50
Everything posted by onespiritbrain
For 2003 What device increases the rpm when under load?
onespiritbrain replied to aoist's topic in 96-2004 R50 Pathfinders
I am in search of the same answer if it’s pertains to the VG33 as well -
Electric Radiator Fan Relay Help
onespiritbrain replied to onespiritbrain's topic in 96-2004 R50 Pathfinders
I went with the last design and it’s working. I am very happy with the improved air conditioner performance. I do have to say that with the AC on full blast and the fan on high speed, it seems like I actually have less power than before. It’s not much so it might just be me but I can’t discern any extra power whatsoever. I wonder if the increased power draw on the alternator is causing a noticeable increase in mechanical resistance. -
VG33 Engine Oil Dipstick Upgrade
Oh yeah I did but I edited the first post at the bottom. It was from a 1999 Isuzu Rodeo -
wow haha @colinnwn you were right! here is the final draft http://tinyurl.com/y2b9sgh6 -
here is the circuit and it looks like it does indeed work!!! http://tinyurl.com/y46lm8gc I want to figure out a way where the dual temp switch cannot be overridden IF the coolant is at 99degC or above. I dont see a way to eliminate the ground break relay. How can I eliminate it? I am switching the ground because its milliamps instead of fla for the fan. Im probably just going to tell the fan to kick on high with the AC clutch instead of trying to get crazy with the recirc thing.. its going to be a pain in the arse to run wires to that plug anyway and im not going to want to have to hit the recirc button all the time when the ac isnt cold enough.. -
This is with the rest of the wires shown By feeding the coil ground on relay #3 from NO on relay #2 it will eliminate the issue of having the recirc button on with no AC running -
Reduced area much be outweighed by increasing flow. During hot and humid summer days in Georgia my cooling system can’t keep up driving off-road, on long steep grades, in long drive thru lines, extended periods in parking lots, etc. Also when stopping at red lights, or any of the above mentioned situations, the AC starts blowing warmer air. The electric fan pulls so much more air that the AC condenser even has air flow. I had this exact same problem with my 2001 Frontier and I replaced the radiator and fan clutch on it. I’ve replaced my thermal fan clutch and radiator on my QX4 but as before the issue, while not as bad, is still there. It’s like the factory cooling system is just barely enough to do its job and any sort of added heat load (including the AC) or reduced capacity (radiator scaling?) results in a situation where the engine temp rises slowly but indefinitely.. -
I am trying to figure out how to set up relays for controlling an electric radiator fan. I have it hooked up now and it works very well but it will run after the engine is shut off. I have spent literally hours trying to figure out how to set these relays up... Can someone who understands this stuff please look over what I have so far and tell me if its going to work correctly? The only issues I can see for myself are: 1. Turning the AC on will kick the fan out of high speed unless I manually activate the recirc switch (which is always off by default..) 2. If I turn recirc on without the AC on and the fan is running on low then both low and high motor leads will be energized. I don’t know what will happen to the motor if this occurs. As I was typing the third issue I noticed what I thought may be an issue could actually solve the first issue IF the dual temp switch connects both grounds inside itself when its high temp setting is reached. Then even if I have the AC on but recirc off and it reaches its high temp setting it will pass the ground through itself and activate the fans high speed. If the dual temp switch doesnt connect both grounds, is there any way I can have the fan run on high speed if the high temp set point is met? Here is a drawing from the tech library at therangerstation.com of the Volvo relay: Here are some pics from the install:
I have a junk yard compressor blowing super cold air in my QX4 that I paid $40 for.. and it’s guaranteed to be in working condition or you can come back and pull another one until you get a good one. Where exactly are you?
cars ac dosent cool the compartment
onespiritbrain replied to qxx4's topic in 96-2004 R50 Pathfinders
Yeah window tint is very much like the optics on a pair of sunglasses. You can get stuff that looks great and performs decently, like a pair of Walmart sunglasses or you can get a pair that look almost identical but they have polarized lenses with multilayer coatings. Likewise window tint can have all sorts of different properties like high visible light transmission with very low infrared transmission(expensive— “ceramic”), or you can have very low visible light transmission with high infrared(cheap— “limo tint” from Wally World). -
Heat rejection from *good quality* window tint has a huge effect on AC cooling. Air flow over the condenser at low speeds is another big factor. Our AC setup has the ability to do some serious cooling. I've measured 34degF at full blast with recirculation on. If its not fighting an onslaught from the sun then I bet it'd get chilly in there quickly. I do notice vent temps rise the instant I start slowing down.. hopefully I can report better performance after my electric radiator fan install. I'd be interested to hear what someone with high quality tint experiences. -
I installed camber bolts on mine to correct negative camber because of the way it looked and it worked very well. It also raised the front of my vehicle up about an inch.. I can’t tell you if slight camber causes your tires to wear on the edge. I imagine they would wear a little more but not a lot. I can tell you that tie rods, control arm bushings, and wheel bearings will eat tires alive. Especially mud terrains.
