on plastic-chrome coatings, and a scratchy pad should help. Then just jam some newspaper around it, hose the badges flat black, call it good. I personally like chrome... when it's on metal.
  13. Save your 30 cams though, aren't the 33 cams smaller?
  14. I torqued them and called them good, and haven't had any trouble with them since. No locktite, though I did shoot a little WD-40 on the threads so they wouldn't rust in place. I don't remember how close they are... maybe remove all but one, then see if the hinge tries to pivot. If it is bent, you might be able to find a straight carrier in a junkyard. Fixing a bent carrier sounds like a royal pain. Also, I just went out and checked mine. The gap between the rear quarter and the hatch does change, but not by much (maybe a millimeter or two). I'm not sure if it's a little bent, or built a little wrong, or if it's just heavy and forcing the panel to flex. Dunno if this helps any.
  15. If you pull the driver's seat, you'll see the alarm underneath (it's got an antenna). The truck (well, mine anyway) will run with the alarm unplugged. I don't think the alarm has a starter kill to it, so you may be looking at another problem there. Unplug it, see if you still have issues. If nothing else it'll help you track down what the actual problem is. And Lee, yeah, I'd wager that the broken locks are part if not all of your problem.
  16. You would obviously have to move the hinges... probably to the side of the tailgate, with the joint sticking out from the panel gap a little. I suspect they're not well braced on the sides, so you'd have to shore up the inside of the panel and the door jamb to keep the door from sagging/deforming. Then you'd have to hack up the other side for the latch/striker, and re-configure the linkages inside if you wanted the lock to work... only other thing would be re-routing the wiring for the locks/hatch popper/defroster. So, a whole lot of work, just to have it swing out oddly. I'd be inclined to chop it down the middle and hinge it from both sides, like a delivery van. That'd be a whole lot easier to open/close in tight parking spots. Of course, you'd have to cut/reframe the glass... the hinges would probably hold up a lot better, though. Or, you could just throw the tire on the roof and call it close enough.
  17. Cousin put this on FB... copy http://www.moonhonda.com/inventory/autocheck.aspx?vin= into your browser, then add your vin #. Turns out mine was a fleet vehicle in New York.
    1. Tungsten
      Tungsten
      that is awesome
  18. Upload to Photobucket, paste the IMG code here, and it even resizes for you. If they're not too bad, you may be able to beat them straight again, assuming the frame and body aren't too badly torqued. I'm sure you'd have some trouble lining them up.
  19. Seems like the problem isn't the shim so much as a bent carrier... short of chopping and welding I'm not really sure how you'd fix that. You might try backing out the bolts a little, open it and close it, that might at least show you which hinge is sitting wrong... maybe a little work with the BFH would put it right. Watch out, though, the carrier is one heavy SOB. If the hose isn't working, try an automatic car wash. I remember going through one of those in my mom's old Jeep with worn out window seals... it washed them on the inside too!
  20. Are you set on buying new? Why not just grab a VG33 and trans from a low miles junked r50/Xterra? That trans (if yours is an automatic) is stronger, and of course the engine's a little bigger.
  21. My 95 did seem to pick up a bit with a new (stock spec) exhaust. I'm not sure if that was due to the leaks it used to have or the new cat (mine actually came with two, both of which were probably clogged). It had no CEL before or after. Have you run the codes again? I don't think there's a sensor for a clogged cat. It might be something else coming up because of the cat, or something else entirely.
  22. If the one-way valve somewhere in the tubing leaks, the fluid will drain back out, and you'll have to hold the switch for a bit to re-prime the line. I have to do that on mine sometimes, if I haven't used it in a while.
  23. Sure it's not a blown fuse? Pull the relay out and test the coil. Just hook one side to the battery, touch the other, see if it clicks. If it does, set up a voltmeter on the other pins to make sure it's making/breaking the connection. If there's no click, or it doesn't connect up inside, it's your problem. Past that, I guess it could be a bad switch, or a bad wire somewhere.
  24. You might also try unhooking the battery cable for a few minutes to reset the ECU. That should give it a chance to re-learnt the engine with high-altitude air.
  25. LOL, sounds like something I'd do. Glad you got her working.
