kmgar99
Everything posted by kmgar99
  1. I decided to pull apart my intake tube to check the MAF sensor for damage or dirt....so I decided to remove the whole tube from the Throttle body and all I saw inside was black! It looked really dark and crusty.....I seriously want to pull it and clean it I know 88 had his polished, besides replacing the gasket how hard can it be????
  2. We have them here in SoCal a lot....I tried one ONCE! Much bigger than it looked and really soft too. Buried the Pathy up to the tops of the wheel openings....
  3. POR 15 will definitley stop any existing rust from occuring, I did some on the front half ofthe frame on my 1970 Chevelle and it worked and looked great. I used to get most of my body work stuff from Eastwood....free catalog and decent prices EASTWOOD
  4. I don't know man....but I would love to get some tips too.....I was going to mount mine to the roof rack cross piece. As far as wiring goes....
  5. Definitely check the fan, and if you replace it, you might consider an electric instead of the HP robbing clutch style. Also check the idler/tensioners for a bad bearing...a bad bearing could cause excessive drag on all the items connected with that belt....You can check the bearing by removing the belt and trying to spin the item by hand. Also check them by trying to move the item up, down, side to side for excessive wear.
  6. Perfect Picture...thnx....time to get to modifying mine
  7. Also try the Tire Rack if you really want tires online. Tire Rack Click Here Also check out some of the ads out of the 4x4 Mags.
  8. True, but I think you done went and insulted Pezzy... Hmm, would that apply x2 for her ?? B Hey Pezzy, you're not a red-headed step-child are you? If so, I seriously did not mean it. Am I forgiven? red headed, and i do have a step-family... I'll be ok... eventually the trauma will wear off See this is why this board rules! No one is trying to hurt anyone and everyone seems to get along.....God that sounded Sappy! Sorry.....(Hanging head in shame)
  9. I like it....i'm in for a few.
  10. Hey Dean, did you have an added section welded in to gain thickness for countersinking the bolts?
  11. LOL....My wife is too short to even get in my Pathy....Some say that's a bad thing? I beg to differ.... You're a lucky man jj big shoe....she's a keeper....... BTW she can chime in every once in a while, we don't mind.
  12. Great Idea! Time to get working on it
  13. Hi-Lift Collapsable military trench shovel Change of clothes basic tools bailing wire 4 Fire Extinguishers (2-5lb and 210lb...this is SoCal, so gotta watch the brush fires) Glock 25 with 3 clips 4-4" straps 4 shackles No CB yet Work Nextel Cell phone good walking shoes Sunscreen (No wool blanket or tire chains needed here)
  14. If it wasn't for those PIA bolts, the job is fairly easy.....I'm glad my posting helped.
  15. 88 hit it on the nose along with....Lots of time, $$$$ and frustrations. Remember your truck is a unibody and with too much HP you'll twist that thing so bad you'll never open a door again.....if you can find a way to keep an axle under it. You might want to rule out too much HP and keep it mild. I say go for it.....lots of friends, call in all favors and who knows..... I've thought about it too....when I still had my Chevelle I wondered many an afternoon, what it would take to squeeze my 307 into the Pathy.
  16. I have a 97 SE and I have and indicator on the dash...not sure where, but I see it all the time while i'm out wheeling. I have front ABS only, the proprtioning is controlled by some rear end height tension spring thingy. I'll find the topic.
  17. I get 14-15 driving 40 miles through the hills of SoCal each way with 32's and a 2" lift! OUCH! Doesn't help that I drive like 80-90 MPH! Probably get 15-16 if I drove normal.
  18. Now make some strut spacers and raise that front!!
  19. Looks good! I squeezed the 32x11.5's with a little bit of rubbing.
  20. That's very intersting! I gotta read the test data more closely, but it seems those so called crappy filters I buy at Wal-Mart every other month, might not be so bad after all. The guy is correct at the end, more airflow "IN" will not always produce more horsepower or torque. Unless you utilize that additional flow of air by tuning it up with new ignition components, and a new free flowing exhaust (with Headers). My idea is to keep the stock box with the usual crappy filters, but grab the incomming air from the front grill, hopefully in front of the radiator...one of my many projects that'll probably never get done!
  21. Rivets???!!!! Where? I didn't see anything resembling rivets anywhere around my upper strut mount....I have a double thick sheet metal spot welded together....That's how mine is put together.
  22. Don't they sell bombs for mice and rats? Or are they only for cockroaches and ants?
  23. I don't think it was you SLICK. I was in Vista on my way to work
  24. Yesterday on my way to work in Vista California, I saw a Blue older model Pathfinder, and I swear it had an NPORA sticker on the passenger side. Was this anyone here? I didn't think anyone lived by me!
