madhornet
Everything posted by madhornet
and the reverse issue was common there is a fix but its a very detailed fix not for the average wrench turner
out of time either change the distributor or check to see if u jumped a cam or the crank with the timing belt did u get it like this or do any work or did it just start up like this one day?
Anyone got an r50 rear DS laying around?
madhornet replied to sammyb33's topic in Solid Axle Swaps, Hardcore Custom Fab
ok i dunno how to upload pics from rear mount flange to center of front u joint is 39 5/8" to front flange dust shield thing(4" diamaiter thing) is 41" and what fits inside is from about 41 1/2" to the end total length is 46" -
rule of thumb is use what u have in your tranny but i went 10w30 in my tcase even though i had an auto tranny its too cold in the winter here for 80w90 in the tcase it is so thick it will turn the front drive shaft and try to engage the auto hubs in the cold for a daily driver i would have used the atf but it is for hardcore offroad so i wanted the thicker protection cause i run 33"s posi up front and locker in the rear
will do tomorrow i hope been home sick -
i just took one off will post up later tonight hopefully -
air and fuel filter i have also had to clean my maf element also had the air tube from the maf sensor to the intake crack and yes a leaky exhaust will loose power especially noticeable from the cat to the engine
very straight forward if u have done this sort of thing if not youtube
Distributor if it is coming and going
yeah just found out my 98 is back by the fire wall under the blower motor with 4 wire connector the 97 donor truck had it behind the glovebox with 3 wires i do have another 98 donor truck for parts but have to drive to go get it thanks everyone for the fast help!!!
and also how can i change the resistor its self?
ok i will try his motor i have it too but i was told everything was done by the switch?
so i put in a used heater switch that the owner said it worked fine but still i only have the hi setting working could he have been wrong or is there something else that can fail?
3.0 Distributor Work in a 3.3?
madhornet replied to Dizer92Pathfinder's topic in 90-95 WD21 Pathfinders
VG30E WONT WORK TRIED BEFORE DIFF ELECTRICAL BUT IT WILL BOLT IN -
GET A TRANSFER CASE DOUBLER EASIEST THING AND THROW IN A FRESHER 3.0L THIS WOULD BE BEST FOR OFFROAD OR GO WITH THE SUPERCHARGED CONVERSION FOR A DAILY DRIVER WITH LOWER GEARS
Possible Tip From New Guy (Air-Flow / MPG)
madhornet replied to KTempleton's topic in 96-2004 R50 Pathfinders
I HAVE BEEN DOING THIS FOR YEARS TO ABOUT 9 NISSANS NOT ALL MINE BUT IT MAKES A DIFF IN MILLAGE AND ACCELERATION VERY NOTICEABLE USUALLY 2 3" HOLES I DO -
YEP DISTRIBUTOR FIRST THEN CHECK TO SEE IT THE TIMING BELT JUMPED ALSO THE WOODRUFF KEY ON THE CRANKSHAFT THAT KEEPS THE HARMONIC BALANCER IN TIME CAN GO BAD GOODLUCK
you could buy them like that from Toyota wish Nissan had of made one
the extra one u found is for AC
agreed
great pic that makes it easy LOL... i have done this and it is a very slow process but it does help it was an easy 8 hour job with 2 very skilled grease monkey's
you should be using 5w30 it will have more lube capabilities in the cooler weather for the lifters at start up also i have a pathy now that has been doing that for 8 years almost every start up
Starter problems? or... ? newbie question
madhornet replied to andrewcconti's topic in 86.5-89 WD21 Pathfinders
what u are describing sounds like a leaky injector or possibly a bad temp sensor do a search on here as these Nissan's have a self diagnosing ECM Goodluck -
Need new rear axle assembly - '93 SE
madhornet replied to deanpence's topic in 90-95 WD21 Pathfinders
yeah get a junk yard complete unit just check your door jam gear ratio 1: hg46 or hg43 2: next make sure u match if u have drum brakes or disc 3: decide if u want an lsd or open diff, u can go either way with the last one LSD is determined if in neutral and t-case in neutral that the both rear wheels turn in the same direction or open diff they spin opposite like i said open diff or LSD is a personal choice and make sure the oil in the rear axle is clean so u dont have a repeat issue i wouldnt rebuild one around hear u can get a junked unit for around $200 -
coolant temp sensor would be the next check
