23
Everything posted by silverton
Yeah, but the cool thing about Super Blue, if it were still being available, is that you get to run the same spec'd brake fluid, but know positively when the old stuff is out. Start with blue, replace with amber. Start with amber, replace with blue, etc etc
Under the same name even!
Just because someone claims they are older than I am, does not make them more knowledgeable.
Well, 100% of my Pathfinder's have not had working handbrakes, and it seems to be a fairly common thing. What's the percentage of statistics that are made up anyway?
You do them one at a time just like a regular bleed, and it works on all five of the bleeders. Set it up like you're about to bleed them normally, but instead of pumping the pedal, leave the bleeder open until the bubbles stop. Once you don't see bubbles, close the valve and move to the next in line.
Seriously try a gravity bleed. And probably 98% of Pathfinders don't have a working hand brake.
Super old, and a bit of a stretch, but there is snow on the ground! silverton:
- 5 replies
- nissanpathfinders.net
- NPORA
(and 3 more)
Tagged with:
So people keep telling me.
How are you bleeding? I recommend a gravity bleed as the brake pumping on/off thing has given me mixed results across several vehicles. Gravity bleed has never failed me and usually gives you a firmer pedal, only downside is that it takes much longer.
Those systems are wired to bypass a starter safety if equipped, which is why it's imperative if you have one, you leave it out of gear when you plan to use it.
Says the guy who doesn't wheel his truck. What's the reason for the switch then? Why would Nissan include something to bypass an obvious safety feature? So that curious blokes would use it and take themselves out via natural selection?
Oh really? I was looking in to getting the Super Blue when I upgraded the brakes on my S12, but that was about 2...2.5 years ago.
Trouble finding emergency brake parts.
silverton replied to MrEviLDeD's topic in 90-95 WD21 Pathfinders
I believe the parts are only available through Nissan. -
I'm just being an ass. Facebook NPORA group member asked why his truck shimmied while in four wheel drive on bare pavement. I said he needed an alignment. He didn't like that answer because he had just gotten one, two weeks ago. But he went wheeling this last weekend, so it should still be good right? That's when I said it's recommended to get an alignment after every trip off road. He still didn't like my answer. That's when another group member popped in and said that I must work at an alignment shop and that I don't know what I'm talking about because he's been wheeling since I was just a baby. Which I'm sure I've done more wheeling in four years than he's done his entire life. Either way, the OP ended up deleting the post after he asked me to stop telling him he needed an alignment.
Right, and the interlock switch bypasses that safety so the truck can be started in gear. A starter is only going to spin the engine at around 200rpm, whereas if you try and use the clutch to obtain that RPM while the engine is running you're going to lug it so hard the pistons slap. Essentially, a built in crawler feature. He's asking what the switch does, and I'm telling him the intended use of it.
I really like the Castrol GT-LMA brake fluid. it's DOT3 with higher specs. If you don't tow anything you'd be fine with just the standard store brand DOT-3. If you tow or just want the extra confidence of a higher rated fluid, get something like the Castrol LMA or if you feel like getting extra crazy, opt for the ATE Super Blue stuff.
I have an automatic, so no I do not. It's not a matter of killing the engine while wheeling. It's being able to spin the engine at low RPM while still having the transmission directly connected to the engine. Too much rpm can cause a tire to just slip and spin, where doing something at a lower RPM can be just what you needed to get over the minivan sized boulder. Why put a second transfer case in a rock crawler? Because then engine RPM's can stay high while wheel speed stays low.
To me the only advantage of having the interlock switch is being able to crawl over obstacles without lugging the engine or causing unneeded wear on the clutch.
I call it a proportioning valve cause it's not much of a "unit" just an annoyance in the brake fluid flow.
I don't know much about the manual gearboxes in these trucks. Is it not the standard 1/2" square hole like most differentials are? Usually have to get a pick or screw driver to clean it out.
Some more information includes, but not limited to, I work at an alignment shop. And someone who is smarter, more experienced, older than me has been wheeling longer than I've been off my mothers tit.
I got an alignment two weeks ago, so the alignment is fine. I took it wheeling this last weekend and had a grand ole time! To get out of my driveway today I needed to put it in four wheel drive. The roads are bare but it shimmys on the road while in four wheel drive. But the alignment should be fine, because I just got it done. WHAT COULD IT BE???
the LoadSensingValve is on pickups only. Basically it increase brake pressure to the rear as there is more and more weight put in the bed of the truck and makes the suspension "sag". The proportioning valve is on Pathfinders and decreases pressure to the rear brakes when it detects a wheel locking under heavy braking.
I'd take it somewhere that has an impact to remove the drain plug. As far as adding fresh fluid to old fluid it should be okay. Just make sure it's the proper GL number because I know the newer stuff will eat the bronze.
Some help with the correct harnesses to unplug
A few feet? dang! I know for sure you'll need to disconnect the fuel pump harness which is located just behind the fuel tank on the passenger side. Probably need to disconnect the brake line that goes to the rear axle. I don't know how much extra length there is for the ECU harness that goes through the firewall. The differential breather hoses will probably have to be disconnected as well.
