CDN_S4 Posted April 23, 2015 Author Share Posted April 23, 2015 Ooooooo. Do tell. Which did you go with, and does this mean the unibody width for bumper mounts on face lifted R50s is the same? I saw theexbrit's write-up but wasn't sure if the widths are the same. I would think so. I've searched for his write-up and have had no success in finding it...any chance you could link it in here? Thanks Link to comment Share on other sites More sharing options...
hawairish Posted April 23, 2015 Share Posted April 23, 2015 Here you go! http://www.nissanpathfinders.net/forum/topic/36674-xj-cherokee-bumper-mod/?hl=%2Bcherokee+%2Bbumper While connecting some other dots, I saw that he indicates that the width for the XJ mounts are the same for his R50, while Precise1 noted in another thread that he put a brush guard for an older R50 onto his newer one (or maybe it was the other way around). In terms of mounting width, I interpret it as XJ = R50. I think you meant Rough Country for your bumper, right? P/N 1057? If so, it's what theexbrit got (linked in his thread). One major advantage to this particular bumper is that the mounting brackets are separate pieces. So even if the widths weren't the same, you could mount the brackets inside or outside of the tabs, and even use plate steel to adjust the width further (to an extent). Keep us posted! Link to comment Share on other sites More sharing options...
Beatup96 Posted April 23, 2015 Share Posted April 23, 2015 (edited) Can't figure out how to show Youtube , click here... Edited April 23, 2015 by Beatup96 1 Link to comment Share on other sites More sharing options...
Beatup96 Posted April 23, 2015 Share Posted April 23, 2015 Guess I figured it out ! 1 Link to comment Share on other sites More sharing options...
CDN_S4 Posted April 23, 2015 Author Share Posted April 23, 2015 Here you go! http://www.nissanpathfinders.net/forum/topic/36674-xj-cherokee-bumper-mod/?hl=%2Bcherokee+%2Bbumper I think you meant Rough Country for your bumper, right? P/N 1057? If so, it's what theexbrit got (linked in his thread). Thanks for that. Strange that I couldn't find it. Turns out I even posted in that thread. I suck! lol And yes, I meant Rough Country, not Rugged Ridge. Was looking at their winches just moments before. I will definitely take lots of pics and detail all the "issues" to make this thing fit. My fabricator guy is pretty good, so I'm kind of hopeful this will turn out real nice. That thread just reminded me that I'm going to have to relocate the windshield washer fluid. My front HD springs should arrive tomorrow, according to UPS, so hopefully on this rainy weekend, I'll get them installed without killing myself. I hate compressing springs. Link to comment Share on other sites More sharing options...
hawairish Posted April 23, 2015 Share Posted April 23, 2015 About the washer bottle...I know theexbrit mentioned that it would look pretty stupid hanging low, but it reminded me of those Calmini prototype pics that XPLORx4 posted long ago. On the pic of their front bumper, they just spray painted the thing. It still hung down, but was much less conspicuous. I'm sure it will be hanging down more with the RC bumper, but maybe explore that option? Link to comment Share on other sites More sharing options...
hawairish Posted April 23, 2015 Share Posted April 23, 2015 And hey, while you've got that bumper off still, mind taking some basic measurements? Maybe... 1. Full width 2. Distance between the outside of the mounting tabs (i.e., space between mounting tabs + 2x tab thickness) Link to comment Share on other sites More sharing options...
CDN_S4 Posted April 23, 2015 Author Share Posted April 23, 2015 Yeah I will see what options I'll have for the washer bottle. I'll cross that bridge when I get to it. I will make sure to take plenty of pics and measurements during the process. Link to comment Share on other sites More sharing options...
XPLORx4 Posted April 23, 2015 Share Posted April 23, 2015 https://www.flickr.com/photos/41184956@N08/sets/72157629989182681/ 1 Link to comment Share on other sites More sharing options...
CDN_S4 Posted April 25, 2015 Author Share Posted April 25, 2015 Front OME HD springs are in. Plus 2" spacer from Fleury still. Technically this should be close to 4" of lift. It doesn't really look like that much. It settled as soon as I test drove it. Compare before, right after and after test drive pics: Link to comment Share on other sites More sharing options...
Rebelord Posted April 25, 2015 Share Posted April 25, 2015 Man that still has some rack to it! I did OME HD and 1" spacer up front only. I drove 45 miles so far today. Settled some. But the truck is pretty level. Sent from fat fingers on S6 Link to comment Share on other sites More sharing options...
CDN_S4 Posted April 25, 2015 Author Share Posted April 25, 2015 I wonder if the spacers cause the springs to compress more? I am bit dissapointed in a way. At first it looked great, almost level and I was happy. But within minutes it settled into what you see in the last pic. In a way it's still good as it will be level when I tow and load it up, but once I add my jumper and winch, that will add another 150-200lbs up front. I need a SFD!!! Hawairish, I need you take make one for me lol. Link to comment Share on other sites More sharing options...
