Alkorahil
Vendors
Everything posted by Alkorahil
  1. I probably wont be able to order the part since it was not available in the US, but can probably at least get you the part number.
  2. Bulb is Radio Shack part number 272-1092. two per package. about $3.50 that is it, it only comes on when the stalk is turned to on and you open the glove box. (pin is opened) The harness, if it is there, is tied off to the main harness under the dashboard. Remove the glovebox and see if it is up there. My 95xe didnt have the harness, my friends 93xe did have it. My 95 Hardbody had the harness.
  3. Yes, it only illuminates the orange when on.
  4. PART NUMBER: 25370-V5000 SWITCH, FOG LIGHT APPLICATION: WD21 86-93 $32.99 (NISSAN LIST: $59.49) 86-93 Hardbody trucks had this switch in place of the rear defogger switch on the 86-93 pathfinder PART NUMBER: 48476-73P00 LAMP ASSEMBLY, IGNITION COURTESY APPLICATION WD21 94-95 $14.36 (NISSAN LIST: $27.07) Illumination lamp for the ignition switch. Some SE and all LE models had this. You will also need a new ignition switch cover (the round plastic piece around the ignition switch) or drill an approx 1/4 inch hole in your existing cover.
  5. PART NUMBER: 68800-75P10 ASHTRAY, LIGHTED APPLICATION: WD21 94-95 $57.08 (NISSAN LIST: 96.86) Illuminated ash tray. Lights up when ashtray is opened. Harness connector to hook up the ashtray should be on all models. It is the black flat two prong connector dangleing behind the radio if not used.
  6. PART NUMBER: 26475-F6100 LAMP ASSEMBLY, GLOVE BOX APPLICATION: WD21 94-95 $11.49 (NISSAN LIST: 26.38) PART NUMBER: 25310-71L00 SWITCH, LAMP, GLOVE BOX APPLICATION: WD21 94-95 $10.64 (NISSAN LIST: $24.42) This is the pin switch and lamp for the glove box courtesy lamp. These parts go together to light your glove box when the glove box is open and the light switch has the parking or headlights on. Note: some XE models do not have the harness connector to hook the lamp up to power. You will have to run power to the lamp.
  7. It is actually metal, with a strong adhesive back. The switch in the center console came with the fog light kit, so dealers used it. Yes, the hazard switch should be backlit when the lights are on....dealers could put the center one in but it required purchasing seperately the switch and harness and the labor to install. Hardbody trucks with the optional roll bar came with this switch. I will post pictures when I get home.
  8. PART NUMBER: 40692-34G00 ORNAMENT, HUB, FREE RUNNING APPLICATION: WD21 (ALL) $3.28 (Nissan List: $8.07) This is the round metal emblem on the front auto locking hubs that says 'automatic' in orange and silver letters. PART NUMBER: 25370-73P00 SWITCH ASSY, FOG, FRONT APPLICATION: WD21 94-95 $19.52 (Nissan List: $36.80) Ever wonder what went in that far right blank above the center vents next to the rear defroster switch? This is it. An optional fog light switch. Push button and lighted style (similar to the hazard switch.) with the fog light emblem in white on the face. Note: the harness for this option is no longer available. PART NUMBER: 62890-56G00 EMBLEM, FRONT GRILLE, 4X4 APPLICATION: WD21 $29.82 (Nissan List: $55.37) 4X4 emblem, black with raised orange letters. measures about 8 by 2 inches. Mounts to the front grille on the drivers side.
  9. Are you talking about the ones on the doors?
  10. drained the mud-like substance from the transfer case and refilled transfer case with fluid.
  11. 83814-83G00 MOULDING,UPPER, RH $21.18 83822-83G00 MOULDING,CENTER, RH $17.40 83816-83G00 MOULDING,LOWER, RH $21.96 83815-83G00 MOULDING,UPPER, LH $21.18 83823-83G00 MOULDING,CENTER, LH $17.40 83817-83G00 MOULDING,LOWER, LH $21.96 All are still available.
  12. Mine does this all the time after driving it when I turn it off,.when it is very low on fuel (1/8th or less). My fix has always been to put gas in the truck so I dont run out of gas. (and the sound goes away too.)
  13. There are actually two different pins used based on year. The parts guy you talked to didnt look at his screen close enough, it shows under quantities on the vehicle '2' for the bushings and '1' for the pin. If he was paying attention he would have seen that and known that it is telling him '2' per pin, not '2' per vehicle!! I hate amateurs! 89-92 WD21 E7247-41G60 BUSHING, HINGE $1.56 EACH QTY NEEDED: 2 E7245-41G60 PIN, HINGE $3.40 EACH QTY NEEDED: 4 93-95 WD21 E7247-41G60 BUSHING, HINGE $1.56 EACH QTY NEEDED: 2 E7246-41G60 PIN, HINGE $2.51 EACH QTY NEEDED: 4
  14. Replaced front sway bar and bushings, both endlinks and bushings, tensions rods and bushings. One tension rod was bent!
  15. These symptoms sound like a distributor issue to me. When they go out they will cause back fire and it to run rough, then they will clear up for a while and then do it again untill it completely fails. It will also not want to crank sometimes and will crank up fine other times. Is there any backfire through the intake when you try to start it? Open the air box up and watch when you try starting it. IF there is any backfire through there that is your problem for sure! IF you can, try replacing the distributor on your truck with a known good one and see if it goes away.
  16. Every three months when i change the oil I think about doing this mod..............as I create new curse words...........
  17. My rear end was getting noisy and I was way overdue, so I changed the front and read differential fluids and the transfer case fluid. I had some leftoer fluid from the subaru so I got under the truck and went to work. There was a little sludge buildup on both the drain plugs and an acceptable amount of metal flakes on the rear drain plug magnet for 210,000 miles....So I am happy. Both fluids were near black and nasty. Front was very thick and rear was very thin and didnt have a very strong 'gear oil smell' I was way overdue to change them! (i know better)
  18. Hi Albino, Did you replace both the evap cannister and the purge control valve on the cannister? Did you use aftermarket parts?
  19. As far as Genuine Nissan Parts go, the old/original part number for the studs automatically supercedes to the new part number no matter what dealer you go to.
  20. I read a lot fo threads........too many.....it all runs together in my noodle sometimes!
