221
Everything posted by adamzan
Grease the steering stoppers on the control arms.
I agree, mine is leaking at the flange right before the o2 sensor and it runs OK, but I can tell it isn't right and the gas mileage is reduced.
Or no oil.
Oem nissan shocks are made by KYB, and most last well over 200,000kms so I don't think they used the cheapest.
Did you put the timing belt on too tight? I know it can make a nasty whining noise.
I agree, your timing cover is completely sealed. Mine was mudded like that and there was nothing under the timing covers when I took them off recently.
There are 3 part sources local to me and the people that work there are decent but they never have any parts in stock for the wd21...There is a place here called CAPS and they have everything and if they don't they can get it in an hour or at the latest the next morning. I find the CTC in smaller areas (brockville, kemptville) are terrible especially with non domestic parts since most of the workers there are hicks who don't give a crap.
I think that is actually what you are supposed to do. Get everything set in and then tighten it down to spec. The smoke is the 2 dollar rattle can paint pacesetter uses burning off.
Look on your drivers door jamb it will say the month and year it was made.
It won't make any difference on yours. The manual hub swap is for r50s that have full time drive flanges so their cv axles are always spinning.
What kind of exhaust are you looking for? Stock replacement? You can get a new muffler/tailpipe assembly at crappy tire for 160 dollars. If you want something more free flowing you'll have to go custom but it's nothing a good exhaust shop couldn't do.
Custom 2WD steering system conversion
adamzan replied to Tungsten's topic in Solid Axle Swaps, Hardcore Custom Fab
Agree with Simon 100% as well. All the stabilizer does take a lot of the feedback out of the steering wheel and keep it from wandering as much on rutted roads. I have driven my pathy with and without a damper, on and offroad. It sure feels nicer with the damper but my @!*% still wore out fast from wheeling. -
1. You're probably right, I would check the ones that support the muffler as they have broken on me twice over the years. Replacements are only about 5 dollars last time I checked. 2. There is a small fuel hose that connects the 2 fuel rails you can see it behind the distributor cap. Mine was leaking a bit and I could smell gas. It's a 4" (roughly) piece of hose. 3. Could be the T-belt is a little too tight. I've been told that there is a break in period for the belt although I never noticed it on my rig. What you can do is take off all the accessory belts (one at a time) until the whining stops. Is it like a whirring kind of whine? 4. Mine used to do this too and it was intake boot that had small little cracks in it.
You know what works better is replacing the plugs, wires, distributor cap, and rotor. Then you won't have a "tired" ignition system. It's maintenance.
Check to make sure the drain hose isn't clogged, you can see it on the passenger side of the firewall.
I am 95% sure that the long ones are the starter bolts, but it has been a while since I've been in there.
Wrong. Mine was made in japan.
I've got one of those! Number 76 of 300 There was also a Warren Miller edition. Came with ski racks and stuff.
I know the timing is supposed to be at 15. I'm having the same problem, my pulley is a 7 marks and I assumed the first was TDC but I am starting to think this is not the case!
Try these guys http://bandit4x4.com/4x4-truck-parts/steering-parts/idler-arm-bushing-replacements/
Switching out drive flanges for auto locking hubs.
adamzan replied to rwd5021's topic in General Forums
You can, but you have to modify the spindle a little bit. Precise1 tried and there is a thread around here somewhere on it. -
Some filters can make a big difference in how fast the oil pressure comes up on startup.
best radiator for R50 Pathfinder / QX4 ?
adamzan replied to FUELER's topic in 96-2004 R50 Pathfinders
This place seems to have an all metal one listed for the r50: http://www.radiatorbarn.com
