86
First thing I suggest would be to review this thread and see of you have similar symptoms, this may be your issue and fix...
1st Gen Factory Chrome Roof Rack in Parts Forum
RedPath88 replied to Grego92's topic in 86.5-89 WD21 Pathfinders
Your are correct about deletion... in this instance I'll just lock this thread. But, given that new/recent threads are already given attention in the sidebar, as this post was as well, please refrain from doing this in the future. ? -
AC wont turn on, any common thing I should check?
RedPath88 replied to DonutHands's topic in 96-2004 R50 Pathfinders
Building off of @Slartibartfast, I would lean towards low pressure... in my personal experience, that has always been the issue, on multiple vehicles, but YMMV. As for the light, in my '88 (not sure about '97s) the light does not turn on unless the clutch is electrically engaged. Meaning no light if the system pressure is below the pressure switches minimum threshhoold. -
Yesterday: Jumped my neighbors van after he left his dome light on all night. After parking and locking the Pathy back up I noticed smoke coming from under the hood. Popped it and found that where there is smoke, there is fire! On the RH side of the intake manifold next to the TB. Today: Replaced all the soft fuel lines from the frame rail to the TB. Problem solved
As far as I can remember it was in regard to the instance I mentioned above, which was quite a few years ago. Have you called or emailed SuperLift about it?
Yeah the Calmini and SL/RC arms all correct ball joint angles as part of their design, AC are the only ones that do not. But that said said many have reported no alignment issues, with our own @5523Pathfinder being one of them.
Looks good! Just adding the following context for other members... People have reported in the past that Calmini UCA's has had, iirc, premature bushing wear issues and AC UCA's have given many alignment problems. Neither of these are across the board,but the numbers were high enough to be a consideration. My personal recommendation, and what I run, is SuperLift/Rough Country D21 UCA's. Superlift manufactures them and the difference is only in the coating, nickel on SL & a rough textured powder coat on RC. The only complaint about them that I can recall was a bad production run that left their inner mounts out of alignment. Once the issue had been identified, it was corrected and affected units were replaced with just a call. I originally bought RC branded arms, and SL quickly replaced them with SL versions. This issue is documented here on the forum. If they are still available, assuming they still make and sell in the same way, they come as a package lift for 4x4 Hardbody's (with rear blocks) only and are not available for a Pathfinder. However, they are equally compatible with all WD21 pathfinders as they use the same front suspension as the 4WD HB's The way to get just the arms years ago was to call RC and request just the arms (with bushing/accessories) and to not tell them that they were for a WD21. Some have said that they don't do this anymore, while I believe some have got them. So I can't say if you can still get a set or not. But I can say that how you spoke to them, perhaps even who you spoke to, back when many people were buying them directly from Rough Country, effected your success.
Please welcome mjotrainbrain as an NPORA Forum Moderator
RedPath88 replied to RedPath88's topic in NPORA Announcements
Careful, you might inadvertently summon the v"6" -
I recall nothing of the sort! -
96 model v6 no spark or injector pulse
RedPath88 replied to Pathy1996's topic in 96-2004 R50 Pathfinders
Welcome to NPORA Forums Pathy1996! I've moved your post to the R50 section to try and give it more exposure. Consider making a new post in the new members section to introduce yourself. -
Forum was offline for less than 60 seconds for a minor software update.
Does it work well for you? Have you had any problems and would you do anything differently if done again? BTW there's no issue with reviving old posts. Honestly it helps keep related info together
It's been quite insane, 'cuz, ya know, every1 needz der internetz!!! Only if you never visit the NPORA Home Page
You are correct, but it's been a long while since I've updated and added new ones. May still be a bit, I'll try and let you know when I start doing it once again. Also, I see you sent a PM a while ago. My apologies for not responding, I honestly didn't even see it as I have been slammed at work during the shutdowns.
Replaced the alarm siren.
Good job! I am going to have to do this on my drivers door again to my 88. Seems the aftermarket pins did not last as long as the factory ones..
I'd give them a call, but as mentioned several times here on NPORA tell them you have a Hardbody and do not mention the word "Pathfinder" They used to be willing to sell the arms separately and directly. If they still offer them (probably in a leaf sprung Hardbody kit) they may still sell them alone if you ask nicely *don't forget to ask for the bushings and hardware as well! If not, then as @FirstGenFreak mentioned, you can go with Superlift arms (same thing, different finish)
That's what I figured you were talking about. An Xterra rack, people have been putting them on WD21's for a long time now. I actually have one in the garage that I have never got around to installing. It's meant to replace the S10 rack I originally installed, and currently still have, on my '88.
Installed new hatch struts Which truck?
Simple but efficient OBDII IPhone adaptable code reader?
RedPath88 replied to MTGunner's topic in 96-2004 R50 Pathfinders
I bought a cheap Bluetooth adapter years ago and used Torque (as mentioned above by @jjmwilkinson) Still use both of them to this day. It's proven to be very reliable and great for basic OBDII code reading. In addition to giving real-time information. The Adapter is actually plugged into my cars OBDII port full time. but note that I use these with Android, so YMMV. I remember when I was researching these things that iOS had compatibility issues with BT devices IIRC.. wasn't my focus so I don't remember exactly. But I see the one linked by @XPLORx4 uses WiFi, his word is good enough to trust in it, but if you look at other devices do your research to make sure they will work with your iOS version and device. -
Ditto, though I need to replace the entire exhaust system, which I have in the garage minus one minor custom coupling requirement, it still starts first on the first turn if they key. I kinda feel bad for only calling upon its services now and then lately. It's easy to just stick with the norm and drive the same vehicle, in this case the Lincoln, regularly. As such, I've decided to rotate more regularly between the two. Granted, we're only talking 4.4 miles per day between home and the company vehicle, on days I don't simply work from home. Plus what little I do on weekends, but it's something nonetheless.
Drove it, as I have a more often than not over the past couple weeks.
