94extreme
  1. i thought you like to be on it? gallon (UK) is called the imperial.. i think that's what AU and NZ are using but there is another sized gallon out there... metric is so much freaking easier...!
  2. advanced auto does them too now.. they also started to rent the tools finally
  3. it's been a while since i was in the doors but i think you can move the side channels.. some trucks have just center rods... you'll just have to monkey with that untill the window tracks better... i'll be in my door this weekend so i'll try to look for you.. if nothing else works try to open the "good" door up for reference...
  4. lol.. must be some real love there... hehehehehe
  5. 94extreme
    WD21, R50?
    wd21 =<'95 r50 '96<'04
  6. i thought you had 240k miles on the truck.. sorry.. sure they should last a bit longer... just check their tension and see if that is the deal.. belt dressing may just do the trick.. it's hard to tell without sweeing the darn things..
  7. i bet you have to replace them pronto... they are probably stretched and thus making noise... tightening them will work only very temporarily..
  8. last time i was there i was in my mustang so i didn't even attempt it.. so i biked all over the place and eventually went to Seneca Rocks... maybe we could meet in WV sometime?
  9. yeah, terrible roads... i wish we had some like that around here though..
  10. well, gas is well over $2.00 at this point and probably will never go below that.. the prices fluctuate daily here as much as 30c but most of the time only about a dime... on friday i filled up for 2.04 but this weekend it was 2.38.. it was 10-15c less yesterday and looks like it maybe even lower today... http://www.indianagasprices.com/ http://www.indygasprices.com/
  11. nice pix dude... WV is pretty awesome as to outdoor oportunities... there is a lot of wheeling spots everywhere... was this fr13 near blackwater falls?
  12. i wouldn't worry about it too much. XOC is a freaking ZOO.. fok them.
  13. a friend of mine wit an X tapped grease fitting into the UCAs
  14. tellico is on the border of TN and NC.. near Murphy NC... most of it is not doable in a stock truck.. just the few major trails... http://www.4x4trails.org/tellico.htm http://www.solaros.com/TellicoDirections.html
  15. yeah, bad egr is basically cost of extra gasoline... precise1, there is the shop manual online you know?
  16. 10-30 M1 but i also still mix it with the new extended mileage ones... probably will try to switch to 5k oil changes also.. 10-w30 weight is what Nissan recommends!
  17. yeah, the light really mean nothing.. as soon as ylu engage the transfer case you get power going to all 4 wheels.. then of course the front has to lock for it to be useful... sometimes i have trouble telling if both fronts are locked or not... backing up tells you that if you hear 2 pops when the fronts unlock.
  18. do a search on the external cooler mod on this site... lot's of good discussion and pictures.. look at the stickies in the garage..
  19. ok, i fixed it.. i just loosened the catch and moved it towards the front of the vehicle, retightened and whala! it's good to go... took all of 2 minutes or so... didn't have to use tape or mess with the latch.. super simple..
  20. It might be, but from what I remmember the TDs don't have an ECU. We don't have em in the states so I have no experiance with them, just remembering a post by a Swed on another board about them. i don't see a diesel havin one but i guess you never know...
  21. kool, thanks guys.. nnice write up 88.. i'll try to take a few pix in the next day or two or when i find the darn time to get'r done...
  22. and that doesn't get too hot?
  23. yes, power flush is a good thing and not the same as just changing the lube... yup, over half of your fluid is in the torque conv...
  24. under the glove box in the passenger's footwell... look in the shop manual.. it was kind of a hassle but not that hard to do... mine was packed full of junk and i mean full.. had hardly any air circulating...
