5
You just need a manual trans from a 4WD, the t-cases are all the same.
Is this possible with SLR Headers
88pathoffroad replied to mora2818's topic in 96-2004 R50 Pathfinders
I'd call and make sure they actually have some before even considering it. SLR is famous for selling stuff they don't have on the shelf and then waiting months before getting them made. -
Auto Tranny slipping under hard acceleration
88pathoffroad replied to OE812's topic in 96-2004 R50 Pathfinders
It shouldn't start off in 2nd. That's not standard practice for nay transmission I know of. -
How to prevent frying your alternator....
88pathoffroad replied to sammyb33's topic in General Forums
Wash it out after getting it muddy. I've had my current alternator in for at least a year with no problems. -
okay, so i have not really figured this out yet
88pathoffroad replied to mikemike's topic in General Forums
You're not a hardass after all? -
I'd like one, but they're heavy and huge and take up room. Heh.
Totally different setups. The Calmini CL is steel stock welded together and the L&P is a stock CL with the jointed sections notched out and spherical bearings and sleeves welded in.
Mine takes 80-90 gear oil for the t-case. Says so in the FSM. It depends on the year, not which transmission you have.
I have the same CB, a Uniden Pro 520XL. Mine's stuck to the underside of the dash under the stereo cause I have the short dash with no cubbyhole underneath. There is a resistor you can pop out of the circuit board for "more power", but IMHO it didn't do a damn thing for mine and I have no assurance that it didn't actually hurt performance either. 4 watts is the legal limit unless you want to hook up a linear or stereo amp for some REAL heat. Google it sometime. You don't want to drill a hole in your roof for an antenna, it'll bend the hole and waller it out in rapid order after you go through a few drive-throughs or parking garages. Then it'll leak and you'll have a caved-in hole and a floppy antenna. Do you have the spare tire carrier? Bolt it onto that and run a short ground wire to the body. Make sure your body grounds at the battery are good and it should be allright. The L-bracket on the edge of the hood works very well also. Mine is on my roof rack.
Oh man.... Flares First aid kit Fire extinguisher MRE's Spare belts(alt and PS) An extra blanket Gallon of water 3-D cell Mag light Signalling mirror Fire starter(magnesium/flint type) Jumper cables Shorty shovel Air compressor or C02 tank Tire plug/flat repair kit Ratchet straps Oil, antifreeze and trans fluid Belt dressing WD-40 Clean rags Leather gloves ROLL OF TP Lots of recovery stuff, 3" tow strap, 2" tow strap, couple of tree straps, shackles, clevises, a half-ton comealong, etc 100' of 1/4" yellow rope 20' of 3/8" yellow rope Bolts, washers, tape, wire, tie rod ends, the list goes on. The back end is packed. Heh.
Drop the front diff as a whole, crossmember and all. The oilpan will hit it and make it a real PITA on the way out.
How's your steering? A shot CL and tie rods or idler arm would make it pull one way or the other in 4WD.
Most likely a CV, but it sounds like you need some steering parts too.
That info is on the build/ID tag under the hood on the passenger's side. There's a code for build info on the second line down (I think), starts with a WHLYD21. From the FSM for 94... Model: 95 Pathfinder Wagon, Automatic transmission, V6 engine, non-California Emissions. XE: WHLYD21DJKBU SE: WHLYD21DPKBU LE not shown.
Looking good, everyone. I can *try* to place code in the appropriate places, but the IPB software is really funky, it splits each HTML section up into variables and makes you edit them singly instead of all at once as a page. Some sections only have two lines in each. Anyway...I'm glad you're all having fun working things out!
Wanted: FRONT DRIVER'S SIDE WINDOW LIFT MOTOR
88pathoffroad replied to hookemdevils22's topic in General Forums
Dude, that was uncalled for. Vent somewhere else, please. -
Pathy locking torque converter vs modern
88pathoffroad replied to gxl90rx7's topic in General Forums
It's annoying but normal. The difference between an 06 Ford and a 92 Nissan is HUGE. -
Here's a MSPaint version of your paint idea on mine. *snic* With and without the black hood. How's that?
They went from 27 spline in 87-89's, to 28 spline in 90+. Unless you're outside the US and have a 4-cylinder 4WD.
I scaled it down to 1000 wide. How's that? I know lots of laptops max out at 800x600, but most people have at least a 17" monitor nowadays running at least 1152x864 or so. Ideas?
I love the TOTM banner, too. Maybe the whole thing could be scaled down in size a skosh to save bandwidth? And maybe include more TOTM winners too cause I'm in there somewhere....years ago....can't remember...so far back...
There's a fuse for that. Mine's labeled "Clock/Room Lamp".
how do you remove frozen exhaust studs
88pathoffroad replied to dtom4's topic in 96-2004 R50 Pathfinders
Not having a pic of the aforementioned setup in front of me doesn't help, but could you drill the old ones out, re-tap and install studs? Individual taps are pretty affordable and studs are too. -
Bell Housing Area Threaded Bolts
88pathoffroad replied to BLouisGod's topic in 90-95 WD21 Pathfinders
The other 8 bolts should keep it from rattling, perhaps your rattle is coming from another source. Check everything underneath, get under there! IIRC, they're 14mm x 1.5 thread pitch. I can doublecheck if you need the info. -
Google it...there's more than one description on how to bleed brakes out there.
