yozsi
Everything posted by yozsi
not really, maybe just a different flange on the t/c side and/or sortening/lengthening the driveshaft.
hope you got the 2 lower brackets also.
no, gl-5 contains sulfur, a lubrication additive. Our syncro's are made with brass and/or bronze, sulfur corrodes and eats away at bronze.
from 0-infinity and beyond. no seriously.... you could get alot of miles outta one. it all depends on .... well everything. i got almost 200k on my original 5 speed and its like new.
this is so full of @!*% it aint funny. what kinda idiot would actually thinks this would work. hahaha, yea like all of your window seals, and door panels would hold any sort of air pressure.hah!
i tighten bolts to what feels good, after working on cars and trucks my whole life i kinda know the feel.
put a halogen light under your car over night with the hood closed. that should do er'
i started wheeling in my 87 subaru gl-10 turbo 4wd wagon. i ended up lifting it a good 3 inches and put LT's on it. man, i could get through anything with that bitch. i would always pullout heep wranglers and cherocars. they hated me. but one day the fricken hood insulation fell off the hood and went on the turbo and sorta lit the whole engine conpartment on fire. that was the end of that car.
aint no throwout bearing noise, that only makes noise when the pedal is depressed. i would say that the counter shaft bearing is shot, drain the fluid and refill with 5 qts.
sounds like the thorleys are warped all to hell, put a straight edge up the the flange and see if they are warped.
Southwest Auto Salvage USA-IL(Lockport) E-mail 1-888-539-0598 / 1-815-723-6878- those guys have one for 60 bucks.
pull the hose off of the booster and plug it, see if that helps. if it does than the diaphram on the booster is busted.
yea about 4 quarts with the filter.
aint nothing nissan bout that thing.
the starter solenoid is known to go on these cars because the damn oil filter unloads right on it, also the starter relay is a known culprit.
yep, its called 4lo, you get double the tourqe with the simple move of the lever!
for diesels? what does it call for? in my cummins i like mobil delvac, chevron delo 400, and shell rotella is okay.
@!*%, i have welded with my battery more than a few times, a couple 7018 sticks and a set of jumpercables work well.
if i was to go with a i-6 i would go with a 6bt. same motor as my dodge, man that would be awesome. the only problem is that the motor weighs 1800 pounds. lol
Sigh, what got knocked loose this time?
yozsi replied to VW_Factor's topic in 90-95 WD21 Pathfinders
take my advice and check the damn injector dwell. -
alright man, if you shot some carb cleaner in the intake and it started that means the ign system is probably working. you are looking at a fuel problem. no injector dwell/not enough fuel pressure. hook a dwell light or a small lamp up to one of the injector plugs to test injecotr dwell or listen to an injector with a stethescope. if thats fine test your fuel pressure. throwing money at it is for ghey dudes. stay away from that crap. -
shoot some carb cleaner in the intake just to make sure your not getting fuel. -
i'd rather r&r the clutch than rebuild an elecro-hydraulic tranny.
so when we gonna do a meet?
