sammyb33
Everything posted by sammyb33
  1. i like the look but i hope the hole for the hitch pin is not to close to the rest of the bumper....gonna make fastening that hitch pin clip a pain....
  2. keep me updated. I have tx10s and transmissions piled up like cord wood out here.
  3. Those hooks are not meant to be pulled from. Those hooks are meant for tie downs when the vehicle is being towed (as in on a roll back or a multiple car hauler). They were not meant for the shock load or the multiplied load of pulling out a stuck vehicle. That being said, I have used those before to pull myself out (and others) and they worked fine, just bent up a little. Nissan has to put a disclaimer on it because it was not designed for that use.
  4. So i take it there are no r50 owners out there who own a tape measure??? Not suprising, those of us who have frames usually do the mod work
  5. I moved my rear axle back when i re-did my rear end with leaf springs, and now i need another option for a rear driveshaft. I have one out of a 89 standard cab hardbody that works for now, it was about two inches longer than my WD pathy. But, it only barely catches the slip on the transfer case and with any flex it falls right out lol. So can someone measure a r50 one for me from flange to slip so i can see if this will work for me? or if its on your truck you could measure from joint to joint for me and i should be able to make a decision that way. I would like a cheap option for now, i would rather not have to get one made because I am hoping to do a doubler or maybe do the NWfab adapter to run a 6 bolt tcase in the future once I get this thing back on the road. So, measurements please?!!?!?!?!?!?
  6. so are these plates for the entire sides of the frame? or just the trouble spots? I cant find anything on their site, not even those part numbers come up at all.... nevermind. i posted to quickly. i found pics on the PDF, like you initially posted. i just need to read better!!
  7. I tried to message UNCC about this, but it seems he cannot receive any new messages....full inbox maybe!! What I have are two hardbodies, a 95 plagued by frame rot (badly, I just patched a place with a 12 inch frame patch, and I knew it wasn't going to last because there just wasnt much there to weld to, and yep its already showing stress cracks)and an 87 with a perfect frame, but an engine that is unknown and has sat since at least 1999. Overall the 87 is in pretty good shape. But I think since my 95 runs so damn well I just want to swap frames! So I was hoping to get some insight on the TBI to MPFI engine/dash harness swap. I have been trying to come up with ways to do this, trying to figure what would be the easiest/cheapest. My thoughts were, to pull both cabs, swap the engines, and then drop the 95 cab on the 87 frame. This seems to be the easiest way to me. My only thoughts were, what am I going to run into with other wiring on the truck? I know I will have to at least swap the VSS on the tcase, if not swap just the whole case. Both trucks are 5 speed, I would just as soon keep my transmission that is in the 95 because it was a rebuilt unit from a 99 frontier.... In reality I think I could pull the cab, then pull the engine/transmission/transfer case all as one and then drop it onto the 87 chassis..... What am I missing? Let the comments and concerns roll
  8. Used to happen to me as well, sometimes in deep water crossings my alty and brake lights would flash for a second until the alty spun all the water out, seemed like it just did not like getting wet. Do you happen to have some splash shields removed so the puddle water can splash all over the alternator? If so I would say that is the problem, this may not kill your alty immediately, but it will harm it over time....
  9. Stocking up on fuel pumps? Are you really expecting to replace one in the near future?
  10. A lighter flywheel is also going to hurt you in the rocks....when you are letting your clutch slip while you have only a couple hundred RPMs climbing up a rock, the more weight turning on your driveline the harder it is to stop and stall...
  11. Got it, yep, i was looking for somewhere on the engine itself. or on the fender near the washer fluid bottle. I had not looked under the intake tubing. Ill get it there tomorrow and see if I have spark... It really is amazing, this truck has very minimal rust. body rust, I havent found any, only rust I have found is in the bed, but I believe that is from all of the crap sitting in the bed since it was parked in 2000..... thanks for the quick replies, Ill keep you updated....
  12. Hey, I am working on getting a nice looking 89 Hardbody running to replace my 95. It has been in a JY since 2000 but when i slapped a battery in it, it turned over nicely, the oil was fairly clean, and overall the truck is in really nice shape. My friend who owns the JY told me he bought a whole lot of trucks and cars off of a woman who's husband had recently passed, but he owned a towing business and often kept cars that were towed and not wanted anymore. He was told this one needed a fuel pump, or a coil, he was not sure. Either way I am assuming the owner of the truck put the cost of the repair above the worth of the vehicle. It only has 140k on the ODO, and everything seems to work electronically. But, even though it turned over, I did some more poking around and found the coil was pulled out and mounted onto the radiator support, plugged into the dizzy, but the harness plugs were obviously unplugged. So, can someone point me into the right direction and tell me where it should go, i have looked (a little, I didnt have much time) and could not see obviously where it should go. A picture would be awesome but a really good description would be helpful as well. I would love to get this thing on a trade and be able to drive it out of the JY. Thanks!
  13. Yea, staying on 31s i dont see any strength problems with welding up the diff, aside from the expected wear that happens in result of the welded rear. You'll be fine
  14. i would love to see pics of that...
  15. When the time comes I am going to put the molded vinyl back into mine. I love it in the farm trucks it cleans up well and still gives you the sound dampening of carpet because it has a back to it. Or at least those do for the chevy trucks.... If it does not come with a back i will dynomat the floors and then lay the vinyl on top of that....
  16. buy a locker and a high lift and or a come-along. best of both worlds....
  17. I also love rainX, and as far as the chattering wipers, try putting rainX on your wipers when you apply it to your windshield, seems to work for me. I LOVE rainX and just for the record I use the wipe on stuff, as well as the washer fluid....
  18. Ok, I have not seen this hole in person, I was speaking as to what I thought was the case. I have seen install pictures, and read the directions, and seen calmini's install pictures. It does not, and did not, to me look like they drilled a hole any bigger than the thru frame shackle mount, because for all I could tell was there was just a weld holding the tube in place, not multiple passes as filler weld. **EDIT**: I questioned your comment on the High steer, but forgot my axle is mocked up moved forward, so no problems with clearance....
  19. So, the Legos are a 7 inch width rim. With an offset nearing an inch. so the centerline on the legos would come to 3.5 inches. Add the offset to that, making it 4.5 inches of backspacing. The Steelies are a 6 inch wide rim. With an offset a little more than an inch. so the centerline on the steelies would be 3 inches. Add the offset to that, making it 4.20 inches of backspacing. Both PROVING my point about them not being 3.75 inches backspacing.
  20. You are wrong. flat out wrong. go look at your stock legos, they are not 3 and 3/4 backspacing. no fawking way. just take a tape measure and eye it, and you will see it is no where near that, but is more like and inch or inch and a quarter more than 3.75
