4
Simon last won the day on April 27 2023
Simon had the most liked content!
About Simon
- Birthday 08/09/1979
2000 Xterra Xe 33"MT's, 2" BL, 3" Rancho SL w/Rancho 5000's, TK1 Steering mod, ARB Winch Bumper Hella 1000's, WARN Premium Manual Hubs. Bender built sliders and rear bumper/tire carrier
I Wish I had a Pathy!
2000
Contact Methods
MSN
solkowicz@hotmail.com
Website URL
http://www.canadianpathy.com
Gender
Brampton, Ontario, Canada
Country
Canada
Interests
Pezzy, Hockey, Baseball, Golf, Wheeling, Wrenching
Simon's Achievements
NPORA Old-Timer (5/5)
30
Simon changed their profile photo
Agreed on trying a gravity bleed. I had an issue after replacing a caliper where my brake and ABS lights were on, and I had NO pedal pressure. No amount of "standard" bleeding seemed to help. I ended up gravity bleeding in order, and the issue sorted itself out.
MT's and hard pack or ice DO NOT mix. You may as well be rolling on marbles.
Your issue could be the electrical connections on top of the sending unit at the fuel tank. They get corroded over the years, and start to short out. I had to replace the sending unit on both of my Pathfinders because of this issue. There should be an access panel for it under the carpet in the cargo area.
anybody change a distributor lately
Simon replied to River044road's topic in 96-2004 R50 Pathfinders
I did one in my X a few months back. Rockauto even with shipping and duty was cheaper than I could get it anywhere in Canada. -
Modding an ARB Bumper, Advice?
Simon replied to bulletsforringo's topic in Solid Axle Swaps, Hardcore Custom Fab
The WD21 ARB bumper doesn't have separate mounts. They're integrated into the bumper. That said, I, along with a few others, successfully relocated their ARB bumpers after a body lift, so fabbing up a couple of mounts should be relatively easy. The big thing is to tie into the frame at 2 points, in order to distribute the load if you're going to winch or recover using the bumper. Otherwise, it can "peel" down if it's only mounted low. This thread has a bunch of pics of the mounts for the WD21 ARB. http://www.nissanpathfinders.net/forum/topic/26160-arb-pictures/?p=480700&hl=%20arb%20%20bumper&fromsearch=1 -
I've merged the 2 topics, and moved the 1 left into the general forums. As for leaving, don't bother. If you enjoy it here, stick around, offer help, and participate like you always have. Pathfinder ownership isn't a prerequisite......at least......that's what I keep telling myself.
Personally, I'd go with the complete arms. For $200 you can't go wrong.
Great work Steevo!
87 twin turbo sas 1 inch lift...
Simon replied to AK9849cy's topic in Solid Axle Swaps, Hardcore Custom Fab
Split off the gun posts into their own thread.... http://www.nissanpathfinders.net/forum/topic/34532-ruger-1022-split-from-grandpaxs-87-twin-turbo-thread/ -
I've also got a 1000w inverter, and it's installed on the back of the rear seats. I've run 2awg wire, both positive and negative, from the battery, through a 100a marine breaker, to the rear of the truck. I'm quite sure the instructions on mine called for wiring right back to the battery. At any rate, that was the best spot I could find to mount it. Mine, however, has a remote on/off switch (I've yet to install it in the X, but I had it in my WD21). If yours has that option, as well, you could theoretically mount it anywhere, and run a power bar in your center console, or other convenient location.
It's possible the crank angle sensor or camshaft position sensor is throwing causing your no start condition. Check your codes. Your spark timing could be way off due to either of those sensors failing. If you throw a timing light on it while you crank, see if it's in range.
RedPath88 has been, though I believe there was a donation from a member here as well. Running costs are far less than they used to be since the move off IPBHOST servers.
RedPath88 and Pezzy are the site Admin. Moderators most often online are myself, Precise1 and nunya.
Lol. Reading is key. I didn't see it in the original post, and I skimmed the responses. I fail.
