Slartibartfast
  1. ^Does look a little taller... then again it might just be adjusted for factory droop! 31s, I think the T-bars have been monkeyed with, but it sure isn't lifted.
  2. You say it got better when you messed with the cleaner... this makes me think, A, there's a crack between the air cleaner and the throttle body (I know there's a rubber pipe that can crack or lose a vac hose on the MPFI trucks, dunno about TBI though), or B, it's temperature-related... is it still getting worse each time you try starting it? Maybe check the coolant temp sensor?
  3. The farthest I've ever been into my trans was pulling the dipstick to check the fluid, so... no idea. The kit you're looking at looks like it's got everything. Chances are you'll get a few things that aren't broken in yours, but if you're stripping it to the shell, seems like you might as well put new bits in. Also beats getting into it and realizing something you didn't get is bad! If you click the 'info' thing next to the part number, it tells you how many of which part # you get. Oddly, the factory service manual doesn't seem to specify by #. If you don't have the FSM, go here and download the AT section (if not the whole thing, it comes in handy). It's got an overhaul procedure with expoded views, torque specs, test procedures, the lot.
  4. Good to hear it's alive. I hate crimp connectors, I've been going through and soldering stuff up on mine.
  5. My understanding is that you drop the old trans, bolt the new one in its place, fill it and go. Plugs/bolts right in. It's pretty much the heavy-duty version of the older trans. You're looking for a Pathy or Xterra trans, up to 2004 IIRC, that came with the VG33 engine. I'd see if a junkyard near you had one, get a price, and compare that to a rebuild kit. Looks like these guys have the kits: http://www.rockauto.com/catalog/raframecatalog.php?carcode=1211926&parttype=8512&partkey=1286247&a=FRc1211926k1286247-894518 If you do decide to swap the trans, but still want to wrench on something, see if you can pick up the VG33 from the donor vehicle. I hear that's a fun project.
  6. I just tied mine on a little tighter with fence wire... I'll see how long that lasts. They sure are a pain to get to!
  7. I don't think I've heard of many people rebuilding the Pathy AT. The early R50/Xterra trans is stronger and bolts right up... a better setup for a lot less work. Unless it's been run with sand in it, the clutches are probably all you need to worry about. I've never rebuilt a trans myself, but it seems like that's always what goes bad.
  8. Yeah... the 3k rpm is limp home mode... it'll do that if the MAF is dead or the wiring is buggered. Did you replace the MAF with the other stuff? Check the wires/plug/sensor...
  9. Yeah, 4x4 shouldn't affect it when you're turning sharply, on-road... mainly because it shouldn't be in 4x4 on-road! If it's in 4x4 it's winding up the front diff against the rear diff, building up torque until something (usually traction, but sometimes a hub, and sometimes the transfer case) gives/breaks. When it's wound up it'll have crazy high friction, which could account for it failing to roll downhill. There's no central differential or coupling in these, so the wheels have to slip a little in 4x4 when you go around corners. (Unless the tension is released, it'll still bind when going straight.) Assuming your transfer case and hubs are working right, the 4x4 system does absolutely nothing when it isn't engaged. The CV axles shouldn't even be spinning. The T-case lever should be all the way forward, and the light (square dash has a 4x4 light, right?) should be off. You can also jack up the front end and see if you can spin the wheels. Both fronts should spin freely in either direction. While it's up, check and see if the transfer case shift linkage is buggered, that could be keeping it in 4x4 no matter where the lever is. (Never heard of one failing though.) If it's not in 4x, then I don't know anything... sorry.
