Flysilly Posted June 14, 2016 Share Posted June 14, 2016 Hello - pretty sure my fuel pressure regulator is bad. But I can't find it! Where is it located? Thanks in advance. Link to comment Share on other sites More sharing options...
Slartibartfast Posted June 14, 2016 Share Posted June 14, 2016 Reach around the back of the upper intake manifold and you'll find a vacuum line leading down to the fuel pressure regulator. 1 Link to comment Share on other sites More sharing options...
NP670 Posted June 14, 2016 Share Posted June 14, 2016 Sent from my SM-N910T using Tapatalk 1 Link to comment Share on other sites More sharing options...
NP670 Posted June 14, 2016 Share Posted June 14, 2016 on the fuel rail Sent from my SM-N910T using Tapatalk 1 Link to comment Share on other sites More sharing options...
Flysilly Posted June 14, 2016 Author Share Posted June 14, 2016 Thanks, will go look again in the morning. Link to comment Share on other sites More sharing options...
SpecialWarr Posted June 14, 2016 Share Posted June 14, 2016 Bring a mirror because you can't see it from anywhere except by removing the upper intake plenum! Link to comment Share on other sites More sharing options...
Fast_eddy Posted June 17, 2016 Share Posted June 17, 2016 Far back right corner of the fuel rail. If you take the intake plenum off, take a pic for me! Trying to make sure I have these injectors connected in the right order right now on the drivers side... Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted June 18, 2016 Share Posted June 18, 2016 Far back right corner of the fuel rail. If you take the intake plenum off, take a pic for me! Trying to make sure I have these injectors connected in the right order right now on the drivers side...Just compare the wiring color and then you will know. That's what I had to do. Sent from my SAMSUNG-SM-N920A using Tapatalk Link to comment Share on other sites More sharing options...
gustycrosswinds Posted November 7, 2022 Share Posted November 7, 2022 is it possible to remove the regulator without taking off the intake manifold? Link to comment Share on other sites More sharing options...
Frenchy Posted November 8, 2022 Share Posted November 8, 2022 Its possible, just notfun Link to comment Share on other sites More sharing options...
adamzan Posted November 10, 2022 Share Posted November 10, 2022 Easier to just remove the plenum. It isn't that hard and your hands will thank you. Link to comment Share on other sites More sharing options...
gustycrosswinds Posted November 23, 2022 Share Posted November 23, 2022 has anyone verified if the fuel regulators on the 3.0 are different psi than the 3.3? i am looking up some parts on rockauto and they say the regulator is good from 1990-2000 for the pathfinder, which would cover both engines? Link to comment Share on other sites More sharing options...
adamzan Posted November 26, 2022 Share Posted November 26, 2022 I'm pretty sure they are the same for the VG30 and 33. You can also check nissan part numbers at courtesyparts.com. Link to comment Share on other sites More sharing options...
Frenchy Posted November 27, 2022 Share Posted November 27, 2022 Can't say if they will fit one another but I can say the pressure should be fine Link to comment Share on other sites More sharing options...
