vengeful Posted June 21, 2006 Share Posted June 21, 2006 It is a possibility. You've got the new 99, right? I'll see if I can find the procedure for testing the CPS and if I can find it, I'll post it. Link to comment Share on other sites More sharing options...
k9sar Posted June 21, 2006 Share Posted June 21, 2006 (edited) check FSM pg EC-277 (and it's referred to as the CKPS) Edited June 21, 2006 by k9sar Link to comment Share on other sites More sharing options...
ninoj Posted June 21, 2006 Author Share Posted June 21, 2006 It is a possibility. You've got the new 99, right? I'll see if I can find the procedure for testing the CPS and if I can find it, I'll post it. That would help alot! Link to comment Share on other sites More sharing options...
ninoj Posted June 24, 2006 Author Share Posted June 24, 2006 Is this the timing check? - Air conditioner off - AT in Neutral - Start engine and warm up fully, do not exceed 1000rpm - Open engine hood and run engine at 2000rpm for 2 minutes under no-load - Perform diagnostic test mode II (no idea if this is required) - Run engine at 2000rpm for 2 minutes under no-load. Race engine (2000-3000rpm) two or three times under no-load, then run engine at idle speed. - Turn off engine and disconnect TPS - Start and race engine (2000-3000rpm) two or three times under no-load, then run at idle speed - Check ignition timing with a timing light (crank has 5 marks, 0,5,10,15,20) should be 15 +/- 2 BTDC. - Adjust timing if necessary by turning distributor after loosening securing bolts. - Turn off engine and reconnect TPS Link to comment Share on other sites More sharing options...
ninoj Posted June 24, 2006 Author Share Posted June 24, 2006 Now it sometimes shuts off while I am driving. I slip it in park take the key out and it starts bang on. Any ideas? Link to comment Share on other sites More sharing options...
94extreme Posted June 24, 2006 Share Posted June 24, 2006 (edited) if it's anything like the earlier gen moce II is Mixture Ratio Control Monitor which is probably where you're having issues. not sure if your truck has tbi or injectors but normally, in the supply line there is a bicycle type valve (shraeder(sp?)) where you hook the guages on.. not sure if zone will do the diagnostic mode II for you.. ask them. from what i have read a few times now is that you guys can do the screw flipping thing too without having to connect to an external device.. something about above the pedal.. hard to access but doable.. oh yeah, check for spark at the plugs.. also pop hood at night and see if there is a light show.. Edited June 24, 2006 by mzxtreme Link to comment Share on other sites More sharing options...
ninoj Posted June 26, 2006 Author Share Posted June 26, 2006 Alright this puppy is now officially not starting at all. I guess whatever was failing completely failed. Turns over but does not kick in. Link to comment Share on other sites More sharing options...
vengeful Posted June 26, 2006 Share Posted June 26, 2006 not sure if your truck has tbi or injectors You of all people should know this Mz....Nissan stopped using TBI in everything in 1989. Link to comment Share on other sites More sharing options...
vengeful Posted June 26, 2006 Share Posted June 26, 2006 I'm at a total loss here....fuel pump maybe? Might be time to enlist the help of a mechanic. Link to comment Share on other sites More sharing options...
ninoj Posted June 26, 2006 Author Share Posted June 26, 2006 I'm at a total loss here....fuel pump maybe? Might be time to enlist the help of a mechanic. Thanks for your help! I am going to tow this puppy to the dealer. Link to comment Share on other sites More sharing options...
zonianbrat Posted June 26, 2006 Share Posted June 26, 2006 Unless you have a warranty on your 99.5 why are you going to take it to the stealership??? I am sure there is a mechanic around you that works on nissan and will probably not charge you nearly as much. then again i do not know your situation, all i know is i always read about how people take their pathy's straight to the dealer... i would only do it if i had a warranty. but that is just me. besides any mechanic will be able you run the codes for you then if it is something like simple you can replace it yourself, i guarentee the dealer is going to tell you all kinds of crap you need but probably really dont. sorry i will get off my soapbox now i just hate dealerships the screw you any chance they get. Link to comment Share on other sites More sharing options...
ninoj Posted June 26, 2006 Author Share Posted June 26, 2006 (edited) So I called a flat bed tow truck and had it towed to the dealer. They replaced the AIT air intake temperature sensor and said it should be fixed. The car started and didn't shut off while I was driving. I will post the results after a week of driving. Here was the cause they gave: Sensor was showing -45C in cold temp and 220C in warm temp. The engine was burning too rich and thus was flooding itself and giving some crappy mileage. Total cost $150. Edited June 26, 2006 by ninoj Link to comment Share on other sites More sharing options...
ninoj Posted June 27, 2006 Author Share Posted June 27, 2006 I was pretty skeptical of their quick fix, and I was right. It seems the problem is still there. They removed the error code but it did nothing to fix my initial problem. Link to comment Share on other sites More sharing options...
ninoj Posted June 28, 2006 Author Share Posted June 28, 2006 Check out the new video. Link to comment Share on other sites More sharing options...
max_stryker Posted June 29, 2006 Share Posted June 29, 2006 wow that video was insanely slow!!! LOL just doesnt wanna turn over all the way i guess... im thinking something along with fuel pump now...maybe Link to comment Share on other sites More sharing options...
John Boy Posted June 29, 2006 Share Posted June 29, 2006 I know this is extreme but I the same problem years ago with a Pontiac and after 3 mechanics changed every sensor possible I took it to the dealer and low and behold it was the "computer" that was no good. Good thing for me it was still under warranty. Point being mechanics like to just start replacing sensors and hope it works. Link to comment Share on other sites More sharing options...
ninoj Posted June 29, 2006 Author Share Posted June 29, 2006 Ya it is a guessing game with Mechanics, I am just hoping this puppy totally craps out. I am done playing the guessing game. Link to comment Share on other sites More sharing options...
ninoj Posted July 11, 2006 Author Share Posted July 11, 2006 Update: Just got a ride back to my office from the Nissan Shuttle Service. THese guys still can't figure out what is going on. Link to comment Share on other sites More sharing options...
vengeful Posted July 11, 2006 Share Posted July 11, 2006 I hope they're not charging you for storage! Link to comment Share on other sites More sharing options...
ninoj Posted July 12, 2006 Author Share Posted July 12, 2006 (edited) I am dying without a ride. Man, it sucks to have car problems. I got a friend working there as a mechanic so I am positive I won't get dinged with a storage fee. Edited July 12, 2006 by ninoj Link to comment Share on other sites More sharing options...
zonianbrat Posted July 12, 2006 Share Posted July 12, 2006 Well good luck hope it is not anything to $$ it sounds to me like your timing has gone retarded. Link to comment Share on other sites More sharing options...
88pathoffroad Posted July 12, 2006 Share Posted July 12, 2006 It's turning over just fine. It's not firing, that's all. Wierdness...that sucks. Link to comment Share on other sites More sharing options...
mattd123 Posted July 12, 2006 Share Posted July 12, 2006 how about the oil pump if there is no oil flowing to the engie it would seize right just a guess but worth a shot Link to comment Share on other sites More sharing options...
ninoj Posted July 18, 2006 Author Share Posted July 18, 2006 So I was at the dealer and it wouldn't start... What a surprise, they couldn't figure it out. Now I am up to whoring it around to every mechanic in town. Link to comment Share on other sites More sharing options...
zonianbrat Posted July 18, 2006 Share Posted July 18, 2006 Ok the "dealer" could not figure out what was wrong with it??? Wow something is fubar here. Did you find out what all they did to your ride??? Or did they just hook it up to a cpu?? Link to comment Share on other sites More sharing options...