  10. Weld the flanges together and keep rollin.
  11. Just opened mine up, pulled the hose off the actuator and blew into it. No resistance, like there's not even a pump there. I tried sucking on it too, nothing. I imagine the pump locks up a valve or something when it gets going. (I can't imagine it as a sealed unit in an engine bay... too much temperature variance, thus pressure variance... probably.) The one thing I did note was the cracked and hardened hose... at this point I doubt your hose is bad, but it couldn't hurt to check. Of course, I've never actually used my cruise control. My dad said he got it fixed when we got the truck, and IIRC he tested it, but my commute's too short and hilly to bother with it. Anyone with known good cruise want to chime in? Given that the 'resting state' of the pump appears to be wide open, I'm guessing that the 50-60 seconds are controlled by the cruise control circuitry... maybe check the wiring? Or, as Silverton said, the sliders behind the steering wheel. My horn worked fine until one day when it didn't... didn't take the wheel off (couldn't figure out how to remove the horn pad) but still got loads of crud out with some alcohol and a q-tip.
  12. I'd download the service manual (if you haven't yet), then pull the interior door trim to get at the plugs and things. Hook the 12v tester to the window motor, have someone try to move it, and see if you get 12v to the tester. If you don't, there's a problem somewhere in the wiring. If you do, but the motor just won't go, then... either the window itself is stuck or the motor's cooked. (Do you hear it humming when you try to make it go?) The tester has to hit metal/wiring, so yeah, a little disassembly is probably required.
  13. Give the exhaust gaskets a check... one easy way I've heard to do this is to duct tape a shop vac or something to the exhaust pipe. Then you crawl underneath to see where it's whistling (or use an incense stick or a cigar or something to see where the air's going), and find the busted gasket/rust hole/whatever. Mine was loads quieter after its new exhaust, and did seem to pick up a little power. Probably couldn't hurt to unhook the ground strap, let the computer reset, but I doubt that's it... seems like it'd only be confused while you were in the mountains.
  14. I just loosened the bolts for the skid, pushed it around until the latch just barely hit right, and resolved to ignore the tiny big of panel movement left over.
  15. Looks like a crank angle sensor wheel, the new engine controller must have a sensor for that. From what I've read, the water injection should help keep the pre-detonation (knocking) down. How's the trans holding up?
  16. Possibly... it's gotta come out somewhere, it could just be a stuck valve. I'd probably try tearing into the pump to look for dirt or bad rubber bits.
  17. You can get selectable mufflers now, there's a little baffle inside that you can actuate from the dashboard. Goes from loud to quiet pretty quickly. It's more of a rice rocket thing, though. I've heard a cold air intake makes the exhaust sound a little deeper.
  18. Leak between the pump and the actuator?
  19. They're not universal, unfortunately. The bolt spacing differs between 4.5" and 5.5" according to 06 Xterra: 6 lug 4.5 inch or 114.3mm 02 Pathy: 6 lug 5.5 inch or 139.7mm So no, doesn't look like they'd fit, regardless of the center hub.
  20. I've read about people swapping the heads between without changing distributors, so you should be good with the 30 dizzy.
  21. Got it back from the mechanic, found out the timing is fine, it just sucked some crud into the fuel system. It's got a little tick at idle... I'll see if it smooths out over the next week. Nice to have it back!
  22. Pathy's back home... the shop pulled and cleaned the fuel pump. Apparently the tank was nearly dry, the pump was full of crud, and this was severely limiting the fuel supply to the engine. My fault, then, for running it until the light came on. It did sit for a year (under a pine tree no less) under the PO, and I've heard that this tends to increase tank gunk. I did hear some backfiring when we were trying to start it before. I'll keep driving it, and if it starts doing the same stuff again, I'll pull the dizzy. (It's the crank sensor that goes bad, right? Or just buggered terminals/rotor?) Thanks for the help, guys... hopefully the problem's actually fixed this time. Edit: It hasn't acted up since... definitely the pump. They didn't even replace it, just cleaned it out.
  23. Check out the frame rust repair thread in the WD section. How bad's yours? I've seen people on here rebuild frames from rust flakes... mine just had a few holes in the sides. My dad and I had a guy cut patches from 1/8" steel, ground them to size, and had my uncle weld them up. Any pics of the rust carnage?
