GrimGreg
Everything posted by GrimGreg
  1. I started hitting the Nissan related sites in 01 when I got my 93...
  2. At least they carried the WD-21 platform well into the 2000s in that country. You could probably make a mint shipping out body/light parts from the latter models.
  3. GrimGreg
    AC UCAs
    Yes and no.... The front suspension only has a range of movement from upper bump stop to lower bump stop, any lift/lowering done to the truck does not change that. So as your front end flexes the angle on the compression rod continually changes all the time. So while sitting still, the angle might be slightly different than before, but it is still well within it's acceptable range of movement. So yes, the angle is different, but no it should not increase the wear on it.
  4. I have the 1.5" AC coils on my 93, with a slight t-bar lift in front, stock UCAs. In the 8 years since I installed the coils and cranked the bars I haven't had any real issues. I changed out my ball joints 2 years ago from wear, but they were the originals (16 years old). The springs initially gave me about 2" lift in the rear, but settled down after about 6 months, and haven't drooped yet.
  5. Not common, but it might be a problem with the distributor shaft, or the crank angle sensor. Does the rotor turn when you crank it?
  6. The body sheet metal is thin enough to use aviation sheers on if you didn't want to use a cutoff wheel. I cut mine a 1/4" long and bent it over to restrengthen the edge when I cut my 88s.
  7. Really, everytime someone says something he doesn't like, he flys off the handle like a huffy, puffy, 2 year old.
  8. So is non-DOT lighting. There are a few states that check too.
  9. I had to ratchet strap one side on mine, the one side went right in, but then it limited the movement to get the other one in without some help. As long as you hook it right, and the strap isn't worn out or to light duty, it is just fine.
  10. I tend not to video myself. But have been caught on video, search "Pathfinder on rocks".
  11. Mike (Gator) used to be on 4x4parts.com regularly, I know he pops in on the NOAS board now and then too.
  12. Those are a generic roll type, you can get them in wider versions too. They usually attach with sheet metal screws onto the fender lip.
  13. You installed the damn things yet?
  14. And if the seat bottom sticking up is an issue, undo the 2 12mm bolts on the hinge and remove the bottom completely.
  15. You could always get the 3M rocker spray, it is made to be painted over, or they have a tintable version that you could mix pink.
  16. Mine were basically 2 piece, the part that stuck on the stub shaft, and the outer hub. The outer hub has moving parts in it, but I saw no need to dismantle them.
  17. Don't over do it, you just need a light coat, not gobs of goo allover
  18. Looking at thae picture it looks like most of your snap ring isn't sitting in the groove, maybe that was part of the cause, or part of the effect?
  19. Why the fuss, do you plan to ever remove them? If you want to remove them later, why bother installing them to begin with? If you plan to leave them, what will drilling holes hurt it?
  20. Yeah, what do you have; 2wd/4wd? What kind of budget do you have? How extreme do you want to get, do you want to still have it street friendly? Etc. etc.
  21. Sounds like you are good to go, it only takes about 5 minutes per hub, so go do et!
  22. I live by the K.I.S.S. theory, Keep It Simple Stupid!
  23. Not a dropped hitch, but maybe an extended one that puts the ball further back, or extend the tongue on the trailer.
