vagabond
Everything posted by vagabond
Speedometer & Odometer Not Spinning
vagabond replied to DesertEagle's topic in 86.5-89 WD21 Pathfinders
have both, odometer is reading 257.000 -
I think I have both a cluster and cable assembly off my 88, what part of az are you in -
havent checked yet but I think Im going to need a tranny replacement for my 88, somewhere on the forum there was mentioned an upgrade for the 5speed tranny, Im running a jdm 3.3 engine, 95 electrical from tail lights to headlights, 95 dash, and if I read the tag right it has 4.36s gears and it feels like it. any thoughts on an upgrade on the manual tranny, thanks in advance
Rear brake upgrade on an Australian WD21 Pathy
vagabond replied to ije's topic in 90-95 WD21 Pathfinders
i swapped the disc from old red an 88 to my latest toy another 88 that had drum brakes since both were almost next to each other no probs -
it was either a 01 or 02 Exterra maybe both that has the ps pump and alt in the same location as the 3.0 thatswhat I used when I id my swap
almost finished with the front suspension just the torsion bars left to install, then finish hooking up the 3,3 and she's on the road, Should have been done a year ago
Center Dash Lights Not Illuminating
vagabond replied to SquadCarPathfinder's topic in 90-95 WD21 Pathfinders
pull the center section and check the connections -
New To NPORA Board & Have A/C Question
vagabond replied to MrFister1975's topic in 90-95 WD21 Pathfinders
if you can't find a kit at any of parts stores try an A/C shop it will probably be quite a bit more but they do the complete install -
VG30 to VG33 SWAP, Step by Step Starting Today 8/26/17
vagabond replied to OH6PILOT's topic in 90-95 WD21 Pathfinders
?want another project how about an 88 with 94/95 wiring from tailights to headlights 94/95 dash and inst, cluster, all ready for a 3.3 it also needs a tranny, MaMa says only 1 so I'm keeping the white 88 5spd and she has her 95.6 mos ago I had 4 pathys sitting around here -
Removing AT 1993 Nissan Pathfinder radiator
vagabond replied to Dingy18's topic in 90-95 WD21 Pathfinders
or pull the fan and the shroud, makes it easier to remove the hose clamps and gives you a lot more room -
if you weren't so far I'd go down to pickapart and pull one for you, I've got 4 or 5 of them within about 30 miles of me
you could try disconnecting the upper and lower hoses and see what kind of flow you get thru the rad with a water hose. or pull the rad and take it to a radiator shop and have them check it
unless they have changed, the defroster lines are like a paint,there are repair kits but mainly for broken sections.your best bet is find one at pick and pull, if you have volt ohm meter check at the male spades at the top of the glass if you have continuity all the lines are good
its hell getting old; I just remembered I have a 88 Nissan Truck and Pathfinder manual all I had to do was look at page BF 38
has anyone replaced the rear side glass on a 2door I know it's bolted and probably glued with some type of adhesive
yes I'm on my 2nd swap updating to 95 wiring and dash power windows and powerand heated mirrors
on my 88 1 exploder cooler. my rad cooler is still connected but I'm running a inline tranny filter from NAPA and I'm running a tranny temp gauge no probs at almost 400,000 miles
when I did mine I used parts from a 2000 exterra the angled oil filter mount a/c bracket and ps bracket, crank pulley. I think I posted all I did to mine including a 95 dash and main wiring from taillights to headlights plus the smaller harnesses -
had a CT scan last week and I'm clear so far so good just need to get my strength back and gain back about 25 lbs
started moving parts from the auto 88 to the 5spd 88, it's been awhile since I did any work on them thanks to 48 radiation treatments and 4 months of chemo, I wouldn't wish that on my worst enemy
94 and 95 both electronic speedos, also both of my 88s are electronic, 1 has a 94 dash and complete wiring, the other has a 95
what I did on both of my 88s 1 auto 1 5 spd was change out the dash and the main body harness, a lot of work but I love the rounded dash. The wiring harness goes from the taillights to the headlights you'll also need the tranny wiring harness for which ever tranny you use. I used a 2001 xterra alt and a/c bracket and the ps bracket to get the alt and ps on the proper side and used the crank pulley from the 3.3
What mount are you using?
