Valcryss Posted August 31, 2015 Share Posted August 31, 2015 Nice work. Be sure to check the blower motor squirrel cage to the right for leaves as well. Unless you like having your blower sound like a 10 year old's bicycle with playing cards clothes pinned to the spokes, lol The plastic grates are pretty broken. I snaked the hand vac hose down there best I could. It's going to the carwash for a big vac tonight. I'll probably just snap off what little plastic remains and get some new ones soon. Or fabricate one. I'm not very pleased with those plastic bits. I don't park under trees, so I should be good for a few days without one. Link to comment Share on other sites More sharing options...
maddmark1981 Posted December 5, 2015 Share Posted December 5, 2015 Yup mine too Sent from my MotoG3 using Tapatalk Link to comment Share on other sites More sharing options...
Terranovation Posted December 8, 2015 Share Posted December 8, 2015 Eye carumba that's a nice nest of junk you have in there. I bet you are feeling the air coming out of the vents now! 1 Link to comment Share on other sites More sharing options...
maddmark1981 Posted December 13, 2015 Share Posted December 13, 2015 Yeah it's made quite a difference and im not paranoid of catching fire now...lol Sent from my MotoG3 using Tapatalk 1 Link to comment Share on other sites More sharing options...
MrEviLDeD Posted December 19, 2016 Share Posted December 19, 2016 Ironically it was quieter in the Pathfinder before I cleaned it out. Now when set to high you cannot even hear the radio anymore The blower motor is a loud bugger. Link to comment Share on other sites More sharing options...
Terranovation Posted January 26, 2017 Share Posted January 26, 2017 I did my yearly inspection again and this time didn't find anything inside. I gave it a flush out with a couple of bottles of water. It flushes the air con drain tube. Link to comment Share on other sites More sharing options...
Citron Posted February 7, 2017 Share Posted February 7, 2017 Cleaned out mine the other day. Quite a bit of stuff in there. How do you pull off the grills for the cabin air intake? Link to comment Share on other sites More sharing options...
Slartibartfast Posted February 7, 2017 Share Posted February 7, 2017 The ones on the cowl? You'll need a pick or a little Phillips and six zip ties. Each grille is held down by three little rectangular-topped clip fasteners, and each of those has a circular bit in the middle. Press down on the circular bit and the clip releases. If you're careful, and lucky, you can reuse those clips. The other 364 days of the year, you put the grilles back on with the zip ties. If you remove the black plastic cover under the passenger's side grille and look in at the right angle, you can see into your blower. I glued a piece of wire screen over that hole after a mouse took a crap in my blower. It'll probably keep the pine needles out, too. 1 Link to comment Share on other sites More sharing options...
Citron Posted February 7, 2017 Share Posted February 7, 2017 That is exactly what I was thinking. I was going to use a peice of window screen. Thanks for the info. Link to comment Share on other sites More sharing options...
Slartibartfast Posted February 8, 2017 Share Posted February 8, 2017 Fair warning, the opening is kind of a pain to get to. That's why I ended up sticking my finger in there with a gob of seam sealer. Link to comment Share on other sites More sharing options...
Citron Posted February 8, 2017 Share Posted February 8, 2017 My plan was to attach the window screen to the back side of the cowl grill, but I will have to see how things look once I remove the grill. Link to comment Share on other sites More sharing options...
Slartibartfast Posted February 8, 2017 Share Posted February 8, 2017 I tried that on my last rig, but wasn't sure what to hook them to and didn't want to glue them, so the screen didn't do a whole lot. Looks like the new grilles come with cross bars molded into them to accomplish the same thing. 1 Link to comment Share on other sites More sharing options...
Gusthebus Posted March 16, 2017 Share Posted March 16, 2017 My heat hasn't been working as well as I would like on these colder days. I found this thread and thought I had solved the mystery.After removing the glove box I found that my Pathy didn't even have cabin air filters or the resistor pack. I can see the cut outs where they would be if they had actually installed them. I did cut out the slot and installed the cabin air filters. But how in the wild world of Nissans do I have a multiple speed fan if I don't have the resistor pack to control it??? I'm confused! Anybody else have this set up? Link to comment Share on other sites More sharing options...
Citron Posted March 17, 2017 Share Posted March 17, 2017 I read somewhere that later models put the resistors in a different location. 1 Link to comment Share on other sites More sharing options...
Gusthebus Posted March 20, 2017 Share Posted March 20, 2017 I read somewhere that later models put the resistors in a different location. Any idea where? I can't seem to find any other info on the webs. Link to comment Share on other sites More sharing options...
Citron Posted March 20, 2017 Share Posted March 20, 2017 I thought it was on a previous page of this thread. IIRC about mid run of the wd21 they moved the resistors to a different location. I will look around a bit. 1 Link to comment Share on other sites More sharing options...
Slartibartfast Posted March 21, 2017 Share Posted March 21, 2017 My '95 had the resistor pack in the same place my '93 does, no idea on the R50s though. 1 Link to comment Share on other sites More sharing options...
Citron Posted March 21, 2017 Share Posted March 21, 2017 Yes, I was mistaken, the only change mid run was adding a shield to the resistors to prevent debris contact. 1 Link to comment Share on other sites More sharing options...
Gee_Aye Posted May 27, 2017 Share Posted May 27, 2017 Could this be why my whole dash vibrates and makes a lot of noise when turned up to 3 or 4? You have leaves in the blower motor squirrel cage. It sits upright like a bowl to catch everything that comes in. Pull your resistor and clean it and the box then drop the blower motor to the right of the resistor and clean it out. This happens to alot of vehicles. James I have this problem on the '92 I just bought. Thanks for the info Link to comment Share on other sites More sharing options...
Gee_Aye Posted June 9, 2017 Share Posted June 9, 2017 Guys, I removed my glove box today to clean the blower assembly but instead of finding the metal panel with 4 screws I was confronted with molded plastic that seems to be attached to/part of the dash.... I tried to figure out how to remove the dash but have not had any success... I think i need to remove the trim that covers the demister vents so I can access the screws underneath but i'm finding it really difficult. I've popped the clips along the front edge of the demister trim but it still doesn't want to move. What am I doing wrong? Link to comment Share on other sites More sharing options...
RedPath88 Posted November 17, 2018 Share Posted November 17, 2018 BUMP for new members Link to comment Share on other sites More sharing options...
