SC88Pathy
Everything posted by SC88Pathy
As everyone has said 31's should fit just fine. You might have to adjust the torsion bars a little but that is a very simple procedure that anyone who knows how to turn a wrench could do. See my sig for a pic of a pathy on 31's. I have my t-bars adjusted a little so that the front rides even with the back.
Yah us Nor-Cal folk have tried to arrange meets a couple of times but then it all falls apart at the last minute. I'm thinking of arranging a trail run in the near future. But it all depends on what the verdict is on the status of my transmission when I get it serviced tomorrow. I'd be down to do something during the summer as well, as long as it isn't too far of a drive (gas is getting expensive!)
DAYUM! And I'm pissed about having to spend $280 to get my AT serviced! :o
Ohh where'd you get that bitchin billet grill?
Effect of window tint on factory privacy glass
SC88Pathy replied to ntwrkguy1's topic in General Forums
Don't look too closely at my tint or you'll notice that the drivers side triangle has purple tint while the rest are light black. The PO was broke into and I guess the replacement glass place could only find purple tint. -
Wow aren't the cops all over you for the front window tint? Up here if you have ANY tint on the driver/passenger windows the cops will write you a fix it ticket SO fast! -
No not if you know where to shop... http://www.tirerack.com/tires/tires.jsp?ti...re1=yes&place=0 About $100 each after shipping for those AT's http://www.tirerack.com/tires/tires.jsp?ti...re1=yes&place=5 Or about $112 after shipping for those AT's (those are the one's I think I'm gunna get when I next need tires)
OH! Swap in an SR20DET!!!!! There's some POWER for ya!
Hmm I can't remember when did they switch from the Z24 to the KA24? I'm assuming that it must have been before 93 cause AFAIK the Z24's have timing chains. If it does have the KA there are a lot of ricer parts for that engine that will probably make it even more powerfull than the VG30. :cool2:
Well when you try and spray the rear window do you hear a pump working? If not then the pump needs to be replaced (yes they are seperate units I'm pretty sure.) If you do hear a pump working then the lines might be clogged, start out by checking at the rear sprayer itself. Mine often clogs up, I'v found a needle is the best way to unclog the nozzles.
Cross drilled brake lines?
No that shoulda worked you just made a mistake in the address: "http://http//i33.photobucket.com/albums/d73/navygz19/Dsc01078.jpg" You forgot to delete the "http://" that is auto inserted on the IMG button dialogue box. If you insert the proper address it should look like:
Well I'll be dipped I never noticed that before. Trainman is right the box that says IMG on photobucket is all you need to copy. Then paste it in to your post. Thanks for pointing that out trainman!
OK so you uploaded your pictures to photobucket. Next step is to copy the URL that is under the picture you want to post. Now create a new post here. At the top of where you type there are a bunch of buttons. Click the one that says IMG. Now a pop up box should appear that says enter the complete URL for the image. Paste the URL you copied from photobucket and ta-da you should have a picture in your post, like so:
I'm planning on taking mine off over spring break, along with a lot of other work that needs to be done (install second tow hook, make gap gaurds, get pathy smogged, get AT fluid flushed, then hopefully go play! -bounce- ) I'm fairly certain that I won't get a ticket, I see all kinds of yotas running around with aftermarket tires sticking way out and they never seem to have any trouble from the cops...
Hmm I just searched around my room and dug out my crutchfield install guide, unfortunatly it is only for 87-93 pathys. However I'm fairly certain that one of those connectors is for the diversity antenna. Crutchfield's instructions say that a diversity tuning adaptor is needed, says to contact Crutchfield if an adaptor wasn't supplied. Of course if you didn't buy your head unit from crutchfield I'm sure that they'll be willing to sell you one for a decent price.
LMAO! "Clean up on aisle 5"
I just put my drinks in the center console. Most drinks fit perfect to prevent side to side motion, but back and forth movement is an issue, I have my cell phone charger stuffed behind it that usually prevents any movement back and forth.
I can understand the difference in ride MWS but reduced tire life? Seems to me if he gets all the suspension geometries correct and everything is properly aligned tire life shouldn't be too different. :confused:
Don't forget to put the air system on recycle so that critters don't crawl in and make home in the air ducting! Otherwise you might end up writing "The Great Mouse Saga: Vol. 2"
Glad to hear you're healing up! Hopefully feeling will return to your arm soon. Just think it could have been a LOT worse!
Spin them. And crank the steering wheel. -bounce-
OK before somebody much meaner than I comes in and plays whack a mole with you guys JGC I6 springs work just the same! Same part numbers and everything! http://www.nissanpathfinders.net/forum/index.php?showtopic=18 http://www.nissanpathfinders.net/forum/index.php?showtopic=7445 http://www.nissanpathfinders.net/forum/index.php?showtopic=7777 http://www.nissanpathfinders.net/forum/index.php?showtopic=7814 In the future please please please use the search function or simply just browse the site. These links were NOT hard to find.
Just wheels? Or wheels plus tires? $91 for 4 or $91 each? I know you said not legos but there's a set of 4 with tires on San Fran. Bay Area Craigslist going for $344. http://www.craigslist.org/sby/pts/139863787.html
I hope that was a camera phone or something, otherwise it might be time to get yourself a new digicam! If I had a spare $3000 I'd get it!
