All Activity
This stream auto-updates
  1. Today
  2. Still waiting for my pistons and rods, but decided to lift the old lump out. Last time, I pulled the trans, this time I thought I'd try the method of removing the front diff. Way easier than dropping the trans, but I will be honest - I am getting too old for any of this
  3. Yesterday
  4. If the clutch pedal is anything like the clutch pedal on an R50 it might be caused be a worn clutch pedal assembly. I had a very similar issue on my R50 not to long ago. Turns out that the pin that connects the clutch pedal to the clutch master cylinder had wallowed out the hole that it goes through and caused the clutch pedal to not be able to fully return to its resting place after the clutch pedal was released. Check out this short video for reference.
  5. Last week
  6. I got rid of my EGR a couple of years ago when I had the heads off of the engine. I noticed no change in performance. Unless your state requires it, I would remove it.
  7. Gotta love not getting notifications of any response... I have a union in the event that I need to bypass it. I checked the spring, because I thought that was the culprit. Turns out, it's fine. Still has me scratching my head since it's not leaking fluid.... The only thing that makes any sense would be the master cylinder or the dampener. However, if it was the dampener, it would just take up more fluid and still function as normal.... I think I may have just convinced myself that it's the master cylinder One of these weekends when I have time, I'll start tearing into it. It's still drivable for a while, just won't ever go on a long trip with it any time soon because of this.
  8. I haven't measured mine, but this guy says 22". Which engines are you looking at?
  9. Okay, no luck in search. I KNOW it is here somewhere. How long are the VG30E's? Want to transplant a modern engine in one day, but cannot find this detail...
  10. I agree, I am certain however that the EGR tubing is going to disintegrate when I remove the stock cracked manifolds....sigh.
  11. Earlier
  12. That's insane the @!*% with ups... I can only hope this insanity stops soon. It's not good for either side of the border.
  13. After 9 years of ownership it’s still my daily and I’m still in love! 274K purrs like a kitten.
  14. I have an old set of yokohama winter tires on lego wheels, that I use as "rollers" for my projects. The date code is from the year 2000... Of course these don't see the road.
  15. I know a lot of people like to delete stuff like those lines but the truck just runs better when you don't try to engineer it yourself lol.
  16. so little update. Got my SFD ordered back in like november and it showed up in december BUTTTTT the lovely people at UPS messed up the box quantity with item quantity and the tariffs/duties skyrocketed to 2400 bucks per box. which means 4800 for 2 boxes with 500bucks worth of parts in them lol so its been re routed back to the shipper in canada and is currently "lost" per ups but they found it in montana. It has been an absolute shyt fest and waiting. So in the meantime i put on some 2in AC coils from 4x4parts and debating on if i want to rip the trans out of it to do the clutch now and replace the input shaft bearing since it is howling and making all kinds of racket. Heres a pic of the truck last night after i did the coils
  17. Good lord. And here I thought I was pushing it at half that!
  18. Agreed, the 2nd part appears to be some sort of NVH damper. It's not a transmission mount, that's for sure. If you buy from Amazon, you can search for the 1st p/n and it'll return a bunch generic options. Ebay, too. Anchor 9011 for $19: https://www.ebay.com/itm/297995046269. If you have a clunk when you change gears, the problem is more likely to be your motor mounts, specifically the driver's side. If your transmission mount has sheared or shows signs of shearing, I'd be certain at least one of your motor mounts has already given up the ghost. I changed mine out a few years ago on a whim, and the 2 pieces came out in 4.
  19. I've had a set of Michelin LT tires on my Pathfinder for TWENTY YEARS! Yes I know that's way too long to be riding on a set, but after about a hundred thousand miles, they still have lot of tread. I had a flat a couple days ago, and had to run on the flat for a couple hundred yards, and the tire actually started to break apart. So, let me tell you guys. Twenty years has got to be the absolute upper limit for the useful age of tires. The Michelin LT tires really are too heavy and hard for ride comfort, but they sure do last. They haven't required balancing for years, and were still smooth as could be on the highway. And of course, I certainly DO NOT recommend running a set for this many years.
  20. Looks like the VG and VQ R50s used the same trans mounts, and they are still available aftermarket. I looked it up for '01 and '97 on RA (I know you can't order, but it's still a good parts lookup) and found Anchor 9011 and Westar EM9011 marked as rear/4WD/manual. I punched the Anchor PN into the Gargler and it spat up a few other vendors listing it. Hopefully one of them actually has it in stock. The second PN comes up as some kind of damper rather than a mount. Possibly an NVH thing? If so, I'd be surprised to find one aftermarket.
  21. I have a 2001 3.5 4x4 MT. The rear motor mount/transmission mount are moving a ton and I think is the reason I have a clunk when I change gears. Part numbers that I found are: 113201W200 113754W000 I cannot find them anywhere, what aftermarket have you used that will work for me? Any part numbers? I also cannot use rock auto since I’m in AZ. Thanks for your help!
  22. Crank and new main bearings in the big Z24 over the weekend, main bearing clearances and thrust all measured up great. Pistons, rings and new clutch turned up last night I just need to get the pistons pressed on and then I am ready to assemble. Can't wait to have my old girl going again!
  23. Sorry for delay guys. I ended up just replacing all the rubber and keeping it intact. I do plan on removing the EGR and all that nonsense when I put these headers on and redo the entire exhaust...(SAS requires it!) Just not there yet.
  24. Yeah I concur. Gotta wait a bit for it to warm up some, no shop anymore. Will probably just rhino-line the entire thing at that point. But...I am also considering deleting the two rear side windows so might do that as well. While the forum was down this one dude kept posting things he was doing to his WD21 (I think he is sponsored by Rival Offroad maybe?) and did the same, put some flip up truck camper top type covers in there and had storage space accessible from the outside. Not sure why, but it crossed my mind.
  25. Well, tore it down and put it back together with a new pump. The "new" one I put in was leaking pretty bad, guess the seal was bad from the get go. All is well now. Thank you for all the input gents!
  26. Plenty of info on TD27s on the Aussie facebook groups, a lot of us are TD nuts, they will be able to give you all the measurements and info you might need. There is a group 'TD27 Torque' which will have plenty of help.
  27. Superstar. Great to have the extra support. Huzzahhh!
  28. yep ! that's a good guy ! happy that the forum is back online... facebook groups are just not my thing when you search things ! way to go adam
  1. Load more activity
