gxl90rx7
About gxl90rx7
- Birthday 03/01/1981
1992 Pathfinder XE 4WD Sport package w/LSD US Wheel 84 15x8 wheels, 4.75" backspace 31x10.5 BFG A/T tires Warn Premium manual hubs Aux trans cooler Class 3 hitch
1992
Contact Methods
AIM
gtu89rx7
Website URL
http://www.geocities.com/gtu89rx7/
ICQ
Charleston, SC
Interests
RX-7, rotaries, Pathfinder
gxl90rx7's Achievements
NPORA Regular (2/5)
nice.. i got stuck on my first outing with the pathfinder too haha Thats when i found out my auto hubs were not locking, so all i had was 2wd
If it is idle rough on startup, its probably not your o2 sensor, since the o2 usually has to be warmed up to work anyway. but yeah, i bought a new o2 with the intention of replacing the old one, but when i saw that i would have to reroute it all the way back up to the connector... i still havent done it, been putting it off
When im sitting in traffic, ive been smelling this burning oil smell, but it actually smells a lot like burning popcorn. I started noticing it a couple months after i bought it, its been happening for about a year now. No oil leaks, engine temps normal, tranny oil temps normal (aftermarket temp gauge), drives perfect and no other problems i can tell. any ideas? could it be just oil near the the exhaust manifold where it may be leaking from the oil filter?
its not stealing members, since its not about pathfinders. sounds like a good idea, will check it out **EDIT: From the original "A VG Community" Topic
the less backspacing you have, the further your wheels will stick out, the more it will rub on the fender flares. I have 15x8 with stock backspacing (4.75") and 31" tires, no lift, and it doesnt rub any after trimming the flares a little
EL Pathfindero May have died again
gxl90rx7 replied to El Pathfindero's topic in 90-95 WD21 Pathfinders
i would just fix it/get it fixed if i were you. if you buy another pathy, you never know what may break next with it. if you get yours fixed, you know that that part *should* be good for the next 100k or so. I always opt for fix than replace (for the same price or less), cause whenever you fix something, you just make your vehicle that much more reliable, vs buying another person's problem -
are you talking about removing teh air filter assy? if you remove it and put a cone filter instead, it will probably lose power because it will be sucking in hot engine bay air instead of cool fenderwell air.
your maf will compensate for it, hence 'mass airflow sensor'
thats how i did it, i pushed on a scale to feel what 22 lbs felt like, then pushed the same amount down on the belt, and adjusted the tension for 15mm
NY to Florida to NY to Arizona in the 95 Pathy
gxl90rx7 replied to John Boy's topic in General Forums
running higher than recommended octane will in no way clean out deposits.. the definition of octane rating is the 'to resist detonation or pre-ignition (knock).' Which usually means less ability of the fuel to burn completely. Which means, a lot of unburnt fuel will be left after the combustion cycle, leaving carbon deposits, etc. im surprised you noticed better fuel economy with 94 oct vs recommended. sure, higher octane has more energy content, but is usually canceled out by its resistance to combustion here is a good article that explains it: http://www.answers.com/topic/octane-rating-1 sorry bout the thread hijack -
I would do a full tuneup first, timing belt, fuel filter, air filter, o2 sensor, plugs&wires, all fluids changed, etc. then an external tranny cooler i wouldnt worry about performance mods until all the reliability mods/maintenance have been taken care of manual locking hubs are another common upgrade, as the stock auto-locking hubs break pretty easily. If only one side is broken, your whole front axle will be useless in 4x4
I just changed my t-belt last weekend. mine had no mark on the crank gear either, what i did is count the ribs on the belt. 40 between the marks on the 2 cam gears, 43 between the marks on the driver's side cam gear and the crank gear. The other problem i had was tightening the crank bolt. pretty much impossible to do on an auto without a impact gun, ill probably drive it to a shop to get fully tightened. an easy way to loosen it is put a breaker bar on it, tie it up somewhere next to the frame on the pass side, and give the engine a quick turn with the starter, lol. kinda risky if the breaker bar gets loose, but it gets the job done if you do it right, and is a hell of a lot easier than taking the starter off and jamming the flywheel. and i also found out my t-stat housing is stripped out on the far bolt-hole, so its impossible to tighten down all the way. I RTV'd it to hell and back, hopefully it wont leak
one of mine is missing too. i think we have a cowl thief on our hands
just so you know, running premium fuel will not help burn out engine gunk, if anything, it will leave carbon deposits from the unburnt fuel. higher octane fuel is designed to not burn well for high compression/forced inducted engines to prevent pre-ignition.. 87 is best for our pathys (unless your turbo'd or running high compression crankshaft or something) good luck on your trip back, dont sell it!! but yeah interstate driving is not the best for mine, i usually have it floored just to keep up with traffic on the uphills at 80 mph! -
one of my friends was over in san diego for a business trip, and he wasnt really used to the area, nor the fast-paced traffic. he told me he was driving along on the interstate, trying to follow directions to his destination, and quickly attracted a tailgater.. there was a lot of traffic, my friend was in the middle lane, tailgater right behind. everyone started slowing down in front of him, but still going at a good pace, probably 50-60mph. well tailgater didnt like the idea of slowing down more than he had already, so he pulled into the left lane to pass, accelerator to the floor. Unknownst to the tailgater, the traffic was slowing for a stalled car in the left lane . My friend said the car came up beside him, looked over and frowned as he realized his imminent doom.. the next thing he said happend in slow motion - tires screeching followed by the tailgator plowing head first right into the stalled car, glass and other assorted car parts flying across the windshield of my friend's rental car as he passed by, haha he was freaked out, he thought the guy must have died or at least injured really bad lol, but never stopped to find out
