mluczaj22
Everything posted by mluczaj22
  1. yeah i will have to check that. i did always tell friends when climbing in the back "2dr" watch my ecu dont step on it! but yeah with 2 of those codes alone im pretty sure it wouldnt run. i remember when my cylinder head temp sensor went out it would not start or run for nothing. i will have to look into it some more this weekend after oil change. but it yeah fine again to and from work!
  2. yeah thats what i was thinking. but it totally ran fine. having 45 alone and it will barely run. so it must of just been some loose wire....im at a loss too.
  3. heading to the gas station this morning before work. cruzing along about 40. cel light comes on. hmmm strange. havent had one in years. checked codes when i arrived at work...45,35,13,21. she ran perfectly fine 20 miles to work on interstate. reset codes before leaving work and another 20 miles with no codes or light. ran perfectly fine on the way home. just curious if anyone has had similar issue? oh and 88 vg auto. cali ecu. almost 300k on the clock.
  4. had a similar issue. was pinion shaft bearing was smoked!
  5. i dont think so at all with the design.
  6. its the egr tube. in a different spot on vg30e's. u can plug it or make a line to fit it. but if you plug it and have a cali model you will get check engine light.
  7. check codes. sounds like a maf.
  8. yeah i just wanna use aftermarket.
  9. has anyone put aftermarket tweeters in the stock a-pillar tweeter location? curious on what fits or if i have to get stock ones.
  10. mine went bad recently. from what hes sayin he has checked everything and all is good. so im thinkin the sensor. when my comp said what part was bad i replaced it and all was well. so its either shorted or open. so just replace it and call it good.
  11. if you have a maf,tps,o2 sensor,and a comp. you have 2 injectors. you have a TBI. replace maf sensor!
  12. replace maf. also check for bad injector. but bad injector should also give you code.
  13. no. stock. gonna change brushes just for the hell of it and see what it'll do. if it still doesnt work ill just put my other one in.
  14. mine just started acting up today as well. gauge was reading about 14 yesturday. now barely 12 with everything off.
