50
Everything posted by onespiritbrain
I was EXTREMELY bored, to the point where I was thinking about things I shouldn’t be, so I had to take action! There was a powerful storm band moving thru Georgia on its way to me that was dropping tornadoes, so I thought, “I know what I’ll do... I’ll hit the trail in the middle of this storm”. And so I timed the storms arrival to hit me when I was getting started on the trail, and it was a major success! It was worse than I imagined and the trail had been closed for some time and was overgrown. I did not record my getting on to the trail and the storm because it was literally too crazy for me to do anything but survive, and not get crushed by a falling tree! Last thing, I used to like getting high, and I spent a lot of my life doing just that.. but I have to say, I could NOT have done this while inebriated in any way... and to me, that’s pretty freakin cool! Sent from my iPhone using Tapatalk Pro
Valve Train Noise w/ Castrol EDGE 10w30
onespiritbrain replied to onespiritbrain's topic in 96-2004 R50 Pathfinders
I think I had room for about a quart in the sump so I took a half empty thing of ATF and mixed the in the seafoam then poured it in. Sent from my iPhone using Tapatalk Pro -
Yeah I did have to make some mounts for it and about 10-15% of the radiator is unshrouded and that did suck because all I had was some kind of special stainless steel that was hard to work but if you had some scrap aluminum it wouldn’t be bad at all. I literally took the whole fan and shroud right off the Volvo and slapped it on mine. This is the guide I followed: https://therangerstation.com/tech_library/volvo_electric_fan.shtml Sent from my iPhone using Tapatalk Pro
True that! I was 15 and I took my parent’s 1985 Volvo 240 out for a drive in what was supposed to only be in our neighborhood but I actually took it across town. I was coasting in neutral at about 50mph when I accidentally threw it in reverse instead of drive and it instantly started spinning around in circles right in the middle of the road. Luckily it stopped perfectly on the side of the road as if I had pulled off on purpose. I made it home before the rear end died but it never left the driveway under its own power again. Sent from my iPhone using Tapatalk Pro
I went with an electric fan from an old Volvo 950 and it works exceptionally well. Sent from my iPhone using Tapatalk Pro
I had a RWD Frontier when I was a teenager and it seemed to go anywhere and very rarely ever got stuck. I never use 4WD on fire roads. Honestly the only time I use 4WD is when I’m going places my vehicle has no businesses being. I will say that without lower gearing you can run into overheating issues in the summer. My first engine didn’t have a blown HG and I did see temps go above normal when going slow on trails in the summer. A quick neutral engine rev would shoot the temp back down. Sent from my iPhone using Tapatalk Pro
My Pathfinder gets stuck quickly off-road in RWD. FYI Sent from my iPhone using Tapatalk Pro
are locking hubs worth it for me?
onespiritbrain replied to Strato_54's topic in 96-2004 R50 Pathfinders
Yeah manual hubs are actually of no benefit off-road. The benefit of having them is that they dramatically increase the life of CVs if you’re (suspension) lifted since the CVs won’t be spinning unless you engage the hubs manually. The “auto” hubs aren’t automatic, they’re just always engaged. And like Pathydude said, you save gas because the rotating mass and rolling resistance of the CVs, front differential, front propeller shaft, and front drive components in the transfer case are all disconnected from the front wheels. Sent from my iPhone using Tapatalk Pro -
Another not-enough-heat thread
onespiritbrain replied to Daddybender's topic in 90-95 WD21 Pathfinders
It’s a fluid coupler that slips less and less as it heats up. I think the service manual tells you the slip rate, or I might be confusing something I saw on google from a while ago when I was having overheating issues. Anyway you can sort of test it’s health by getting a feel for the difference in resistance to turning the blades by hand when the engine is cold and warmed up. Kind of a subjective test but a diagnosis for a seized clutch is easier to determine than decreasing efficiency. And a seized clutch will roar like a tractor trailer even after the engine is warmed up. Sent from my iPhone using Tapatalk Pro -
I cant think of anything outside of the thermostat. Even if the fan clutch was always fully engaged the operating temp should still be normal. -
From my limited experience, partially worn bushings and end links dont produce large effects while driving. Clunking noises and general difficulty driving the thing in a straight line are what I see as things are wearing out. Large noticeable movements going down the road, for me, have always been caused by a large broken or completely worn out (or gone altogether) bushing / end link. So if your experiencing large noticeable problems then look for something to be completely worn out or like Mr Reverse said broken. Ive also found that large noticeable problems tend to be bad enough that when you lift the vehicle off the ground you can usually move the offending problem area with your body weight. That might be a little different having just replaced all the bushings back there so everything will be quite stiff but I'd still get it off the ground and grab a hold of that sway part and see if you can move it about.
