Everything posted by Casey.T
Amazed that the previous 2 did not tell you... Welcome, have fun join in anywhere and just ignore the whipping boy....
I got a new dog from the Animal Rescue a couple of weeks ago
Casey.T replied to TrailChaser's topic in Off-Topic
Red Healer... Breader Stamp/Brand thing... Its very possible shes a pure bread and could possibly be papered... Contact your local AKC they may have the Breaders Brand on record... -
Doug Thorley Headers Group Deal
Casey.T replied to VegasPathfinder's topic in 90-95 WD21 Pathfinders
SL??? did you move the motor mounts??? BL??? did you move the motor mounts??? SL+BL did you move the motor mounts??? If you answered no to all of the above... They Fit... If you have a BL you might want to change the location of the tail pipe where it leaves the back of the rig, and there may be some minor interference from the inside of the fender wells... Basically they will fit... -
Your showing me all the things I get to look forward to once the garage warms up a little.... no fun working in 33deg F....
Might have to upgrade to a Spotter..... As for ranking: Strength: 128,276 [Ranked: 630] Agility: 209,447 [Ranked: 507] Guard: 68,338 [Ranked: 685] Labour: 22,951 [Ranked: 852] IQ: 12,510 [Ranked: 962] Rig Strength: 26,701 [Ranked: 701] Rig Ability: 24,818 [Ranked: 675] Total stats: 493,041 [Ranked: 661] and I dont have any will bottles... so its 1 good train a day, then the rest is kinda futile.... i need 299mill for a nuke shop... Upgraded to Elite Competition Shop friday night....
Im pretty sure you can.... Now your going to make me go look at the 2, 60mm tb i have from a Max VG30DE.... They are for my 300zx VG30DE
Your Rigs Equipment Trail Tools Dual Air Winch Tires Comp Cutters Engine Small Block Turbo V8 T-Case Military Single Rig Armor Exo Cage And I cant make the Cliff, Shocker or Rubicon.... Guess I need more Ability and Rig Strength Your Rigs Equipment Primary Weapon Shoulder Percussion Secondary Weapon Portable S.A.M. Personal Armor Passive Assualt Armor ^^^ all the reasons why K9 Thinks im a play toy.... That and I have not broken 200k on any of my stats...
I put a disclaimer on that.... 3.5 motor would be nice....
Best way to improve your R50 is to upgrade it with the WD21.... Sorry I could not resist...
Get an alignment too....
yes he does... hes from way down south... they do things a little backwards.... Running Rough once it warms up???? Check the ECU codes, could be as simple as a loose MAF wire...
If you removed the Distributor and you were not at TDC, and you just tossed it back in... ya your not gonna start unless you are reallllllllllyyyyyyyyy Lucky.... Timing reset time for you... and its not like Windows... turn it off then back on and it works fine... front timing cover is going to have to come off so that you can align the timing marks and then reset the distributor...
Happy B-Day.... :tonguefinger:
roof rattle, looking for any help i can get
Casey.T replied to laxman0324's topic in 96-2004 R50 Pathfinders
See I was right..... this time... hehehe -
the other end of that plug on the back is prolly hanging down around the trans... if you have your hood off you can look straight down and find it.... In the future loosely zip tie it to the knock sensor wires... wont have to reach down as far.... NO SILICONE>>>> Just torque the plenum on per the FSM... I take the torque requirement divide it in half and torque in 2 stages....
2 bolts and that plate comes out... then use about 24" or so of extensions and have the ratchet hanging out in front of the CL where you got lots of room...
Bitch.... wheres mine???
and you might find something like this..... http://www.nissanpathfinders.net/forum/index.php?showtopic=12828 Now make sure you read it all....
95 V6 poor heat, makes for whiny kids!
Casey.T replied to tmoore4512's topic in 90-95 WD21 Pathfinders
Change the timing belt ASAP.... unless you want to drop 9+bills on a new motor.... I did... Fluid levels??? if its too low it wont blow hot... Bubble in the system... When you move the temp selector is it easy? hard? a little resistance?? My daughter complains about the heat in the 92... it always works for me.... -
You sure its not the spare tire carrier, roof rack or the rear spoiler???? Something in the sunroof rain tray??? A screw in the rear drivers side ashtray drove me nuts for 2 or 3 months once.... -
Check the Codes... Sounds like it kicked into "Safe Mode"...
You can see the back hose with a inspection mirror and a flash light... If you find it to be the source, I would recomend changing both...
