Tungsten
Everything posted by Tungsten
  1. I'm wondering about the oil pan seal and the drain plug. The oil pan gasket can leak sometimes and a free fix is to torque the bolts.
  2. Good call on the wires. An exhaust leak will cause bogging because the oxygen sensor will pick up an incorrect reading.
  3. Just one advice. If you are going to use polyurethane bushings they will give you a much harsher but stiffer ride. Also they wear faster. I have tried both rubber and poly bushings. The rubber ones last longer and have a better ride. The poly ones don't last as long but are stiffer if you want that. I have mixed opinions on using poly vs rubber on the strut rod bushings. You want them stiff but at the same time you want them to last long and not throw the alignment off. I currently run aftermarket rubber ones there and they seem to be fine. Just use factory sleeves because they fit over the strut rod better.
  4. I made the map light come on with the dome light instead of the luggage light. Just a personal preference. You can just add a ground wire from the dome light to the luggage light if you want the luggage light to come on with the dome light.
  5. There is one big difference between the two. The automatic has a different variable length intake manifold with power valves while the manual has a regular intake manifold.
  6. The most accurate reading for the coolant temperature is acquired from the upper coolant neck on the return line. This is where you have 2 of the temperature sensors. One for the ECU and one for the dash cluster. I have used the dash cluster sensor for my fan controller when I did the E-fan swap.
  7. You can switch to a carb and there's even a member here (Mr.510) that sells adapters to attach Holley carbs. It would make everything simpler but the fuel economy might go down a little. Mine used to bog like that when I had a bad oxygen sensor. Try disconnecting that and see what happens. Make sure you also don't have an exhaust leak.
  8. I don't know how they are like on the R50 but the fog lights on antique Pathfinders are real fog lights. They have the correct bulb and pattern. Some people swap out the fog lights for driving lights or install driving lights if the fog lights are not there. I personally don't like that because it gives the illusion of safety and does not make you really focus on what is up ahead. People do this mod because the factory sad eye headlights are almost inadequate for use at night. Using the lower fog lights on the R50 as DRL is not a bad idea but DRL lights don't need to be bright in the first place. On WD21s the factory DRLs for places that require them are high beams that are run at half the brightness (or about 32.5 watts). Also running fog lights without running the headlights is actually illegal in some states which is why Nissan makes the fog lights turn on with low beams from factory. You want to check with your local laws on that.
  9. I'm not even sure the factory pre-historic ECU is going to be able to cope with a modern DOHC system. A donor truck with the engine would be the way to go.
  10. Unplug the sensor then so that it does not pick up the leak. It's not the best solution but should be good until you fix the source of the leak.
  11. The VQ and VG are actually directly interchangeable. You might run into some fun with wiring for the computer though.
  12. Doing a hardbody light conversion with grille. Lets see how much brighter these IPF 820H housings are.
  13. Sounds like a MAF sensor issue to me. Could be that or the oxygen sensor. Do you get a code?
  14. Alright if you're happy with it I guess it's good. Remember the job of fog lights is to light up the corners of the road, it is not to compliment the headlights. Even basic filament bulbs work just fine. HIDs are not a good idea for fog lights because they are not ideal for bad weather driving at all.
  15. There might be a special way you have to cure it in order for it to be actually flame proof. I haven't used VHT Flameproof but I have used other VHT high temp paints and they work great. I painted my bumpers with matte VHT roll bar paint and it looks great just like original.
  16. Yes, it will most definitely run improperly if there is a leak before the oxygen sensor. You are better off unplugging the sensor and running the default mapping. I suppose you have the stock exhaust right?
  17. You select them by the wattage and not by the color. Clear is the best "color" to choose. Just pick ones that are higher watts but make sure the filament orientation is the same.
  18. I'm surprised that nobody also suggested a KA24 motor. It was factory equipment for these truck platforms on certain models.
  19. I would stay away from any tinted bulbs because they are junk. Tinting the bulb does nothing but limit its output.
  20. I have this crazy idea of sticking zinc wire along the frame. The chemistry makes sense so in theory it should work.
  21. Theoretically it should have slightly more compression after shaving the heads. I don't know how much was shaved but that can impact the timing too.
  22. Gates all the way. They have superior v-belts to Nissan's own Bando stuff.
  23. Yep that's it! Had a brain fart... Those damn logos are so identical it must have got mixed up in my head.
  24. The fuse for the dash is called METER. There is also another one labelled ROOM LAMP. You would be surprised just how much stuff is wired through those. Take a look at both of those.
  25. Yes it will physically fit into the hole but you will need to do some slight re-wiring and I think the voltage regulator is inside the ECU on the newer one instead of the top of the cluster. Going from a newer to an older should be easier than going from an older to a newer.