Aha! Thank you Sent from my iPhone using Tapatalk Pro
Subbed for more info and nighttime pics Sent from my iPhone using Tapatalk Pro
I should probably read the whole OP before I reply.. I see you said it happens in 4lo and you have a different tcase than me. When the thud appears, are you moving forward or sitting still? Has it happened when sitting still? How often is it reappearing? Like every 5 minutes or more like every 5 seconds? Do you notice it happening more often while traveling thru turns? Sent from my iPhone using Tapatalk Pro
Oh I know what you’re talking about. The center lock disengages if you sit for a long enough period of time. It will do the same thing if you shut the engine off and it doesn’t do it at all in 4lo. Sent from my iPhone using Tapatalk Pro
The Quest alternator makes 110A and I think only needs minor mounting modifications. I had a 1500wrms system not long ago and the stock alternator handled it just fine. The battery is actually the most important thing unless your gonna be playing at competitions for hours on end. Sent from my iPhone using Tapatalk Pro
I got some time to myself today and decided to visit Echo Lake again. I haven’t been back down there since we found that stolen Jeep, fearing serious criminals frequented the area. About 300 yards into the trail I was greeted by a flipped truck that had burned to the ground! When I finally made it down to the lake there was a group of teenagers smoking some very good smelling weed which I passed on. They had screwed a lazyboy way up in a tree and one of them was sitting in it. I asked about a homeless man I had met down there previously and they knew him. They told me the reason he is homeless is because his son died on a dirtbike and that they went to school with him. Now there is a congregation of homeless people that have makeshift shelters set up in the woods all along the trail. I didn’t take pictures of anything while I was down there because I felt like I shouldn’t. If I go back with some of my friends then I’ll take some pics of the shelters and that lazyboy. On the way out I barely nudged a tree and it handed my bumper it’s arse. This is after I beat on it with a hammer: It’s lined up better than it’s been since that idiot who offered me a fish sandwich at 8am crashed into me: Sent from my iPhone using Tapatalk Pro
Tree gave my bumper a massage Sent from my iPhone using Tapatalk Pro
Drive-by-wire + AT + 4L = sucks
onespiritbrain replied to hawairish's topic in 96-2004 R50 Pathfinders
My wife’s GX470 is DBW and literally just this morning I noticed that the throttle response does not have high enough input resolution. I’d never notice it under normal driving conditions but in sopping wet grass I could not give it just enough throttle to move forward just before the tires would break loose. It was either no discernible forward movement or too much. I think it would be even more noticeable if the engine was more powerful or the gearing was even lower. However extremely low traction and rock crawling are very different. -
I can vouch for the ultras. You might also have a look see at the high output “off-road only” bulbs. If you have your headlight housings aimed correctly then no one will know you have “illegal” bulbs. Besides some of these new vehicles (2019 Silverado!!!) have headlights that are at least triple the lux that our old halogens produce. That and they’re only $3-5 each..
Sound right, MAF needs replacement?
onespiritbrain replied to DonutHands's topic in 96-2004 R50 Pathfinders
Hit the 3.3l Nissan Quest at junk yards for the MAF Sent from my iPhone using Tapatalk Pro -
zakzackzachary's 2000 R50 new to PNW from AK
onespiritbrain replied to zakzackzachary's topic in 96-2004 R50 Pathfinders
Hope you guys are happy up there with your ridiculously beautiful land... saying I am jealous doesnt do well to describe how I feel looking at these photos. -
great spot for pictures man I really dig the stock with a lift look
I put 100W halogens in my fogs and theyre actually useful now. If you put the 100W or 130W bulbs in there then make sure you aim them correctly. I had to cut off a tab that was on the bulb's metal base.
