Casey.T
Everything posted by Casey.T
  1. Your showing me all the things I get to look forward to once the garage warms up a little.... no fun working in 33deg F....
  2. Might have to upgrade to a Spotter..... As for ranking: Strength: 128,276 [Ranked: 630] Agility: 209,447 [Ranked: 507] Guard: 68,338 [Ranked: 685] Labour: 22,951 [Ranked: 852] IQ: 12,510 [Ranked: 962] Rig Strength: 26,701 [Ranked: 701] Rig Ability: 24,818 [Ranked: 675] Total stats: 493,041 [Ranked: 661] and I dont have any will bottles... so its 1 good train a day, then the rest is kinda futile.... i need 299mill for a nuke shop... Upgraded to Elite Competition Shop friday night....
  3. Im pretty sure you can.... Now your going to make me go look at the 2, 60mm tb i have from a Max VG30DE.... They are for my 300zx VG30DE
  4. Your Rigs Equipment Trail Tools Dual Air Winch Tires Comp Cutters Engine Small Block Turbo V8 T-Case Military Single Rig Armor Exo Cage And I cant make the Cliff, Shocker or Rubicon.... Guess I need more Ability and Rig Strength Your Rigs Equipment Primary Weapon Shoulder Percussion Secondary Weapon Portable S.A.M. Personal Armor Passive Assualt Armor ^^^ all the reasons why K9 Thinks im a play toy.... That and I have not broken 200k on any of my stats...
  5. I put a disclaimer on that.... 3.5 motor would be nice....
  6. Best way to improve your R50 is to upgrade it with the WD21.... Sorry I could not resist...
  7. If you removed the Distributor and you were not at TDC, and you just tossed it back in... ya your not gonna start unless you are reallllllllllyyyyyyyyy Lucky.... Timing reset time for you... and its not like Windows... turn it off then back on and it works fine... front timing cover is going to have to come off so that you can align the timing marks and then reset the distributor...
  8. the other end of that plug on the back is prolly hanging down around the trans... if you have your hood off you can look straight down and find it.... In the future loosely zip tie it to the knock sensor wires... wont have to reach down as far.... NO SILICONE>>>> Just torque the plenum on per the FSM... I take the torque requirement divide it in half and torque in 2 stages....
  9. 2 bolts and that plate comes out... then use about 24" or so of extensions and have the ratchet hanging out in front of the CL where you got lots of room...
  10. and you might find something like this..... http://www.nissanpathfinders.net/forum/index.php?showtopic=12828 Now make sure you read it all....
  11. Change the timing belt ASAP.... unless you want to drop 9+bills on a new motor.... I did... Fluid levels??? if its too low it wont blow hot... Bubble in the system... When you move the temp selector is it easy? hard? a little resistance?? My daughter complains about the heat in the 92... it always works for me....
  12. You sure its not the spare tire carrier, roof rack or the rear spoiler???? Something in the sunroof rain tray??? A screw in the rear drivers side ashtray drove me nuts for 2 or 3 months once....
  13. Check the Codes... Sounds like it kicked into "Safe Mode"...
  14. You can see the back hose with a inspection mirror and a flash light... If you find it to be the source, I would recomend changing both...
  15. Marks look like they are where they should be.... Its a vacuum thing....
  16. I would like a set like that for my 95.... Powder coat them black.....
  17. Fix that stuff 1st... no sense in screwing with the Timing if everything else is known to be incorrect or not hooked up... a simple vacuum line will cause it to run like crappola....
  18. It does have to be 43 teeth from the cam mark to the crank mark and both of them have to be close to the right spot....
  19. I would have asked him for a rental fee on the jumper cables or battery....
