94extreme
  1. rust, uncared for ATs kill these things faster then anything. as long as one does the maintance, vg can bang for a long time.
  2. every state is different.. in WI you can't have more then 4 lights showing up front... it all depends.. they seem to not care about the tires not the lights in my state. we have no inspections either.
  3. that's what i dread.. last time on entering canada it was the least friendly reception, for sure.. maybe my citizenship made the guy be a bit funky. he just questioned me a bunch at the gate but then let me in.. they really drilled me on my stay/itinerary and when i was plannning to go back to the states. no issues coming back to usa.. just welcome back and smile. i was in a rental car which probably made it easier.. next time i come up will most likely be in my truck.. i am going to be hating it.. may have to come through sault ste. marie or something.. port huron is where i entered last time..
  4. they went through your vehicle? damn. i never have had an issues even when loaded to the gills, or even the time i had no papers.. US let me back in without too much hassle and that was after 9-11. i've never had my car searched.
  5. there are ways but if i type it then it won't be secret, will it?
  6. damn, how secret is that now. under the filter
  7. and they may bend you door and lock you inside..lol.. they are just for looks.. not functional as they have no heavy load baring capabalities.
  8. checked fluid level, viscosity, color, smell? edit:which year?
  9. stock ones are black. some have 5 and some 6 windings.
  10. drive faster or slower then. this points to tire/steering/suspention issue to me.
  11. wd and v6. it has a frame. the r50 doesn't. definitely look long and hard for rusty frame.. that's really the only thing that kills these trucks. engine is almost bomb proof (w/maintenance) get manual tranny if you can find one it seems to have more torque. i like it better anyway. powerwise: ah, it ain't too bad. you either lift the frame or the body.. the trannies sit on the frame. MPG's aren't all that.. i'd say ave ~17 but some do less.. few do more.. 20 if you're way lucky but with lifts MPG's drop.
  12. actually this is not really a common issue at all but in some locations avaialibility of junk pathys is so low that when you find one there isn't much left. edit: OR should have a bunch though unless 88 beat you to it all, although he isn't in the S. if you purchase a new or newer motor make sure to match the old one with the new one... they made a couple of different 'models'. at least the way the connect so, don't get stuck with one that won't work for you. one had 3 prongs that go into the door's drive and i don't recall what the other one was oh, the gear thing.. if you say the teeth look perfect then the cause could be latteral slipage, as the cog moves side to side enough where it doesn't line up with the other gear. i have a similar issue with a plastic gear in another car on another part but that was what i finally figured out; it may be something to observe.
  13. are you sure it's the engine and not something else vibrating? have you check your plugs and wires and cap? fuel filter? air filter? you're going to have to start with the basics.
  14. no other times it gives trouble? does the check engine light come on? anything else?
  15. definitely go with standard time.. daylight savings is such a joke.
  16. pinoy? wow.. hmm.. well. stuff happens i guess. or not say a damn thing.
  17. 2x but i have a feeling you were way too close to the obstacle thus he was able to slide into you. i've never had that issue with anybody i went wheeling with. one of my buddies however did get bumped by a jeeper who wasn't in control but there was no damage. things could have gotten ugly if something did get bent up. most of the time i go solo so if there is damage it is definitely my fault.
  18. may want to PM or email mr Vsicks Pathy as he's got a holden and an mt in his truck
  19. since the tornado is just a widget, this thing makes me wonder too.
  20. yes, it could be debris or the motor is going kaput.