Need help with coolant burp 01 Pathfinder
onespiritbrain replied to PrecisionX's topic in The Garage
Every time I’ve burped the cooling system I still have to watch the reservoir for some time afterward. I’ve heard it takes hours to burp the system, revving the engine and squeezing the hose the whole time. I had to drain the radiator about 6 months ago and it’s probably been just a couple months since the level in the reservoir stopped dropping by the end of each week. -
31 Virgo Rabbit
https://www.gumtree.com.au/s-ad/pakenham/cars-vans-utes/1999-v8-nissan-pathfinder-r50-fully-engineered-price-drop-/1122202002 https://www.lowmileageparts.com/Product.aspx?ProductId=309879&gclid=CjwKCAjw36DpBRAYEiwAmVVDMMyRAlxYiF-k0_qG1QLoo38cZPBWhOPlTtKIHYAnbPGSvz0nN5ewFxoCsugQAvD_BwE#.XSjXQetKipo
you should pm slartibartfast he usually knows a bunch about stuff like this
Are cold air intakes worth it?
onespiritbrain replied to Strato_54's topic in 96-2004 R50 Pathfinders
If you're going to be driving thru mud bogs and water holes then you better have a snorkel. I have personally decimated my engine from driving thru what I thought was a puddle only to find out it was 5 foot deep muddy water which my engine drank because I didn't have a snorkel. I don't have a snorkel now, but I also don't drive thru puddles unless I absolutely have to and then I get out and put a stick in it to see what I am about to drive into. -
They usually have 5-10 pathfinders/QX4s at each location and they’re usually pretty torn into by the time I get down there but I have seen several that were pristine. I’ve only come across 1 dizzy though.. I think some of the Nissan Quest engines have the same dizzy though and those are never torn into. -
Norcross is the closest I’ve been able to find any that are unsupervised. Pull-A-Part North 4416 Buford Hwy Norcross, GA 30071 United States U Wrench It 4600 Buford Hwy Norcross, GA 30071 These are right next to each other. I was literally just telling my wife that I feel like I’ve been at the adult playground today haha -
One of my pet peeves with my QX4 has been the engine oil dipstick. I can’t figure out for the life of me where the damn level is half the time and it just shouldn’t be like that. Today I went to the junkyard and checked a ton of dipsticks until I finally found a match! It’s a quarter inch longer but doesn’t cause any issue. I did have to sand down the plastic portion that enters the tube leading down to the engine. I am what looks like about 1.5 quarts past full... When I hear the lifters clacking I usually check the oil right away and since I couldn’t see the friggin oil level I added oil for no reason, twice. I had to add a quart or so every 5000 miles before I did the head gaskets so that’s why I thought I needed more oil. I’m quite glad to be rid of that dipstick. Edit: haha I guess it’d be kind of me to include the vehicle it came from! It was a 1999 Isuzu Rodeo.
onespiritbrain replied to RedRider3141's topic in The Garage
Upgraded my windshield washer nozzles from 2 to 3 streams. The ones I got from the junkyard honestly match the fading paint on my hood better haha -
It’s funny your story would come up right now as I am about to install an electric fan on mine this weekend. I might try to keep the clutch driven one in the back with all my other stuff when I go to the mountains for emergency.
haha yeah they squeeze in. Nah i keep all the stuff in the back tightly packed in a box and the stuff in the front fits in the center console, glove box, and behind the seats. I actually left some stuff out like my muck boots and ratchet straps, among other things. If i ever get around to building a new sound system then i'll have to rethink what all stays.
03Troutfinder Mild build Thread
onespiritbrain replied to 03TroutFinder's topic in 96-2004 R50 Pathfinders
I really dig it. It looks phenomenal! Great balance of sport and off-road. Thats North Hall park isnt it? -
ALWAYS WITH ME Up Front: Bible Kahr Arms CW45 100 Rounds 45ACP Deodorant (Red Spice Fresh) Laser Pointer 3" Knife Business Cards Phone Charger Lighter In Back: Change of clothes (gym shorts, socks, underwear) 1 Gallon 5W30 1 Gallon SAE30 Turbine Oil (power steering or in emergency transmission) 1 Quart Brake Fluid 1 Gallon Distilled Water Can of Penetrating Oil Can of Copper Anti-seize Assortment of 30k# Nylon Slings Assortment of 15k# IWRC Wire Rope Slings 4 17k# Shackles 2 Snatch Blocks Small Tool Box (3/8" socket set, 6-19mm wrenchs, screw drivers, etc etc) 21mm Socket and Breaker Bar EXTRAS WHEN CAMPING In Back: Beretta Silver Pigeon Pump 12ga. 100 Shells 12ga. 100 Rounds 45ACP Chain Saw (STIHL) Axe Tent 5 Gallons Drinking Water Cheap Cooking Oil (for easy camp fire startup) Coffee Food
