All Activity
This stream auto-updates
  1. Today
  2. Not limited to 00+. The trucks that had it were 2WD...but maybe some really old W/D21 4WD before 4-wheel ABS systems came into play. For sure, that setup has existed for a long time. My 98 2wd Frontier had it with the H190 axle, and now that I have an H233B in it, I used an older Hardbody diff to retain the system. Stated differently, it won't matter if the diff has it in your case. It won't get used, and you won't need to remove it. But the flange protrudes a little farther than the non-ABS version because it has more components to work it, but the bolt pattern is the same (I overlooked you said it was from a Frontier). You can't move your flange to housing because it won't clear the snout due to bolt holes that mount the sensor flange. The longer flange means you need to confirm that your driveshaft doesn't bottom out in the t-case when the rear suspension is fully compressed. Parts look like this:
  3. Yesterday
  4. Is the abs sensor you're reffering to the electrical sesnor on the diff? If it is, yes the one I am looking at has that, but my diff does not. It seems like all of the 00+ diff's have that sensor there.
  5. It's amazing how messed up a VG can be and still run! Hopefully it goes as long as you need it to.
  6. Last week
  7. Same thing just, different mfr. KYB is obviously cheaper in cost.
  8. What’s the difference between these 2? Do I need both or one or the other?
  9. Tyler's videos helped a lot when I was deciding what I wanted to do when I still had very limited knowledge of these rigs. If you did a subframe drop as opposed to a coil lift in the front you wouldn't have to use camber bolts as you can fix the camber in the spacers. How ever, I would suggest doing the AC and LR route. It feels great as a daily and being a college student you should have minimal issues (sight bumper rub when full lock and CV boots like to tear).
  10. i always get rid of the spider web of stuff under the intake. my fix are these large thick vacuum caps you can get at a local part store. Been running my woods truck like this and just did the r50 i got. unfortunately in this picture you can see where i left my hose clamp off on the heater hose lol ' https://imgur.com/a/5rEE8mI
  11. it was number 2 intake, 1 exhaust, and 3 intake and exhaust. and i hate to say this.......... i stuck them right back in lol. Motor was a gamble to begin with considering milage, blow head gasket and the fact cylinder 2 and 6 had some bad pitting in the cylinders. This motor isnt long for this world and i dont expect it to be. Just trying to keep it running long enough to actually build the truck and then im gonna be souring a lower milage one and spruce it up a little. Ive got an extra supercharger for my xterra ill probably end up stuffing under the hood at that point also
  12. I found a couple of similarly failed lifters in a VG33 recently. Out of curiosity, which lifters let go? Mine lost #1 and #5 exhaust. I ask because the only other thread I've found where somebody had that happen, it was the same two lifters that let go. I ended up scrapping that engine, but held onto a few bits and pieces, including the rest of the lifters. PM me if you want a few (unknown mileage, used) lifters that don't look like they've been used as tire studs.
  13. I'll give it a read my man! Worst case I Sas this one too hahha
  14. The 2WD 3rd will physically fit all the same, but if the pinion flange is like how it used to be on trucks with the ABS sensor on the pinion snout, the flange will be about 3/4" longer than models with the ABS sensors at the drums. Though...I want to say some 2WDs (maybe the QX4?) had a CV-style driveshaft with a different bolt pattern. Pics would help confirm that. All R50s have 33-spline. The 31/33 split applies to Frontiers. Xterras were all 33-spline...you can use a 3rd from a 00+ Xterra or Frontier as well. Same HG46 ratio.
  15. You'll probably know it as "high pinion" (reverse cut) and "low pinion" (standard cut), much like the reference on Dana axles. The pinion line is either above or below the centerline of the ring gear. Rotation's all the same, but the teeth on the gears are cut in opposite directions. R200A from an W/D21 or W/D22: R50 R200A: In general, high pinion is best up front, and low pinion best in the rear due to gear mesh. But fck Nissan for making the R50 the only high-pinion R200A application. The short answer is they can't be (easily) swapped because they are mounted to the truck in completely different ways. The long answer:
  16. I appreciate the open arms! lol talk to me about this reverse cut stuff. ive never really understood it. As for the differential itself, whats limiting me to sticking an xterra full front diff in place of this one?
