Everything posted by WOT
Mine used just over 1.5 liters I went with royal purple synthetic for my non lsd diff
Those headlights are oem with projector units like that?? Very nice looking didnt know that was an option. Id definitely clean up the top right side of that hole though
You really dont think a SBC would fit in there length and width wise?? I figured we had tons of room for it and that would never be a problem I thought trans tunnel/rear end would be the big hurdle
Ive got the 3.5 and wish there were more parts available for it not as quick as Id like it to be And converting to 2wd Id assume
Once my motor goes Im probly switching to a V8... Id love to see someone do it first lol, obviously youd probly lose alot of your luxury items and have to do alot of fabrication and one off pieces and problems, possibly even may have to make a bigger tunnel for the trans. a/c would probly be lost If you stayed with a carbed engine though, it would probly be very do-able depending on your skill level
Do they have good light output?? They look a bit out of place where they sit, maybe just the pic, curious on there function though My friend has the 6" Hella lights (4of them) on his F150 and god damn do they ever throw light as far as you can see!!!
Where Is The Fuse For Fog Light On 02 Nissan Pathfinder?
WOT replied to accurrate1's topic in 96-2004 R50 Pathfinders
Most of the relays under there are the same prong style so I simply swap the relay out with one from another source that I know is good working There is also a fuse box inside the car where your left knee would be while driving against the dash, you open the little tray and it pops out revealing another 30 or so fuses But Im pretty sure the fog light fuse is in the box beside the battery -
Did You Guys Know We Have An Oem Tranny Cooler?
WOT replied to WOT's topic in 96-2004 R50 Pathfinders
Thanks bud I overthink everything -
Really I had no idea that was standard, but this is my first automatic vehicle I guess, just familiarizing myself with the odds and ends of it I did go for a drive after I replaced the hoses and then checked fluid I was more concerned with how little came out of the rad when I disconnected the hoses, didnt know if there was supposed to be a good quantity in there and I have a blockage somewhere, or if everything is good. -
Found out something new about my truck yesterday. Our radiators have an oem oil cooler built right inside them!! I was replacing some worn clamps and random vacuum lines and such and noticed the 2 lines coming out from the bottom of the radiator and going to the middle bottom of the engine were looking quite nasty. So I bought a 4' section of hose and some clamps to replace the corroded ones. I got a good surprise when I pulled the first line expecting COOLANT to drain out of the hose (I thought it was a heater hose of some kind) only to find that damn ATF fluid spilled out. I changed both hoses no worries. But heres the "problem" I only lost about 200-300ML of fluid, and I think most of that came from the engine side of the hose, I dont know if any at all came out of the rad barb actually, this kind of alarmed me as I figured I should have lost alot of ATF since it is a very low point hose on the car, or at the very least there should be a good ammount of fluid filling the oil cooler ( I have no idea how big it is inside capacity wise mind you ), but my ATF level was within spec. Just dont know what to make of this Just curious, any opinions on this? Anyone ever played with or known about this cooler?
Rear springs, looking to maintain stock height with 600lb load
If only I could make international phone calls!! -
Well some people claim more or less so it would be nice to know from a manufacturer how much lift it gave, front and rear in real world conditions. I still dont know which to go with. -
I used the clutch plate hole for my huge wires, its a perfect spot and comes out at a perfect location inside the car to run the wire, its not sharp either but rubber hose sliced down one side and cut to length to fit around the cutout doesnt hurt
Put the batteries on a trickle charge for the heck of it. Re-aimed the washer nozzles Cleaned headlights and taillights Tomorrow: New upper rad hose lower tranny cooler hoses coolant system flush oem in cabin air filter remove wiring for aftermaket temp gauge I also need to verify my transmission fluid level, I kept getting readings of being way to full when checking it HOT, but Ill let the truck sit for a couple hours and see what it reads and drain it or leave it from there Gonna be a cold sunday
Would be nice to know... -
Couple hundred Aussie dollars to the right inspector... And shes got a paper-legal V8 swap
Still have P0136 code after replacing sensor?
WOT replied to HitMan's topic in 96-2004 R50 Pathfinders
Have you done anything to the passenger side sensor or only the drivers side so far -
Have a pic of it spaced out 1.5"? Why would it rub if it was spaced out more? -
Ya Im debating keeping my car low and trying to keep it like I have, which is lower than stock, but maintain the weight somehow Or if I should lift it 3" rear with WJ coils, 2" medium duty front. And throw my wheel spacers on it. Mind you my wheel tucks in behind the fender right now if I get 2 people to step on the hitch, if I were to space them out, is there a good chance of hitting the fender?? Ive never done spacers before and dont know much much lift is needed to clear if I were to space them out and go for that wide look -
I cant really tell what conclusion you came to either with the 02 sensor side maybe Im just stupid at reading. But if your code is for bank 1 sensor 2, it is for the passenger side -
You dont HAVE to leave the battery disconnected for 24 hours for it to reset. A nissan tech told 2 ways to do it. First way is you disconnect the positive and ground from your battery and then tie them together with a piece of mechanics wire to keep them in contact, leave disconnected from battery and touching for 15 min and it will be fully reset. You must be sure to have the cables disconnected from the battery before grounding the positive wire though obviously Second way was to simply remove positive and negative cables and apply the brakes 5 times to deplete all the energy left in the system, wait for 15 min, and it would be reset. I personally do it the first way now and it works great, all stored codes are gone and reset after 15 min of being tied together and disconnected from the battery, but an IDLE air volume relearn procedure has to be done on my car everytime I reconect, probably because I have a custom cold air intake so the air values are off from the factory settings. -
Ya man youre explanation was perfect and worked like a charm. I figured out where the break was, it was around the back of the headlight, so I cut out that 18" of wire portion or so that went to the factory pump. Then I found the 2 wires you explained in the main harness, a thick gauge red with that had a constant 12V but lost power when pulling fuse 19, then the blue/white that triggerred ground. All solderred to my dual pump harness and shrink wrapped and loomed ofcourse, came out looking factory And the best thing of all is that works with the factory column switch by pulling it back like it should, no ghettoness, and the dual pumps pushing each nozzle throws a crazy ammount of fluid, I should take a video after I aim them a bit better. Thanks again
ya not really going for the muscle car rake, I was more going for the lowerred look having the fender close to the tire with all my weight, but also not having the tire rub the inside... I also have fairly big 2" wheel spacers I bought along time ago, debating putting those on and buying a slight lift, because if I put them on as it sits now, Id probably rip my fenders right off lol -
What would cause my temp gauge to read improper?
ya rock auto wanted some crazy shipping costs Ive been working 12 hour days, hoping to give NIssan thats 30 min away a call, and maybe napa just to get a price difference. Im assuming changing this sensor is going to pee coolant everywhere right?? And I just did a coolant flush Aparently this sensor being faulty could be a cause of my poor start conditions and full throttle performance as the ecu thinks Im overheating with the current sensor, any truth to that?? -
Just another part number question, at the very end of this thread there is mention of part number OME922, supposedly for the rears?? http://www.nissanpathfinders.net/forum/index.php?showtopic=11484&hl=ome%20part%20number&st=20 If I am orderring the rears only, is that the part number Im going for? Is there no difference in medium/heavy duty in the rear springs??
