45
Where do you see the EGR valve that it says for CA? I looked earlier on rockauto.com and the only difference I see between the 2 they have is one says for automatic trans the other for manual trans?
sounds good, let us know what you discover
26 MPG is very high, 17 is normal so I've been told, I just figured out the MPG in my 94 and got 16.3 and 16.49. What part did you feel? The rusty part in my pic or the silver part where the sensor is? Pics are always good if you can take them.
RPM Gauge is stuck at 3000 RPMS
ahardb0dy replied to PitBullGirl23's topic in 90-95 WD21 Pathfinders
Is that the final word on that? -
You may not see the EGR temp sensor (or a black wire) and that is why you are getting the code. Do you see a plug on the bottom of your EGR where the sensor would go? The plug may be tucked up away and not where mine is shown, I think mine was tied up out of the way but the plug was in the general area.
Your welcome !
probably they go together, The line running along the firewall, does your truck have cruise? It may go to the cruise pump that is mounted in the pass. rear corner under the hood,
the plug wires that go thru the manifold and the one that is all the way in the back can be hard to get on the plugs, when the engine is running can you hear what sounds like an arching noise? If so than one of the wires is not on the plug and the spark is arching against metal.
i looked at mine
These are the choices mine gives me when I open it in regards to the different areas covered:
You can't buy it, it is the program Nissan uses in their parts Dept, once in a while you will find someone who has it and is hosting it for download, I have it but it is a very large file, multiple files actually, if you search online you may find someone that has it. Than setting it up can be difficult as well, there are different versions available, the one I have does, the US, Canada, European, as well as Infiniti vehicles try here, don't know if these links are still good or not: http://www.nissanforums.com/general-discussion/92323-nissan-fast-software.html
Welcome
I wrote up how to post pictures, well the way I do it, you can read it here, with step by step instructions and pics: http://www.nissanpathfinders.net/forum/topic/20781-how-to-post-a-photo/page-3
make sure to post pics as you build it
don't know if it is different but the beergarage one was a 2wd
found another one but it looks to be the same one
This one?
they all say "D21" for the model, it's the first digit that is the difference between the pathfinder and pickups
I think that package 33 which is the sports pack for the "SE" so it may be different on an "XE"
here is the chart based on your production date, see it jumps from 31 to 33 for some reason??:
from the pic of your rear axle it looks like the sticker was there. Yeah your Vin number said it has the V/S package of 36 which includes package 32, but there was no listing for the 32 package in the production date range that I have to look at that the production date of your truck would fall into. there are different charts that show the packages based on the production dates, the first one says "up to August 1989" than "August 1989 to July 1990", than "July 1990 to July 1991", than "July 1991 to July 1992" where yours falls into, and than "July 1992 to July 1993" and lastly "from July 1993"
It says your truck has the sports pack, this is what the sports pack should have, does your pathfinder have any of these opions? if so than it may have the LSD: SPORT PACK CONTAINS, (SUNROOF, ALLOY WHEEL, 31-10.50R15 TIRES, REAR SPARE TIRE HANGER, ADJUSTABLE SHOCK ABSORBERS, LIMITED SLIP DIFF, REAR DISC BRAKES)
Don't think your truck has the LSD based on the info from your vin, here it is: MODEL NUMBER = WHLYD21DJFBU36 DECODED BELOW: W = WAGON H = VG30 ENGINE L = LEFT HAND DRIVE Y = 4WD SHORT BODY D21 = MODEL D = 4 DOOR J = XE TRIM F = 5 SPEED FLOOR SHIFT MANUAL TRANSMISSION B = EGI U = FEDERAL 36 = V/S SYMBOL FOR PACKAGES 36 = V/S SYMBOL - 32 AND SPORT PACK FOR XE 32 = DOES NOT COME UP FROM PROD DATE JULY 1990 TO JULY 1991 THIS IS WHAT NUMBER 32 MEANS BEFORE JULY 91 PRODUCTION 32= 30 AND POWER PACK (POWER WINDOW AUTO DOOR LOCK, ELECTRIC OUTSIDE MIRROR) 30 = AM/FM 4 SPEAKER ELECTRIC CASSETTE RADIO
Your missing a number between the Y and the N I see you found it one second
Everyone I've seen on here that has asked about LSD, has found the sticker. You can also see if you have it by looking at the options when decoding the Vin number, which I can do if you wanted to see what the truck originally came with.
