5
Sometimes brand-new brakes will get too hot and smell like that, but if they were JUST replaced, they could be just bedding in and not have anything wrong with them. Or the e-brake adjuster could need some touching-up. There is a small drum brake inside the rear discs that makes up your e-brakes.
LOL! I have pics of my friend Brian's old 89 Pathfinder next to mine, same exact thing but mine was taller and all, heh. *posts a sign in the window* PATHF1NDER RIDES $2.50 *waits for the revenue to roll in*
Second Fuel Tank Gauge Vs Low Fuel Light
88pathoffroad replied to Harbinger's topic in 86.5-89 WD21 Pathfinders
I think the secondary fuel gauge was a rare option on the SE's in 87 and early 88. Kinda like an initial-release model year specialty item. -
Derogate: I missed the last couple of payments on the forum hosting account, so I need to find some money to make it up. vengeful: Click on the arrow at the head of each topic's title. Hover your mouse pointer over it and it'll show you what it does.
Final facts: 90-95 H233B axles should have the 11-stud housing (pre-90 had 9 bolts). The 87-95 Pathfinder and 86.5-97 Hardbody (plus the 99 and early 00 Frontier excluding crew cab) were all 31-spline. The 96-04 Pathfinder, 00-04 Xterra, and 00-04 Frontier (with the above exception) are all 33-spline and not compatible with the older 31-spline diffs. There's the issue of the ABS sensor on the third of the so-equipped Pathfinder/Hardbody and the 2WD Frontier Xterra. 4WD Frontier/Xterra don't have a sensor on the third. Shouldn't really be an issue unless you're concerned about keeping ABS.
That or the low-level sensor wiring's loose.
The hole pattern is 6 on 5.5. Anywhere from 3"-4" BS works well. For 33 x 12.5" tires, the minimum width for wheels are 8".
Yeah, gas tanks are way different, along with the leaf spring/coil spring thing.
Sorry, but I don't think that option is available for this forum software. I tried looking.
Do it yourself if at all possible and save $75. All it takes is removing front tires, unbolting UCA spindle and balljoint, then reinstalling them and cranking up the t-bars a bit. However, if you need longer UCA spindle bolts be prepared to order them from the 'net, cause 14mm x 1.5 x 60 or 70mm bolts are HARD TO FIND. (stock size is 14 x 1.5 x 50) They're about $4 each, and you'll need four of them. Try to get Grade 8.8 or 10.8 at least.
Here are the current forum modifications that have taken place today: Changed forum header and HTML body tags to reflect forum NPORA name and title. Added subforum to Garage section for pinned Tech articles/threads. Added new section for "Discussion By Model Year" and moved all year-specific subforums into it. Added subforum for 2005-up R51 Pathfinders. Moved "NW Chat" subforum to the "Community Corner" section and removed the "Northwest News" section. Re-synchronized all forums to reflect deleted or moved topic and posting stats. If your post count changes a bit, just go with it and keep on posting. I haven't moved or deleted that many threads. NPORA forum members with more than 500 posts can now choose their own custom title! -BUT- If it's inappropriate or admin doesn't approve, remember: that right may be revoked. Accessing that option is in your user control avatar/title settings if you have 500+ posts. Standard issue rank titles are as follows: Turned on the user warning level indicator system. If you recieve a warning from a moderator or administrator for misbehaving, your level will go up by one bar and 20%. Three warnings and you get a little vacation from the forums. Five warnings and you get banned. Warnings can be both given and taken away. Now EVERYONE can see if ANY one person gets any warnings. Sound easy enough? Please refer to Jim's Forum Rules for things that will get you in trouble. Changed some cuss word substitutions in the forum "Bad Word Filter" system. Now it's a bit more realistic. Please still do not cuss, be civil when posting. See the above mod list post about "User Warning Level Indicator System" if you want to post messages that deliberately go around the word filters. Avatar size increased to 120x100 (was 64x64) Uploaded avatar image size is still limited to 20K. Personal picture size limited to 200K. (was unlimited) Personal information in profile size limited to 500 characters. (was unlimited) Signature size limited to 500 characters. (was unlimited) Uploadable picture extension types added: .BMP and .SWF Turned on thumbnailed uploaded images when posting to save page load times on slower computers and for dial-up users. Thumbnail default size is 200x200 pixels. Simply click on the thumbnail for the fullsize pic. Maximum per-post size limited to 750K. (was unlimited, that includes pictures, text and emoticons) You may now upload Flash movies for an avatar or post if it's under the size limit. Turned on word wrap to prevent excessively long side-to-side posts. Turned on Quick Reply option in forums without it. Set number of threads AND posts displayed per page to 20. (was 15) Your page counts will change accordingly. Don't worry about it. Adjusted last displayed post date in several sections to 60 days. (was 7 days in both Classified:For Sale and Classified:Wanted) Changed # of clickable smilies in Reply screen to 5 rows instead of 3. You can now choose any available smily from the Reply screen instead of having to open a new window. Changed server time to reflect NPORA's home server location: GMT - 8 hours: Pacific Coast time for Vancouver BC, Washington, Oregon and California. Cut Search Post Return text limit to 200 characters. (When you search and have it return posts with text attached, it no longer displays the entire post, just the first 200 characters.) Changed default Search option to Simple mode instead of Advanced. Various other tweaks. You get the idea. Let me know if you have any other ideas or suggestions! -88
I'm working on it!
Um, no body lifts for a Unibody vehicle. Just suspension lifts.
Sounds like your t-case position indicator switch (or it's wiring) shorted out on you or was otherwise damaged. The transfer case operation is entirely mechanical except for the indicator light switch.
Thanks everybody. I've already started the forum tweaking...watch for a post with the details.
You're welcome. Have fun!
Well, only if you LIKE doing it yourself. That kit actually has all the stuff you need with none of the mess and guesswork. It's about the right price, all things considered. I just added up all the stuff you'd have to buy to do it yourself and it's about the same.
Oi, no wonder they're so cheap. Are there zerk holes drilled and tapped already?
Yeah, they're tough sumbitches to get off. Even more fun to put back on. Watch for that later. I suggest more PB Blaster or WD-40 and time. They DO come off, but evidently yours don't want to.
Hmmmm. Carrying anything inside on that side? Can you measure to see how much of a height difference you're getting? Coil springs do sag over time and new coils will settle in, but not by THAT much.
They're heavy, but you can put it on a pallet, wrap it in Saran Warp and tag it, then a motor carrier can ship it for pretty cheap. It's just a PITA to transport it both to and from the trucking company.
Glad to be of help! Ask and ye shall recieve.
So, how bad of an idea is it
88pathoffroad replied to BigBikeMike's topic in 96-2004 R50 Pathfinders
The simple answer would be to drill another hole in the hitch itself so the rack slides in far enough to fit properly. I can't vouch for the hitch's towing capacity after that if the holes are too close together, but it should still be good for towing stuff that the Pathy can tow in the first place. -
I had my Pathy packed to capacity to go to work in Cali once...gas can and cooler on the roof, inside packed full of all my tools and clothes and stuff...went through a weigh station, it was at about 5100 lbs. Last time I went camping with me and the GF in the Pathy and all our stuff(including offroading crap) it weighed 5150 lbs.
Wierd Transmission Problem
88pathoffroad replied to RealDealNamowicz's topic in 90-95 WD21 Pathfinders
A stripped input shaft would probably make some nasty noises. Same for a broken input shaft, but I've never actually had that happen to me before.
