SC88Pathy
Everything posted by SC88Pathy
  1. Wow! Why isn't that guy over here?! I want an SAS... :sniff:
  2. - Double the power output so you can get them moving Not double, but definatly headers intake and cams probably. - all new steering components to take the load Definatly, the complete L&P setup would work. - raising truck about 12" oughta just about do it... 10 inches would probably be fine... - All new driveline to handle the power Nah not neccesary, just don't tow anything. - New diffs/axles to handle power Definatly not neccesary, pathfinder axles are BUFF. CV's could probably handle it...
  3. Yup it's called binding, try not to make sharp turns when in 4x4.
  4. If you are looking for the "best bang for your buck" suspension lift it would be as follows: Rough Country Upper Control Arms (contact rough country directly and order the UCA's from the Hardbody truck lift kit), modified JGC springs for the rear, and new shocks all around (I'd suggest ranchos). I already mentioned this (minus the brands) in your intro thread. Prerunner style bumpers are available from www.4x4parts.com I don't think it would look very good but to each their own right? Oh and with the 3 inch lift you could run 32 inch tires.
  5. Oh I meant the 3 inch suspension plus the 3 inch body PLUS the 4 inch trailmaster. 33's are plenty big
  6. 35's won't fit with just 3 inches of suspension and 3 inches of body lift. They might fit if you also add the 4 inch trailmaster kit, maybe. They'll definatly fit if you do a solid axle swap! Also the chevy wheel might not fit because chevy hubs are much smaller than nissan hubs. You'll be best off finding 33's. (Desert rat www.desertrat.com is offering a package deal 4 interco LTB 33x13.5 r 15's mounted on black steel wheels for $715)
  7. Easier test, open hood on 90, open hood on 93. If everything looks the same both have VG30E engines. If the 90 engine looks different (IE it has a circular air cleaner directly on top of the engine) than it has a VG30I.
  8. Timing chain? You meant timing belt right? Chin up, maybe you'll win the lottery right?
  9. My dad had a 1996 (I think can't remember exact year...) 5 speed 4 cylinder 4x2 Ranger. The only problem he ever had with it was the door open sensor wouldn't recognize the door being shut which would cause the dome light to stay on. It also had 8 sparkplugs (and two distributers!), it weirded me out the first time I saw it. Started counting spark plugs and went WTF?! :confused:
  10. I'm averaging about 14.5 to 15 mpg. Around 250 miles per tank.
  11. Supposedly you can. However no active user has done this (apparenlty a now inactive member did it once).
  12. So you have. Um well then sticking up for the person with fewer posts I guess.
  13. Actually I meant pixel regulations like for the avatars. Also no offense meant Luker, just sticking up for the new guy.
  14. Hmm yah this is quite a dilemma. Between the two it seems like there is enough to make at least one road worthy vehicle, and maybe have enough left over for a dedicated trail rig... Either way you go you'v got a lot of work ahead of you. To answer your question yes there is a plethora of dash paints made for painting plastics. Should be available at most auto parts stores. I'm pretty sure DuPont makes it as well as some other well known companies.
  15. SC88Pathy
    Membership
    Last I heard Mr. Jim is having some very rough times, no computer, no internet access. Be patient eventually he will get back to you, once he gets his life in order...
  16. Eh don't listen to Luker he's complained about this before and he knows how to turn sig's off. We probably should have some sorta defined rules about sig pic size though... Oh yea and GO 2 DOOR PATHY'S!! -bounce-
  17. He's on an island, don't know how expansive the selection would be if they even have a J/Y BTW Whats the denomination is your currency over there DNO?
  18. Just tell them the truth, you were on a long trip and the trans broke during said trip and said trip also just put you over the mileage. Assuming you haven't put many miles on since then they could go out and verify this and should help you out. Of course they might just be asses and will tell you tough s@#$. Couldn't hurt to enquire though...
  19. Do you mean it's become kinda of a shiney bluish rainbow quality? That would be due to heat it changes the color... Although I reserve the right to change my opinion once I see the pictures.
  20. No I don't have the $$$ for L&P stuff right now :sniff: However 88pathoffroad (aka 88) has a lot of their stuff, you should ask him.
  21. K&N filter, $34 + shipping from summit racing. Thorley headers $350 + shipping from rocky road. Muffler depends on brand/style/sound you want. Flowmaster 40 series muffler will run you $70 + shipping from summit. Whereas a simple dynomax glasspack muffler will run you $22 + shipping also from summit. A high flow cat will be around $60 from summit. Unless you have some serious equipment laying around your garage you'll probably need a shop to install the exhaust system. Prices and labor will vary so shop around and don't just go with whoever's cheapest. Go with a shop that will do good work and will be willing to take their time to make the system work with your pathy.
  22. You lift the pathy as high as it can go! Go over the water not through it!
  23. Well I researched this earlier and the word from 88 is that it would be darn near impossible to completely seal the engine. I'm sure he'll wander in here eventually and remind me what would need to be done (I think it required welding something shut, can't remember what though...)
  24. Sorry luker, but 87-89 engines don't benefit from a snorkel (other than the cold air properties). Your best bet is a K&N filter, Thorley headers, a muffler, high flow cat, custom 2.5" exhaust piping, and the L&P Performance intake mods: http://www.lpperformance.com/Performance%20Services.htm
