Kingman
Everything posted by Kingman
  1. Really? http://www.nissanpathfinders.net/forum/index.php?showtopic=20711&st=0&p=359445&hl=lift&fromsearch=1entry359445 http://www.nissanpathfinders.net/forum/index.php?showtopic=5325&st=0&p=47405&hl=lift&fromsearch=1entry47405 http://www.nissanpathfinders.net/forum/index.php?showtopic=5343
  2. I believe VQs have oil flow issues through the heads. I would test the oil pressure, and if it's below 7PSI at idle stop driving it NOW. Hate to be the bearer of bad news here, but VGs and VQs won't tolerate much oil starvation. So oil light came on, and now it ticks and knocks on start up? EDIT: If it's a VQ35, it's at least an '01 and any auto parts store that offers free code checks can read them for you.
  3. I started it up and listened to the glorious lifter tick of a VG after sitting for a week, backed it up to where it's normally parked, and shut it off.
  4. VG33 stock will put down more power than a bored over VG30. VG33 is a better baseline for ANY VG motor build.
  5. A Chevy 350 is almost the same size as a VG30/33. A little longer is all.
  6. Blow-by is blue, rich gas is black.
  7. I don't have any issues with shifting into first when moving. Do it all the time on the trails.
  8. Yep. Just like an old diesel truck, plug it in to the house. Keeps the engine warm and rotating easier for starting when it's extremely cold.
  9. Um, no, send it to me. Duh.
  10. I'd be pretty proud of a Pathfinder bumper holding up that well against an Excursion. Those rigs aren't light and are SOLID. Usually a Pathfinder bumper bends if you look at it wrong.
  11. FS5s are pretty effing strong provided you don't put the wrong fluid in it. My '88 is at 203K on the transmission and still feels like butter.
  12. I will say however that your front end alignment is farked! Holy crap, I'm assuming the rear tires were rotated from the front???
  13. I wouldn't even take a second look at that. Have you seen my rear bumper?
  14. Wanna get rid of it? Cut the wires going to it. It works on a Dodge Nitro RT...
  15. Just watched the video. It sounds like the typical lock/unlock scenario with the auto hubs...
  16. I would use the VG33 plenum. You can always try both and see what you like best.
  17. Upgrading the throttle body size won't gain you anything with a stock plenum. The larger size goes hand in hand with gutting the intake, and yes that will drastically kill your low-end torque. Just a reminder, if you do go with a larger throttle body the intake bore needs to be matched. I agree, the guys at z31.com are jackasses which is why z31performance.com was started. There's an epic assload of information on that site but you must become a member to view any threads. http://s218019339.onlinehome.us/redz31.com/turbofaq/mod.plenum.html http://www.circletrack.com/techarticles/general/139_0305_port_matching_engine_porting/index.html
  18. The TBIs tend to need a hotter plug, the 5Es, for complete combustion. The MPFIs can get away with using 6Es.
  19. I can't watch videos. I exceeded my data bandwidth for the month.
  20. I've never heard of a hub slipping. I've seen and heard them grenade before...
  21. Instead of going with Warn or Mile Marker hubs, get some factory Hardbody manual locking hubs. Stronger than the Warns.
  22. That looks like a serious failure waiting to happen...
  23. Wow, I hope mine don't get that bad. The rear end is really loosy-goosy now. I can't imagine driving it if the links were as bad as yours!