Rebelord Posted April 26, 2015 Share Posted April 26, 2015 You may be at you max limit. As the CVs and Tie rod ends will only allow the lower A arm to extend so far. Considering mine were at full droop and I only had to lift the lower assembly maybe a inch, if that to get the spindle to strut bolts in. What do your front CVs look like? \ instead of -- ? Link to comment Share on other sites More sharing options...
CDN_S4 Posted April 26, 2015 Author Share Posted April 26, 2015 You may be at you max limit. As the CVs and Tie rod ends will only allow the lower A arm to extend so far. Considering mine were at full droop and I only had to lift the lower assembly maybe a inch, if that to get the spindle to strut bolts in. What do your front CVs look like? \ instead of -- ? oh yes my CV's are like this very angled / I have no doubt I'm maxed out the suspension travel angles. Time to get a SFD. Might just have to get the Krypton kit if I want to make progress on this. Although I will run it like this for a bit and see it performs. I'm going on an organized 3 day trip in Maine end of May. A bunch of people from over on Expo are going on this. Mostly just gravel and back country dirt road travel. Link to comment Share on other sites More sharing options...
CDN_S4 Posted April 26, 2015 Author Share Posted April 26, 2015 Holy TOE!!!! Good thing I already orderd camber bolts 1 Link to comment Share on other sites More sharing options...
hawairish Posted April 26, 2015 Share Posted April 26, 2015 Holy TOE!!!! Good thing I already orderd camber bolts Yup, you need an SFD. Link to comment Share on other sites More sharing options...
CDN_S4 Posted April 26, 2015 Author Share Posted April 26, 2015 Yup, you need an SFD. And I need it fast!! I might get one fabbed up by my "guy". Only thing I'm not sure about how to do is the steering extension. Surely I can just reverse engineer the krypton kit. Link to comment Share on other sites More sharing options...
hawairish Posted April 26, 2015 Share Posted April 26, 2015 Did you get my PM? I won't be able to kit one for you before your trip, but I'll give you all the details you need. Link to comment Share on other sites More sharing options...
CDN_S4 Posted April 26, 2015 Author Share Posted April 26, 2015 Yes I got it. Thanks. As long as my camber bolts and an alignment can get me straightened out, then there won't be a big rush on the SFD but it will need to be done. Link to comment Share on other sites More sharing options...
Rebelord Posted April 26, 2015 Share Posted April 26, 2015 I'd be worried about your CVs Sent from fat fingers on S6 1 Link to comment Share on other sites More sharing options...
CDN_S4 Posted April 26, 2015 Author Share Posted April 26, 2015 I AM TOO!!! I'm actually more confused now about SFD's after checking out the krypton kit for info. I have apox 4" of lift all around, maybe 5 in the back, but the setup is the same. OME springs and 2" spacers all around. The SFD only requires front parts, so if I were to go with the 4" SFD, would I have to revert back to my Nissan springs? Otherwise I'm going to be sitting at 5-6" inches up front. I suppose I would have to lose the front strut spacers. But then again, the kit comes with strut spacers. This is where I get confused. Would I then be able to keep my suspension set up as is now, but drop the sub frame through spacers and a steering link extension only? Thanks Link to comment Share on other sites More sharing options...
hawairish Posted April 26, 2015 Share Posted April 26, 2015 Would I then be able to keep my suspension set up as is now, but drop the sub frame through spacers and a steering link extension only? Yes. You basically have three options: 1. KRFabs #1. Don't use the included strut spaces, but use the subframe/motor mount spacers and steering link. Keep existing OME springs and strut spacers. 2. KRFabs #2. Use entire kit and stock springs. Don't use OME springs or current strut spacers. 3. Custom SFD. Fab what you need, keep everything you currently have, for half what the KRFab kit costs. Keep in mind you'll still need to fab a spacer if you want to keep your purdy skid plates (#3 includes instructions on how to keep that and still under $250). I'm crafting a PM response with the details. Sit tight. 1 Link to comment Share on other sites More sharing options...
CDN_S4 Posted April 27, 2015 Author Share Posted April 27, 2015 This is what my CV joints look like. Far from straight but should I be concerned for DD? I'm not doing any serious off-road until I have the SFD installed. I do get the occasional "clunk" or "Pop" from the passenger front side. My sway bar bushings are pretty much toast so I attribute it to that. I'm just hoping it's not the CVs. Although I looked them up and they can be had for $100 a pop so not bad at all. Should they be changed anyway every 100.000km or so? Might just do them when I get the SFD. Link to comment Share on other sites More sharing options...
CDN_S4 Posted April 27, 2015 Author Share Posted April 27, 2015 Link to comment Share on other sites More sharing options...
Rebelord Posted April 27, 2015 Share Posted April 27, 2015 Doesn't look to bad. But could be the pic Sent from fat fingers on S6 1 Link to comment Share on other sites More sharing options...
