Precise1
Moderator
Everything posted by Precise1
  1. I'm going to go ahead and move this into the How To section now... B
  2. Right behind the battery, bolted straight down on top of the fender well and I believe it also carries on over to the power steering bracket. I have to go take some pictures of something else, so let me go snap a few... B
  3. You are on the wrong side of the line, that is all. I had no shipping charge, just a handling fee of $12... You could run 33x12.5 on them, but for that width tire the ideal rim width is usually 9-10". Never said they couldn't fit... What brand/model tire are they, I'll check for the recommended rim width... B
  4. As big an any non SAS'd pathy can handle? You could run 33x12.5 on them, but for that width tire the ideal rim width is usually 9-10". B
  5. Precise1
    Parts
    Some but it depends on what year HB and if it is 2x4 or 4x4. I usually use some place like Rock Auto to look up part numbers if they match, then I should be good. It isn't perfect, but there are a lot of factors to remember with cross compatability... B
  6. WOW!! I have a set of BFG AT in 31x10.5" on the stock chromies (which are 6" wide), slightly pinched IMO, but I personally ran them over 25k miles without any trouble. You are welcome and yeah, that's why I got them there. I ran into the same price difference from the local tire stores and did the shopping to find where to get them. B
  7. Yep, through the wheelwell is what I did before I installed the filter relocation adapter B
  8. You have MPFI In North American the TBI became extinct in 1990. B
  9. LOL I don't know who these 'experts' are you are talking to, but I recommend you stop since they are idiots. Here you go http://www.summitracing.com/parts/CRR-3975860/ with a $12 handling fee and hopefully no tax. I bought 5 last year delivered to my house for $212. Everything else you stated is correct but I don't know the backspacing of the Legos. B
  10. Well, he's 1/2 way there already... B
  11. I bet you had a faulty ground, check the cable and connection from the negative post to the chassis. That is wierd yet cool that it would do that... B
  12. Wave front, a nose tarp and keeping moving all help. Not diving in or even hitting big puddles fast makes a big difference. Removing /rerouting some of the air box feeds is good too, but at the end of the day, there is no replacement for a snorkel, sealed air box and relocated ECU. As for the alternator, you may kill it, but you can at least still drive out without it... B
  13. You are welcome, I'm always happy to... confuse the issue. Sorry, weird and busy night, I never got under the hood. I should be able to do it tomorrow. Hopefully it will keep raining... Sounds like you are right, the alternator failed but obviously have it bench tested. There have been several complaints about Autozone re-man items lately... B
  14. Ok, I watched it and there went 15 minutes of my life... I'm pretty sure the spec for the cam timing is 41 belt teeth between timing mark to timing mark as they are on the pulley teeth... Anti-seize on the spark plugs is generally a good idea, and the radiator hose bit is a good trick. I have a unit that is like a spark plug boot molded on/around a knurled aluminum rod so sorry, it's already been made and patented. Nice video though, and I appreciate the dry humor. It'll help a lot of people see what they are (or aren't) getting into. Thanks and keep up the good work. B
  15. Let me point out that this was said by a service manager at a Nissan dealership who owns a pathfinder. He is saying what most of us go by, so I do not recommend being swayed otherwise. There have been some threads about what to use/where to find that a search may turn up but probably the #1 replacement is the Redline MTR 90 with positive feed back. When I flushed my tranny, I used 85-W90 GL-4 and some Lucas oil stabilizer which worked fine here in NorCal other than some hard shifting first mile or two on a cold morning. You should be golden in SoCal... Also, if it is the same tranny as the 95 Pathy, 5 liters is what is required per the TSB pinned in the Garage/TSB section. B
  16. Watch out for the monkeys, they throw... stuff at you. B
  17. The picture of a parked pathy?? Again, my concern is if you stop for any reason which there can be many, especially in such muddy water. I understand how it works and it's a great idea and I'd use it in a pinch if I had nothing else... B
  18. Exactly, absolutely and correct. B
  19. Something tells the problem source is not the Pathfinders... B
  20. Not necessarily... A tire company can call anything a M&S tire, even racing slicks. The mountain/snowflake symbol represents that the tire passed the severe weather traction testing by an independent firm. You'll find that more M&S tires won't have this designation. mws had a good thread about it... B
  21. If a new properly tensioned belt changed the sound of your truck, the old one must habe been pretty bad!! Thankis for the video, I'll check it out when I get home. B
  22. Hey Rob, I'll see what I can trace on my parts truck when I get home. In the meanwhile, go to the Garage section and pinned at the top is a thread about manuals. One of the last posts has a link where you can download a full factory service manual in PDF form. The earliest model is 94 but as long as you have the MPFI 4 door, it should be the same. Aww, hell, here it is... http://www.nicoclub.com/FSM/pathfinder/ B
