50
Everything posted by onespiritbrain
Tree gave my bumper a massage Sent from my iPhone using Tapatalk Pro
Drive-by-wire + AT + 4L = sucks
onespiritbrain replied to hawairish's topic in 96-2004 R50 Pathfinders
My wife’s GX470 is DBW and literally just this morning I noticed that the throttle response does not have high enough input resolution. I’d never notice it under normal driving conditions but in sopping wet grass I could not give it just enough throttle to move forward just before the tires would break loose. It was either no discernible forward movement or too much. I think it would be even more noticeable if the engine was more powerful or the gearing was even lower. However extremely low traction and rock crawling are very different. -
I can vouch for the ultras. You might also have a look see at the high output “off-road only” bulbs. If you have your headlight housings aimed correctly then no one will know you have “illegal” bulbs. Besides some of these new vehicles (2019 Silverado!!!) have headlights that are at least triple the lux that our old halogens produce. That and they’re only $3-5 each..
Sound right, MAF needs replacement?
onespiritbrain replied to DonutHands's topic in 96-2004 R50 Pathfinders
Hit the 3.3l Nissan Quest at junk yards for the MAF Sent from my iPhone using Tapatalk Pro -
zakzackzachary's 2000 R50 new to PNW from AK
onespiritbrain replied to zakzackzachary's topic in 96-2004 R50 Pathfinders
Hope you guys are happy up there with your ridiculously beautiful land... saying I am jealous doesnt do well to describe how I feel looking at these photos. -
great spot for pictures man I really dig the stock with a lift look
I put 100W halogens in my fogs and theyre actually useful now. If you put the 100W or 130W bulbs in there then make sure you aim them correctly. I had to cut off a tab that was on the bulb's metal base.
The super high end LED bulbs do outperform HID. Check this out:
https://headlightrevolution.com/gtr-lighting-gen-3-ultra-series-led-headlight-bulbs-h4-9003/
Check for issues that time will cause, like rust and cracked rubber lines.
PathyDude's R50 Projects (03 SE 4x4)
onespiritbrain replied to PathyDude17's topic in 96-2004 R50 Pathfinders
Agreed -
Spring Break 2020 Meetup (South)
onespiritbrain replied to Ole_Rosie_R50's topic in 96-2004 R50 Pathfinders
What is the SM500? -
Spring Break 2020 Meetup (South) https://r.tapatalk.com/shareLink?share_fid=45554&share_tid=45258&url=http://www.nissanpathfinders.net/forum/index.php?/topic/45258-Spring-Break-2020-Meetup-%28South%29&share_type=t Welcome
Thanks dude
I got lucky pressing the tabs in with a flat head screw driver. I was not so lucky at the junk yard.. I lost my mind trying to remove the blasted thing and busted my knuckles pretty bad while I was freaking out. There’s blood all over that pathfinder lol people are going to think something bad happened in it! Mine was leaking a little all the time and began to really leak badly when you first started pressing the brake pedal and down to about half way. It made the engine start misfiring when it would leak badly and then the brakes would be extremely stiff to the point where I couldn’t stop quickly if I needed to.
I’m not sure how different the WD21 and the R50 are but I forgot to put the gasket back on there and I don’t notice a difference at all. I don’t know about the spacer as I don’t think the R50 booster has any spacers. Where does the spacer go?
Transmission Problem - Module?
onespiritbrain replied to Tshields's topic in 96-2004 R50 Pathfinders
My best friends dad is a master transmission guy and when my trans died (the first time [emoji17]) mine did that same thing, driving forward in park, and he said that the forward clutch had seized (or he may have said a different word— trashed, or broken..) and that it was toast. I found a junk yard trans for $6-700 that was literally perfect. And after I handed it’s butt to it I found another one for around the same price that’s pretty darn good also. -
Yes!!! B4574RD!!! Double B4574RD!!! That’s power steering fluid in the bottle BTW not pee... I’m not about that life anymore
Judder - Died - No start, Help
onespiritbrain replied to TroyButler's topic in 96-2004 R50 Pathfinders
Hmmm.. with no code I think its leaning toward a fuel issue. I honestly dont know how to troubleshoot a fuel issue. Without googling it I'd say figure out a way to see if the fuel pump is actually sending fuel up front or not. May take the supply line off the fuel rail on the passenger side and hold a rag against it while someone turns the key to the on position. Or maybe you can rent some kind of fuel system test kit from Autozone. -
Is your check engine light on? -
Last night one of the spring cups on my driver side drum came loose causing the drum to get smoking hot and the shoes to seize. Had to fix everything in the Kroger parking lot at 11pm in the freezing cold! Dang it!
Take the distributor cap off and have someone try to crank it. Is the rotor turning? -
Yeah Slart is right. If the crank sprocket is clamping against the oil pump then something has happened.
