Morningwould
Everything posted by Morningwould
  1. let me know when you pull the trail master kit out, and what you might want for it.
  2. The herculiner works great as long as you put on 2 - 3 coats. I used in in the bed of the last el camino I had and never had a problem with it. The only problem I can see with doing the entire floor in your pathfinder is the wiring that was hidden by the carpet that is now exposed. If you come accross the duplicolor spray on kit stay away from it. I used on the floor of a van once and the gun that comes with it is junk. and the material is not very durable. As far as the rustoleum stuff you found. I've never seen or used it. Also if you have an undercoat spray gun. You can use that to apply any of these polyurethane bed liners.
  3. Change, screws, bolts, light bulbs, and fuses
  4. Also as far as the shocks go. I ordered mine online from rough country. All 4 shipped for $152. That is for the RC8000 shocks. The part numbers I ordered from rough country are 8109 for the front and 8105 for the rear. The shocks that rough country sells are actually heckethorn shocks. If you want the RC9000 shocks the part numbers are 9109 for the front and 9105 for the rear.
  5. If his idea doesn't work for you 4 wheel parts carries the superlift UCA kit with bushings and ball joints for $278. The rough country UCAs are the superlift ones painted black. The superlift part number for the kit is K297. When you call 4 wheel parts they can look it up by this number.
  6. Are you sure it's carburated? It should have a throttle body. Does your valve cover say Z24I?
  7. My pressure washer has a hose to mix detergent with the spray. I hook up some simple green and pressure wash it. I do this at least 2 times a year on my concrete driveway. Always gets the stains out
  8. I work with aries247, and when I happened to trade my sks for an 87 pathy. I got roped into the forum.
  9. Mine is gray. Just like the weather here in Washington. But soon to be snow camouflage as soon as it warms up enough to paint it in my carport.
  10. Kingman as far as yours sputtering when you press and let off the brake pedal. Your brake booster probably has an internal vacuum leak. to test it pinch off the vacuum line to your booster and pump the brake pedal if it doesn't sputter then there is an internal leak in your booster.
  11. Just remember you get what you pay for.
  12. I have a Z24 with a 16 gal tank and the most I've ever squeezed out of it is 230 miles. I average 15-16 MPG back and forth to work.
  13. Back in the datsun days there were a lot of duplicates being made.
  14. is the leak near the base of the turbo or the intake hose coupler?
  15. I know the 87 - 92 pathys use a 3 piece front bumper, and the 93 - 95 pathys use a 1 piece front bumper. Does anyone know if they share mounting locations? will the 1 piece bolt up to a 87 bumper bracket?
  16. eazzrider. I think you should buy it for $70 and sell it to me for $100
  17. If you want a 32 that is narrower than an 11.5 go with a metric size tire. here is a link to a tire and wheel calculator that will give you all of the conversions you need. DML tire and wheel calculator
  18. where can i get the light bar that mounts in place of the upper 4x4 logos on a 2 door pathy. like the one in TerranoNZ's avatar picture.
