4
Everything posted by mechanicalbaron
Hopefully someone reading this is savy enough to post a link to it. I certainly have had vehicles that I wish I never got rid of. Sent from my SM-G920V using Tapatalk
Slick http://images.tapatalk-cdn.com/15/09/20/6f76ef94ddae681aa7efeeb106827ff2.jpg I would like to nominate Slick for TOTM. Video of the reunion can be found on the NPORA Facebook page. Heartwarming Sent from my SM-G920V using Tapatalk
As I understand she does now have possession of the vehicle again. Trying to figure out how to get a pic posted for it. Any idea how to ? And would that be ok? Sent from my SM-G920V using Tapatalk
If you can't then I nominate Slick for TOTM. Sent from my SM-G920V using Tapatalk
Esm=electronic service manual. Also called assist. I could also have overlooked K ohm spec. Not at work right now to double check but I think I did. As I understand it you can download the manual from NPORA. and verify that spec. Did you remove the distributor and check that the shaft turns freely? Quick and simple test and you need to eliminate that as a possibility. I've seen a lot of problems with the shaft bearings. And one last though, pull off the cap and have a friend crank it over to make sure the rotor is turning ( referring to no spark). Sent from my SM-G920V using Tapatalk
The two terminal sensor is or the ecm, if it's open it is bad. Double check to be sure. The Esm states that backfire through exhaust can be caused by a failed coolant temp sensor. Possibly you have two separate problems. Follow the esm and check the power transistor. If you know anyone else that's close or have a junkyard close you can simply swap it to check. Sent from my SM-G920V using Tapatalk
Check the coolant temp sensor, resistance should be 2.1-2.9 ohms at 68 degrees Fahrenheit, .68-1.0 at 122F and .30-.33 at 176F. Check it with the vehicle hot and failing. Forget the egr system. That is the least likely to cause what you say is happening. Did you remove the distributor and check that the shaft turns freely? Any dust or soot should not make it inside, should be sealed. Forget the knock sensor code, most likely is being set due to the problem your having. Probably should look closer into the ignition code. Check the power transistor. Follow diagnosis procedure 27 in the Esmond page ec-90 Sent from my SM-G920V using Tapatalk
Hmmmmm, yeah I guess the AAA card and water aren't technically tools so to speak. Sent from my SM-G920V using Tapatalk
Gotcha, can't seem to ever get on a real computer, not worth the fight with the wife and daughter! Sent from my SM-G920V using Tapatalk
Soooooo, how do we vote? I mainly use taptalk so I'm not sure if I'm missing something or like most I just didn't fully read the instructions [emoji53] Sent from my SM-G920V using Tapatalk
2 Sent from my SM-G920V using Tapatalk
I keep a small tool bag, 8,10,12,14,15,16,17,19,21,22mm standard,deep sockets and wrenches. Adjustable wrench, needle nose and regular pliers, channel locks, Alan wrench set, universal screw driver with multiple bits, electrical tape, wire cutters (dykes), solderless electrical connectors, assorted nuts and bolts, loctite, and some other crap. Also keep jumper cables, rope, a chain, mini air compressor, auxiliary cb radio, letherman multi purpose tool, extra starter relay, cell phone charger, 5 gallon water jug and a AAA card. Still need to put together a first aid kit and survival kit( MRE'S and survival stuff in case I get sidetracked for a few unanticipated days). Sent from my SM-G920V using Tapatalk
Yep, that's the d-ring. Really common. Sent from my SM-G920V using Tapatalk
A lot of these belt assembly have been discontinued. I've tried to replace mine on my 90 and no parts available. Even though they are lifetime warranty Nissan does state that the warranty is for the useful life of the vehicle. Basically I was told that my pathfinder exceeded it's useful life. I will say check the d-ring of the belt at the B pillar for built-up smeg, if there is crap built up clean It off and that may help. Sent from my SM-G920V using Tapatalk
Sorry we missed you guys, didn't see anything around the 4x4 practice area,figured you guys were out wheelin so we went and hit some trails. We are thinking about Rower Flats next sunday. Sent from my SM-G920V using Tapatalk
#differential.....sorry, cell phone spell check. Sent from my SM-G920V using Tapatalk
You sir have definitely gone above and beyond! Thank you! This should be pinned admins. Really good info. Recently learned what a 4 pinion different was, I had no idea. Goes to show that even a seasoned mechanic or gearhead can always learn something new. Sent from my SM-G920V using Tapatalk
Sounds good. My brother and I are planning to go out sunday. Hope we can hook up and do some exploring. If you got a CB let me know what channel. Sent from my SM-G920V using Tapatalk
I'm a beginner 4wheeler, the second time I took mine out I was with my brother in law that has experience, he pointed me to a hill, told me it will make it so I put on my "brown pants" and went for it. I was dumbfounded that it made it easily. When I tell people, it's like telling a "tall tail" that is actually true! Huge respect for these humble little 4wheelers. Sent from my SM-G920V using Tapatalk
