k9sar
Everything posted by k9sar
  1. k9sar
    Timing Belt
    daytime is definately best to do the work unless you have a well lit shop. Working on stuff like that in the driveway int he dark is a PITA.
  2. in my opinion, the best solution is to get a wiring diagram and snip your connectors. I got my CD player for 80 bucks or so whiel the one listed for my pathy was near 400. Only difference was the connectors. snip snip, a little solder, double check with my volt meter and we're good to go. If you go completely with an aftermarket (that has it's own amps internal), you'll want to completely bypass the stock amps and run the outputs directly to your speakers.
  3. k9sar
    Timing Belt
    shouldn't need any special tools unless you are taking the crank pully off (big-ass socket). Just make sure you mark your cam gear positions before pulling your old belt (and yes, they will creep when the tension is released). Flat scraper comes in handy removing the old water pump gasket. Keep track of the bolts as they are NOT all the same. Good luck. Come back and ask if you run into any issues, I'm sure someone in here would be glad to help.
  4. manual or auto? I had my reverse go out on me with my AT and it turned out I needed a tranny rebuild due to worn clutch discs and a failed pump. In an AT, the reverse gear operates at a higher pressure than the fwd gears so that is typically the first thing to go. If you have a manual... ignore my post
  5. I can't believe you haven't done a comp test yet... with all yer bitchin about failing smoggies and such.
  6. oh great... I almost shot Mt Dew out my nose reading that. gimme a candle, I think I have a fuel leak
  7. did you check your parking brake adjuster also? That could be holding your shoes out as well.
  8. nice. what kind of duration does it get off a full charge? I'm guessing that it's not something needed for reading maps and such cause if you have power to your cig lighter, you probably have dome lights. Perhaps a look-see under the hood if there is something wrong and we all know that it's never something quick and easy. I picked up a hand-crank'd led flashlight that works well. No batteries... no shaking back and forth... fits well int he glove box or tool kit.
  9. Nice Pezzy! I'm still looking at how to mount one for mine. So many options, none very nice.
  10. for your engine, the compression pressure in psi is 173. Minimum of 128 but there should not be a difference of more than 14psi between any 2 cylinders. if one or more cylinder is low, pour a little engine oil in through the spark plug hole and recheck it. If compression improves, rings are probably worn or bad If compression stays low, could be a stuck valve or one seating improperly If compression in any 2 adjacent cylinders is low and oil doesn't help, you have a head gasket leak
  11. I had one that I ripped the threaded shackle pin out of. not good when you have a full load on it. Perhaps it was defective but I got it at a 4x4 auto parts store. Got a couple replacements from a buddy of mine who operates cranes at construction sites and have had no issues since.
  12. yea... that one was just too easy. *sees Pezzy heading for the auto parts store*
  13. so.... hide your propane tanks where the firefighters can't see them, right?
  14. My first thought would be fuel filter but that shouldn't blow a fuse
  15. hey CG, what part of NM are you from? I spent a few years just north of Las Cruces but have travelled the entire state (as well as surrounding ones) as part of our SAR organization.
  16. I agree. Stay away from the Home Depot and Autozone shackles. Construction equipment is the way to go.
  17. you're supposed to put oil in them? sheesh! maybe that's my problem.
  18. the ribbed ones are for female pathys. It keeps them happy.
  19. I have shifted out of 4H at highway speeds but I believe you still need to stop and reverse to unlock the auto hubs.
  20. 91 offered Aztec Red Champagne Pearl Metallic Charcoal Pearl Metallic Cherry Red Pearl Metallic Dark Gray Metallic Midnight Blue Pearl Metallic Riviera Blue Pearl Metallic Safari Green Metallic Super Black Vail White
  21. k9sar
    Newby
    I have the BFG AT KO's and they held up quite well on my last run. You can definately go bigger than the 31's but will need a lift to provide the needed clearance. Or, you could do a hackjob on your body like 88 curious as to why you are looking for new rims. I would leave the stock and invest in the lift. Cheapest list is definately JGC springs and cranking your t-bars but upgrading your UCA's is preferred so you don't have alignment issues or balljoint failures. and... welcome to the boards.