  17. I recognize that X from the Nissan SAS group. Welcome back. All R50s are 33-spline...but the problem with 4.9s is that there isn't a set that fits the front axle. R50s have reverse cut gears up front in the R200A; W/D22 are standard cut. You're limited to 4.6s, and hopefully that's what you already have.
  18. Scored this little 96 about 3 weeks ago. guy said it had an overheating problem with 223k on the dash. Drove 3 hours to check it out and it looked promising so i got it. 5speed 4wd, clean interior, not alot of rust thank goodness. But come to find out the headgasket had pushed out on cylinder 4 so tore it all apart. Upon having it all tore down cylinder 2 and 6 had some pitting in the cylinder, so took a 3 stone hone to it and tried to clean it up the best i could. few lifters were a little beat up but we are gonna run it as is. Get it all back together, and it fired right up. Throttle had a bit of a hesitaton when you blipped it but ran fine when you barley got into the throttle. Come to find out MAF was no good. Stuck one in from my Xterra and she runs just fine. Unfortuently the trans may be bad, gotta get it out and check the counter shaft bearing in the front, being its howling pretty bad on de-celeration. worst case i source a wd21 trans since the gearing is better. Plans are to source a SFD and get some 33s or 34s under it. Question, being a 96 is this thing 31 spline or 33? cause id like to get some 4.9s in this thing also Anywho lets see how this thing goes https://imgur.com/a/BbKLrpJ
  19. Dakota Digital made a device that I used in my first R50 for adjusting the speedo, but it had a problem where it freaked out when the input and output signal were the same. It was more designed to handle vastly different speedo sensors to speedometers...like 2000PPM on the sensor side and 60,000ppm on the speedo side. Some motorcycle speedometer correction devices seem more focused only going up or down 7% or whatever you are off. Those may be looking into. Motorcycles are almost ALWAYS 5mph faster on the gauge then you are actually going, which pisses me off to no end. The tone rings on the rear axles would have been tight, but cool to be able to build something like that.
  20. Okay, I am too old for this. Put everything back together, finally...after lord knows how many days, and I believe the new water pump is leaking. Either from the weep hole or...I guess the weep hole. Why did I stop drinking whiskey again? Man.
  21. Earlier
  22. Hey everyone, the rear diff in my Pathfinder with 235k miles hums pretty loud on the highway between 50 and 70mph and is now making noises at lower speeds. I also hear a growling noise around 20-30mph when slowing down. Recently, when putting the vehicle into drive or reverse, I hear a clunking noise. I had someone shift gears while I was underneath the vehicle and I visbily see the driveshaft rotate at the diff. Nothing is shifting at the tramission mount and no noise is coming from there. I was thinking of purchasing a 3rd memeber and swapping it out without removing the entire assembly. The plate under my hood says HG46 for the differential and I found one on ebay that appears to be in excellent condition and is also an HG46. However, this one is from an 01-02 frontier 2WD (there is also a plug connector on it, which mine does not have). Will this swap into my vehicle? I read online that the HG46 axles had 31 splines pre 2000 and 33 splines post 2000? Thank you
  23. So, I pulled the original Z24 out from under my bench. This was a runner, but smokey when I swapped it almost 20 years ago. One piston (#3) had bad rings and ring lands. Bores however, cleaned up nicely with a hone. Waiting for parts now. Will get new pistons, rings, bearings, timing chain/tensioners, oil pump. Have a reco head here on the shelf. The KA24DE swap can wait for now.
  24. I'll be doing mine when I replace the rad support. Might see if ol' daddy nissan still sells em. Had really bad luck with aftermarket parts lately. Also planning on converting my square tooth 91 engine in my 95 to the proper teeth.
  25. I was wondering to buy on X-Bull winch... I am designing an under the bumper tray and install the winch... So, does some one have experience with X-Bull winches? I am looking at the X-Bull RSX 13.500lb ($407 Shipping and taxes to Colombia), or the XPV 10.000lb ($286 +Shipping and taxes to Colombia) Thanks.
  26. I was wondering to buy on X-Bull winch... So, Still have it? How's the winch holding up? Thanks.
  27. Word. It was definitely a cam seal, and it was certainly unreturnable. Of course it has been 200k since I last did this job and my goodness that extra $80 in seals, hahaha...wow. PVC pipe certainly helps tap the RIGHT crank seal in, but geez....
  1. Load more activity
