MikeV
Everything posted by MikeV
  1. MikeV
    What do I do?
    Y'all be a bunch'a ignorant Krackers!-)
  2. Mine isn't that bad, my first 95 was much worse though Welding is fun as long as it isn't your occupation!-) I enjoy it
  3. I'm having the same issue, after I took off my rear sway, I got enough flex to hit my bumpstop (cracked the frame there) grinding away and got 3/16" and 1/8" sheet and angle to fix it.(mostly 1/8" except where hitch will bolt in) I'll take pics also.
  4. It got real warm here all of the sudden...
  5. I gave up on that when I broke my sternum on a halfpipe at 32, now I only break bones when gas powered engines are included... ATV is a skateboard with an engine, wrist has screws and a plate to prove it!-) I need a plane! Hope all is well!
  6. /\ is correct, but torches are fun < lives by the code of the airtool!-) \/ Likes to blow things up
  7. going to burn some tires and trees tonite (aka scandinavian X-mas tree) In protest of treehuggers everywhere!-)
  8. get an air horn or a train horn!-)
  9. /\ would rather drink wine than whine < is pulling off the gas tank and the center bolts are rusted bad and spinnin' \/ thinks I should use a torch to loosen them thar bolts (lol)
  10. If they are different you will have to swap front and back (they need to be same ratio or they will make real kuwl sounds with the front and back going at different speeds!-) till something broke.
  11. Welcome, also won't abuse you on the Low Rydah decision. Well maybe a bit!-)
  12. /\Still hurting from 2 many beverages < Werkin hard cruisin the web while it is slow at work \/ Hates Mondays
  13. ARB or other heavy duty bumper will protect it well;
  14. 4.3 & 4.6 in the US models, the info tag under the hood will have it on the plate 4.33 or 4.66 or whatever yours has.
  15. ^ is right as usual <uses kevlar and wishes he was 1500 miles closer to The Dunes Vwants to go to the dunes also
  16. ^ Likes the smell of gunpowder in the mornin' <just pulled the 6ft flintlock off the wall to fire and clean V is working very hard at not working hard
  17. ^is correct < 4 pints of Guinness and BBQ is over V Likes warm wine!-(
  18. Cliffs is nice that there are really no hidden rocks, but mudd enough to make you cry for joy, and the hills are fun also. I didn't get stuck and I only have LSD diff and front manual lockers. Just make sure you can get it in 4 lo after the lift!-) I was in the parking lot with a BFH (hamma time) doing a little fab work to the body to get it in low... We will be camping at the campground next to Cliffs all weekend, forgot the name but will post it later. Mike
  19. Nice! I like the press also; have one about 1/4 the way done, as my anvils and vice are cavemanish
  20. Guys out-voted me and switched to Cliffs!-( Have to update the MXO thread You better pack up that D.O. and make me some dinna! :tonguefinger:
  21. Just 4 that I'm bolting and welding Your Both wrong-right!-) I'm welding mine, if it were a new frame bolts would work... but living in the rust belt is rough on the frame (curse you salt!-)
  22. rip one off a Liberty!-) even has the purty lights...
