Cuong Nguyen
Everything posted by Cuong Nguyen
  1. Replaced the busted clogged cat converter. 300 dollars. Ouch.
  2. Tested my reversed drag link and it was a definite no-go. Put the original back in. I need to make a new drag link as it is too short for my liking. Also I need to readjust it as my steering wheel is off centered. I get to drive it again so I'm happy.
  3. I ended buying the bigger trans jack from harbor freight and I was glad I did.
  4. Them electrical gremlins. I found out the other day that the front amp was for the rear speakers and the rear amp was for the front. Wierd.
  5. You could use an aftermarket one or take whole unit from a late model car or truck.
  6. Hit up a reputable locksmith to get the tumbler fixed. Shouldn't be much.
  7. Truck was running like crap. I didn't think the rattling was related. https://youtu.be/ttpqafpC2-A
  8. Snorkel one day. Came home to my mom's for Christmas and found some of my tools, my oil filter relocation kit and external transmission filter, and my rear stainless steel like to the t block.
  9. The impact does the work. No need to do anything special unless it's weak. L
  10. Search on NPORA. I posted this info before. You can buy the stud at 4x4 parts and order the monroe shock at any auto parts store or rockauto. Look up pathfinder steering stabilizer and it will come up in their database.
  11. Sounds like the dizzy. A faulty dizzy will do that and the camshaft position sensor goes out of wack.
  12. You do not need to drop the pan to change the fluid it does help to see if you don't have large broken bits.
  13. I'm guessing your con rod bearings are shot.
  14. The bundle ends at the passenger fender at the transmission harness junction tree. You'll see like 5-6 plugs on a metal bracket
  15. Yeah I hope so too. I thought it was the dimmer switch too. I also realize that I have no headlight chime either when I open the door with the key out of the ignition.
  16. It's a square dash. I'll see what I can do when I get some free time. I have no dash illumination now which sucks at night.
  17. Looks good I'll add that to the bottom of the list of to dos lol
