RedPath88
Admin
  1. But then you spin the other three the wrong way -thnkboutit- BTW SS nice looking tires.. any mounted pics yet?
  2. Maybe you just ogt a bad filter. Never heard of such a thing but who knows... I guess it is possible for the filter paper to have not been manufactured correctly and not be allowing proper air flow
  3. Yeah, last we heard you were abandoning it
  4. Perhaps your wheel bearings are in need of replacement... or he figured it was a good time to do it, to prevent future failure... or he was just trying to suck every bit out of this job
  5. I am guessing in or around Parker, Idaho (Based on snosnk's location info in his profile)
  6. Looks good Mr P. FUELER, iirc he picked them up off of ebay from a local guy... so yeah, deal plus no shipping
  7. He stacked lifts Trailmaster 4in lift kit (diff drop) This kit is available through AC, that might explain why he called it "AC's 4in lift kit" Aftermarket UCA with Torsion Bars cranked 2.5in (Torsion bars were also replaced with aftermarket units) 4in rear coils spacers included with Trailmaster lift kit + replacement 3in lift coils. Perhaps it gave 6in once everything settled. Or are the Trailmaster spacers 3in? As many lifts provide leveling (aka an average of 1in less lift in the rear)
  8. A quick search for "Filter" targeted at 88's posts brought this right up Larger oil filter, For your VG30 engine According to 88, it is a GM filter that you will need to use on the Nissan block
  9. "Federal" means that it complies with emissions regulations required for a new vehicle to be sold anywhere in the United States, except for California. A "Federal Pipe" would simply be a straight through pipe that does not accommodate a "PreCat" it is what you would find on most Pathfinders out there (those not sold new in Cali) Call me crazy but I would shop around I had a new muffler and " Hi Flow" Cat put on for less than that. You might be able to find one in good shape at a wrecking yard... I have found entire exhaust systems there before, just takes some looking. It would appear that you have a little time to look
  10. Cool... good job A lot of money can be saved if you have the right tools to make things... now if I can only find a decently priced used welder
  11. Perhaps the key to this working is that the driver must use the people version first
  12. Seems like the symbol you are describing is that of a "Power" or "Reset" button on a PC or other electronic device. If I remember correctly my 88's Interlock switch is labeled as "Interlock" but I may be wrong.. I'll check in a little while
  13. Is this the one you are looking for? Calmini or Rancho?
  14. ATF (Automatic Transmission Fluid) DEXRON type
  15. I thought about just trimming the tires sidewall... but the sandpaper is a much better idea
  16. Look into turning that AC into an onboard air compressor... well if you think that it is something you would use I have most of the parts needed to add that to my Yota... (only major things I need now are a regulator and pressure switch) Though I am not sure how strong of an air pump a Nissan AC Comp. will make... some AC units work well, others not so good
  17. Yeah have the alignment checked again... popular opinion is that most shops can't seem to do a Nissan Truck alingment correctly
  18. Mechman2K made it for me (I painted it), it's does the job but as 88 I am sure, will point out, it has it's flaws... Something I plan to address if I ever find a deal on a welder
  19. Don't know if it exists, but that was where it was planned.
  20. Looks like he is just about in need of some new shoes
  21. hmm will they price match a printed out sale price? Or can you order online and pick up locally? Tax.. that's a B***H... deal with that all the time. Randy's Ring & Pinion offered me an awesome deal on a locker for the yota (willing to work one up for the Pathy too) a couple weeks ago, but with tax it was more than I could find else where
  22. One in Phoenix and Mesa... there ya go Dan
  23. I have only bought once from them.. the shocks for the Pathy ...which I had no issues with. *well they did send the wrong SS, but that was likely because I may not have been clear enough... I order Pathy fronts and Yota rears, they sent a Yota SS I did not notice till a couple months later, by then to late... just gave it to a friend with a jeep.. since it also fit her year/model.
  24. ^^^What they said^^^ It has happened to some... and they either change them using the spares they carried, leave the truck and go get some replacements (while praying that the trucks in one peice when they get back) or call a tow truck (how fat is your wallet?)
