JackFletcher last won the day on June 13 2019
JackFletcher had the most liked content!
About JackFletcher
- Birthday 07/26/2002
2004 LE Platinum
16-21
2004
Gender
Georgia
Country
1,445 profile views
JackFletcher's Achievements
NPORA Regular (2/5)
45
My set up is AC in the front and LR 9449 in the back. AC springs shipped from Florida and the shipping wasnt that bad from what I remember. The land rover springs however are very expensive to ship due to the fact they ship from the UK. I believe the LR springs ran about $30 for 2 and $75 for shipping. I remember the AC springs were considerably higher priced for the part but the shipping was only $20 dollars to Georgia.
I have a 04 Platinum with the electric t case. I am on 33s with 2 in lift springs and the lr 9449s. I obviously would prefer a manual transfer case because of the "cool" aspect but other than that i have had no problems what so ever. When i put on the manual hubs it took away the convenience of having the AUTO mode. The idea of having to get out of the car and lock the hubs during a bad storm so i can drive with AWD is unnecessary to me due to just laziness. So i wouldnt say that AUTO mode is a luxury unless you keep the factory hubs. I do want to make a note that after i did put on the manual hubs, i get a 4WD warning light when i take exteneded hour or longer trips on the highway at 65mph+. I dont worry about this because i assume it is just the computer getting confused.
You need both one should be larger and the other should be a smaller. You need to replace the seal and the small O ring that is on the inside of the screw you will be removing.
If the connection came undone it might have messed with the vehicle immobilizer system. Sometimes the computers get confused and think the car is still "locked". I would try disconnecting the battery for like 15 mins and then putting the leads back on. I think Nissans will crank with the security triggered but im not sure. Im not familiar with your year pathy but I would read up on the security info in the manual and see if your security light can tell you anything. If its not the security you could also try putting your foot on the gas a little when starting it. I put a new battery in my friends acura and had to do that because the computer needed to relearn the idle.
sfcreation.com
Yea i would definitely add the stop slip. Its only $11 and I have heard miracle stories lol. I don't know the pricing as far as your transmission goes but there might be a lot of info available because of the strawberry milkshake ordeal. Just pour it down the dipstick hole with the engine running. You gotta sit there and squeeze for a few mins because of how thick it is.
I am assuming you already have a after market trans cooler because its unlikely you could have made it 160k miles without one. But just to be sure you are aware it is a common issue for your model year pathy to leak coolant into the transmission from a faulty factory cooler. First thing I would do is check underneath the radiator cap and make sure it doesnt look like a "strawberry Milkshake." The odds are you already have had this addressed though because again it is likely your transmission would have already failed if you hadnt. If the coolant looks fine then I would just assume its starting to go out. 165k miles is a lot for a jatco transmission from that year lol. If I were you I would pour in some Lucas Stop slip. I actually put some of that in just as a preventative measure last weekend and I am impressed with it so far. Good luck
Truck running choppy, P0120 code being thrown...
JackFletcher replied to Teddy's topic in 96-2004 R50 Pathfinders
agreed use a multimeter or take it to a auto parts store sounds like a alternator starting to go -
How many miles did it last ya
Drive-by-wire + AT + 4L = sucks
JackFletcher replied to hawairish's topic in 96-2004 R50 Pathfinders
In 4LO there is a significant difference at idle for me. She will basically go imma say up to 6mph without even touching the gas. When i do give it some throttle I feel what you mean. She will rev up with no power response for a few seconds until you get around 1700rpm . I wish it wasnt a pain to convert to a cable throttle. -
Lets see what he comes up with lol
You don’t have fog lights
This is so cool, I never would of thought it would come together and look this good! Sent from my iPhone using Tapatalk
Y’all think it would be a bad move to put the pro comps on my daily? Or will I be good with the hub rings? Sent from my iPhone using Tapatalk
