All Activity
- Yesterday
Hytekrednek started following Precise1
I haven't measured mine, but this guy says 22". Which engines are you looking at?
- Last week
Okay, no luck in search. I KNOW it is here somewhere. How long are the VG30E's? Want to transplant a modern engine in one day, but cannot find this detail...
CamperDan started following Vq35de Engine Swap
That's insane the @!*% with ups... I can only hope this insanity stops soon. It's not good for either side of the border.
I have an old set of yokohama winter tires on lego wheels, that I use as "rollers" for my projects. The date code is from the year 2000... Of course these don't see the road.
so little update. Got my SFD ordered back in like november and it showed up in december BUTTTTT the lovely people at UPS messed up the box quantity with item quantity and the tariffs/duties skyrocketed to 2400 bucks per box. which means 4800 for 2 boxes with 500bucks worth of parts in them lol so its been re routed back to the shipper in canada and is currently "lost" per ups but they found it in montana. It has been an absolute shyt fest and waiting. So in the meantime i put on some 2in AC coils from 4x4parts and debating on if i want to rip the trans out of it to do the clutch now and replace the input shaft bearing since it is howling and making all kinds of racket. Heres a pic of the truck last night after i did the coils
- Earlier
Good lord. And here I thought I was pushing it at half that!
hawairish started following Transmission Mount
Agreed, the 2nd part appears to be some sort of NVH damper. It's not a transmission mount, that's for sure. If you buy from Amazon, you can search for the 1st p/n and it'll return a bunch generic options. Ebay, too. Anchor 9011 for $19: https://www.ebay.com/itm/297995046269. If you have a clunk when you change gears, the problem is more likely to be your motor mounts, specifically the driver's side. If your transmission mount has sheared or shows signs of shearing, I'd be certain at least one of your motor mounts has already given up the ghost. I changed mine out a few years ago on a whim, and the 2 pieces came out in 4.
I've had a set of Michelin LT tires on my Pathfinder for TWENTY YEARS! Yes I know that's way too long to be riding on a set, but after about a hundred thousand miles, they still have lot of tread. I had a flat a couple days ago, and had to run on the flat for a couple hundred yards, and the tire actually started to break apart. So, let me tell you guys. Twenty years has got to be the absolute upper limit for the useful age of tires. The Michelin LT tires really are too heavy and hard for ride comfort, but they sure do last. They haven't required balancing for years, and were still smooth as could be on the highway. And of course, I certainly DO NOT recommend running a set for this many years.
Looks like the VG and VQ R50s used the same trans mounts, and they are still available aftermarket. I looked it up for '01 and '97 on RA (I know you can't order, but it's still a good parts lookup) and found Anchor 9011 and Westar EM9011 marked as rear/4WD/manual. I punched the Anchor PN into the Gargler and it spat up a few other vendors listing it. Hopefully one of them actually has it in stock. The second PN comes up as some kind of damper rather than a mount. Possibly an NVH thing? If so, I'd be surprised to find one aftermarket.
I have a 2001 3.5 4x4 MT. The rear motor mount/transmission mount are moving a ton and I think is the reason I have a clunk when I change gears. Part numbers that I found are: 113201W200 113754W000 I cannot find them anywhere, what aftermarket have you used that will work for me? Any part numbers? I also cannot use rock auto since I’m in AZ. Thanks for your help!
Crank and new main bearings in the big Z24 over the weekend, main bearing clearances and thrust all measured up great. Pistons, rings and new clutch turned up last night I just need to get the pistons pressed on and then I am ready to assemble. Can't wait to have my old girl going again! -
Sunroof cover decided it was done
Yeah I concur. Gotta wait a bit for it to warm up some, no shop anymore. Will probably just rhino-line the entire thing at that point. But...I am also considering deleting the two rear side windows so might do that as well. While the forum was down this one dude kept posting things he was doing to his WD21 (I think he is sponsored by Rival Offroad maybe?) and did the same, put some flip up truck camper top type covers in there and had storage space accessible from the outside. Not sure why, but it crossed my mind. -
Front crankshaft seal installation
Well, tore it down and put it back together with a new pump. The "new" one I put in was leaking pretty bad, guess the seal was bad from the get go. All is well now. Thank you for all the input gents! -
Plenty of info on TD27s on the Aussie facebook groups, a lot of us are TD nuts, they will be able to give you all the measurements and info you might need. There is a group 'TD27 Torque' which will have plenty of help.
Please welcome adamzan as an NPORA Forum Moderator
FirstGenFreak replied to RedPath88's topic in NPORA Announcements
Superstar. Great to have the extra support. Huzzahhh! -
fleurys replied to RedPath88's topic in NPORA Announcements
yep ! that's a good guy ! happy that the forum is back online... facebook groups are just not my thing when you search things ! way to go adam -
That sounds more like sommething external to the motor. Do what @Slartibartfast said, if that isn't it, these trucks were kind of known for the harmonic balancer separating (it's a 2 piece press fit rubber thing IIRC). I would check that out as well. My parents 2000 R50 with the VG33E had this happen, twice. The first time, the dealer replaced a ton of parts before finding it. An easy way to check rod knock is to loosen all the plug wires at the distributor and then while the truck is running, remove one at a time and see if any make the knock go away or less pronounced. Good luck and keep us posted. For what it's worth, of all the Nissan vehicles I've had with the VG engine, I only ever had one with a rod knock and it was severely overheated several times/ran without coolant.
adamzan replied to RedPath88's topic in NPORA Announcements
Thanks! Glad to help out. -
He has been an NPORA member for nearly 20 years and a regular the whole time. Recently he worked with us in the background to get the forum back online, root out problematic DDoS sources and test for reliability. And now adamzan has agreed to join the Mod Team. Welcome adamzan!
I had a weird clatter turn out to be the front bearing in the alt giving out. Remove the accessory drive belts, run it, see if the noise goes away. If you do them one at a time you'll know which one is noisy. I would also give the water pump a spin, see if there's anything obviously wrong there. Given the front-end wreck, I'd also check that the fan shroud is held on properly, and the fan isn't making contact with it. Long shot, but worth checking. If it still makes the noise with all the belts off, might be worth pulling the timing covers to check the belt tension and the condition of the idler pulley. IIRC the keyway only locates the sprocket during assembly, and it's clamped in place by the crank bolt. So unless the crank bolt is loose, it shouldn't be able to rattle.
